Old 5th September 2016, 18:12   #106
numerouno.no1's Avatar
Thanked: 302 Times
Re: Restoration: Renewing my Rajdoot 175 (1972 Model)
Today I went to jail road for wheel set up. Sadly the old wheel drum's bearing distance bush turned out to be a bit longer than what I had purchased.
The one I purchased was of new model.
Plan to set up the wheel gets postponded for a week. Just ordered two pairs of old model wheel drums bearing distance bush.
So a lesson learned, old model wheel drums have 6 cm long distance bushing with collar size 1/2cm..
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160905_154214.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160905_180948.jpg
numerouno.no1 is offline   (2) Thanks
Old 8th September 2016, 06:04   #107
Thanked: 302 Times
Even though my rear and front wheel drum sets are new there were a lot of scratches on it. Well this is what happens if something is lying there for nearly 30 years.
So, I tried my hands on painting it with Aluminium paint from British Paints. Although it is just the first coat but it seems the final result will be great. Just sharing pics of Drum Sets after scraping old paint and with just 1st coat of paint being applied.
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160908_055632.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160908_055127.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160908_055030.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160908_055105.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160908_060002.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160908_055159.jpg
numerouno.no1 is offline   (4) Thanks
Old 15th September 2016, 21:21   #108
Thanked: 302 Times
Just got them fixed and balanced. I will upload more on this later.
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160915_211338.jpg
Old 16th September 2016, 16:19   #109
autocrat's Avatar
Thanked: 732 Times
Numerouno, I am liking the way you are progressing with the restoration. Absolutely nothing being done in a hurry. A thorough job!
autocrat is offline   (2) Thanks
Old 16th September 2016, 19:17   #110
Thanked: 302 Times
Here are the Genuine SIKAND (8.8 class) bolts & nut (Used by escorts Ltd. for rajdoot) in Shockers and Torque damper:-
1. Front absorbers (Top & bottom) & Rear shock absorber ( Top only) 6 pcs- 16mm head size, 2 inch length, 1 inch threading.
2. Rear shock absorbers (Bottom) 2 pcs ( Unbrako 10.9 class)- 13mm head size, 2 inch length, 1 inch threading.
3. Torque damper bolts 6 pcs- 16 mm Head size, 1½ inch length , ¼ inch threading, Sleeve- thickness & length ¾ inch, Nut 13mm.
Escorts Ltd used Fasteners manufactured by either sikand or STL. Sikand had superior quality. Anyhow the standard of Fasteners were Same i.e 8.8 class.
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160916_191416.jpg
numerouno.no1 is offline   (3) Thanks
Old 16th September 2016, 20:34   #111
Thanked: 302 Times
I really appreciate your support. Whenever anyone thanks me for my post, I must say it encourages me to do more. You have been consistently supporting me here. Thanks for your interest in this project.
Old 27th September 2016, 16:46   #112
Thanked: 302 Times
Finally, after searching so many places, i could get genuine front and rear drum bearing distance. Reason for this delay is its size normally 3 cm to 5.5 cm distance go in Rajdoot but this being old model, size of distance was 6 cm, very rare item. One can guess how tedious it is to find these stuffs.
I have now complete parts and the bike is almost complete. Some pictures of the immaculate fitment of genuine parts.
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160927_163648.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160927_164537.jpg
Old 28th September 2016, 00:36   #113
Thanked: 302 Times
Incredible!!! Got these genuine RAJDOOT magnet puller and it is unused. It was manufactured by Escorts for its technicians. It is of historic value, quality is awesome.
IT IS A PIECE OF BEAUTY
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160928_003202.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160928_003316.jpg
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160928_003356.jpg
numerouno.no1 is offline   (7) Thanks
Old 28th September 2016, 14:47   #114
Thanked: 302 Times
Choke piston Kit for converting MIKCARB VM 24 carburetor with lever operated choke to a wire operated one.
Happy that my bike will have handlebar mounted choke lever system that will look exactly same as it used to be.☺
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20160928_144637.jpg
numerouno.no1 is offline   (5) Thanks
Old 28th September 2016, 15:09   #115
autocrat's Avatar
Thanked: 732 Times
Sir, I am particularly impressed with the magnet puller! I am trying to find one for Chetak and its not available in Bangalore! In haste I pulled out the flywheel by prying it out with a screwdriver and now I see the flywheel is bent. I need to get a new one.
I really appreciate your patience.
autocrat is offline   (1) Thanks
Old 28th September 2016, 16:01   #116
Thanked: 302 Times
Thanks for You support. If you are not able find that flywheel, then I can help. I just talked to a guy in Banglore itself, he says he can arrange in few days. Please message me your name, number and model of scooter. I will give you his number, from thereon you can coordinate.
numerouno.no1 is offline   (1) Thanks
Old 3rd October 2016, 22:48   #117
Thanked: 302 Times
My restoration process hit a roadblock when the new piece of rear drum brake plate turned out to be faulty .
So now searching for a new one as the old plate has worn out due to worm wheel.
My bike's present condition, everything else done. Just waiting for that part to close the bike.
Restoration: Renewing my Rajdoot 175 (1972 Model)-img_20161002_000536_mr1475495999166.jpg
numerouno.no1 is offline   (6) Thanks
Old 4th October 2016, 15:29   #118
Thanked: 302 Times
If any body can help getting the part, that will be great.
Old 10th October 2016, 13:22   #119
Cj3bDog's Avatar
Thanked: 36 Times
Please try Tilak (Spoke wheel Alignment) at Gali No. 25 Nai Wala Karol Bagh. You can call him at 011 28753951
Cj3bDog is offline   (1) Thanks
Old 11th October 2016, 17:36   #120
Thanked: 302 Times
Thanks for your help and concern but just two days back I purchased a new set of rear drum. Although I just wanted to purchase Rajdoot embossed drum brake plate but since the dealer had only one set, he was not willing to sell it loose. So I had to purchase both.
The dealer is going to send the item today, hope it reaches me in good shape, till then fingers crossed.
I will post pics of it as soon as it gets delivered to me.
