Old 15th November 2012, 07:52   #211
Thanked: 885 Times
Re: Land Rover support group!
Originally Posted by Collector View Post
MM XD 3 P,is this the Peugeot engine that came with the Commander,MM540,550 etc???
Its a 2.5 engine , AFAIK it came mostly in the 550 & later models . Commander & 540 had the XDP 4.90 ( 2112 cc ) engine , You can find as many details in the 4x4 section of the Forum
KMT 90 GB How many gears??? I would like to use the GB that comes with 5 plus reverse.
KMT 90 has 4 forward & 1 reverse gear , its a Rugged & easy to repair GB ,you dont need a 5 forward GB for a vehicle like LWB Landy
And would the final drive gears in the land Rover differentials suit/be correct for the GB?Transfer case??
Difficult Question
Land Rovers (old ) were mostly 4.7 : 1 , the same engine GB configuration had these ratios with 6 x 16 & 7.00 x 16 & 7.50 x 16 tyres , Now you can assume that the engine can cope with variety of ratios ,but its a LR engine .
I have and would like to retain both the original differentials and mate them up with an engine of sufficient capacity
Good Idea ,Try it out with MM Engine & GB first
. I have sufficient experience of repairing and restoring to original specs but very little experience on such modifications.
God Bless - may gods shower you with lots of patience
What is your [and other gurus, as far as I am concerned anybody who knows something I do not IS a guru to me!!] take on the DI engines from MM??? and do they fit with the above mentioned GB??
they will fit & run but wont come cheap
I will advice you to closely observe the Land Rover specifications about Engine torque figures , gear ratios ,axle ratios & tyre sizes , that will provide you some insight before you go in any modifications
Sudarshan
Sudarshan is offline
Old 15th November 2012, 12:48   #212
Thanked: 448 Times
Re: Pics: Vintage & Classic cars in India
Some pics of cars spotted over time. Hope this is the right thread.
regards,
Srinand.
Last edited by karlosdeville : 15th November 2012 at 14:39. Reason: Moving to correct thread.
srinand is offline   (2) Thanks
Old 6th January 2013, 22:05   #213
Hi everyone! just to let you know that after several years of passionate ownership, i'm selling my Series 3 109 SW. Check out the classified section.
She'll be missed. Thanks for looking!
fandeland is offline
Old 7th January 2013, 14:30   #214
r_nairtvm's Avatar
Thanked: 2,625 Times
From what can be seen of the chassis and the wheelbase/track I think that what you were told is most likely to be true.
Though why anybody would something like that is beyond my comprehension!!
Hi Collector,
You know that the body of the Landrover is made of Aluminium and doesn't rust at all. So someone with arusty Gypsy would have thought to transplant the body of the LR. So he will have a mechanically sound vehicle with a body that will not rust
My Logic
Best Regards & Drive/Ride Safe
Ram
r_nairtvm is offline
Old 11th January 2013, 14:09   #215
Thanked: 4,668 Times
I am interested.
I see that you have converted it to soft-top.Can it be converted it to hardtop again.?
Waseem.
SILVERWOOD is offline   (1) Thanks
Old 12th January 2013, 09:20   #216
Thanks Waseem, I sent a pm.
Absolutely, hard top and soft are easily interchangeable. Only few bolts and nuts and everything is with the car. Actually LR never made factory built 5 doors series or defenders for that matter with a soft top. This is a unique conversion can give the benefit of enjoying good weather and scenery in a LEB 5 doors Land. A must!
Old 12th January 2013, 09:50   #217
Thanked: 885 Times
& the rubber jointing in between ? dont forget to put that in Body Joints
Interesting finding , but are you sure abt this ?
Sudarshan
Old 12th January 2013, 12:52   #218
Thanks for the info.
But i did not receive any PM.
Waseem.
Old 12th January 2013, 15:55   #219
Sudarshan
Oh yes rubber gaskets, they are there! However who has ever seen a water proof Series?!?��
Ref. 5 doors soft top, I'm pretty sure about but I could be mistaking. SV department might have done some one off...
Waseem.
Tried but couldn't for some reason. Send me one if you can. Thanks
Last edited by karlosdeville : 12th January 2013 at 21:09. Reason: Consecutive posts
Old 11th March 2013, 12:05   #220
catchkumar's Avatar
Thanked: 50 Times
Found These LR Series III Lightweight brochures on the net.
Hope this will be useful for the forum.
catchkumar is offline   (3) Thanks
Old 18th March 2013, 11:14   #221
Thanked: 46 Times
Hi, Could anybody please recommend a person/place in India or the UK from whom/where I can source some suspension spares (eg bushes, shockers, tie-rod ends etc) for my 1984 Range Rover Classic? I changed those about 12 years agao and its time for another change now. Many thanks, Sarojesh
sarojesh is offline
Old 18th March 2013, 11:34   #222
Thanked: 885 Times
In this very thread here ;
http://www.team-bhp.com/forum/post-w...ml#post1927995
Sudarshan
Sudarshan is offline   (1) Thanks
Old 18th March 2013, 12:02   #223
Prithvi's Avatar
Thanked: 26 Times
A great Sunday off roading with friends
Prithvi is offline   (2) Thanks
Old 18th March 2013, 12:55   #224
Hi All,
Have been following this thread keenly... and off late I was able to pick a Land Rover Series III 1973 model.
It is currently running on a Isuzu 2.4D with a 4 speed gearbox. I am interested in restoring the car here in Chandigarh and would need the Guru's advice on the following:
I am pondering over a couple of options the first one is to fit an original Diesel 2.25L Engine along with the gearbox, which came standard with this car. Any idea from where I would be able to source it from?
The second option is to source a 200tdi or a 300tdi engine again I am not sure from where I can get it. I understand the import route for second hand spares is not a possibility. Was wondering if it can be sourced from India.
The third option is to put in a suitable engine which is easily available in India, For this I would like to know which engine and gearbox is best suited for the Landie. I understand this option is not my priority as I am more interested in sourcing originals but this would be my last resort.
I look forward to hearing your expert comments.
Gobind
gpsbrar is offline
Old 18th March 2013, 14:05   #225
Originally Posted by gpsbrar View Post
Hi All,
Congrats.This must be Alban's Landie for sure.
Waseem.
