Old 10th August 2022, 19:37   #2041
earthian's Avatar
Thanked: 2,131 Times
re: Home Construction / Makeover / Maintenance Thread
Originally Posted by whencut86 View Post
Ask for Moroccan/Spanish designer tiles and not specifically for Athangudi tiles. You will get lot of options and designs. These tiles are available from Rs.40-50 per SqFt.
Could you give me a link? And yes, we did not ask for Athangudi tiles here. Cement tiles in terracotta colour.
earthian is offline
Old 10th August 2022, 20:13   #2042
Thanked: 1,017 Times
Please see options below. You can call these guys to see if they will ship to your place.
https://mytyles.com/floor-tiles/kitc...ccan-tiles?p=1
whencut86 is offline   (1) Thanks
Old 10th August 2022, 21:06   #2043
Rocky_Balboa's Avatar
Thanked: 407 Times
Originally Posted by deehunk View Post
Tata Steel doors can be a good option, availability in Bangalore should not be a problem.
https://www.tatapravesh.com
Thanks for the points, deehunk; will explore these before finalizing.
Originally Posted by saisree View Post
Seasoned Teak wood is costlier and a hand made door with frame might be close to your carpenters quote. I would recommend accepting his quote on a condition that you are able to confirm the wood is actually Teak.
Thanks saisree, will verify if going the wood way.
Rocky_Balboa is offline
Old 10th August 2022, 21:59   #2044
Sran's Avatar
Thanked: 2,256 Times
Originally Posted by Rocky_Balboa View Post
Hi Everyone,
I am looking to replace my house' Main Door and Frame (age has caught up), and specific about Teak doors. I have a quote, from my local carpenter, of 70K for handmade door including fitting charges.
I have no idea if this is a fair estimate (standard main-entrance single-door), or if there are better options out there.
Can You please suggest.
Thanks.
Teak in my city costs 3800 Rs/cft. If you door is 4 feet wide × 7 feet height × 1.5 inches thick, it would come around 4 cft and depending upon thickness and design it may be reduced or increased. The frame if built on Sakhua(sal) wood be around 1.8 cft @ 3200 Rs/cft.Take another 5000 Rs for labour and 5000 Rs for polishing. Why don't you go to timber and check rates yourselves.
Sran is offline   (2) Thanks
Old 11th August 2022, 13:36   #2045
earthian's Avatar
In the chat option, the instant i said that i would like the tiles at Ahmedabad, they said- no service!
Maybe they had a bad experience with Amdavadis.
earthian is offline   (1) Thanks
Old 11th August 2022, 13:39   #2046
Thanked: 407 Times
Thanks Sran, this will be of immense help; will check this out if going custom way
Old 11th August 2022, 13:55   #2047
Almost all major tile brands have a moroccan/spanish design collection in their range. You can check with these. A lot of local brands also had these designs.
Old 17th August 2022, 21:49   #2048
rajivr1612's Avatar
Thanked: 1,023 Times
Guys, I am planning to run a LAN cable along the area where the floor meets the wall for a short run. To hide this cable is there any strip/decorative strip available?
rajivr1612 is offline
Old 3rd September 2022, 08:10   #2049
condor's Avatar
Thanked: 16,889 Times
Guys, need suggestions/contacts for installation of a pigeon net for our balcony.
We had one, and the net has snapped in the corner. The thin nylon 'rope' has also snapped. Want something that is durable.
TIA
Decorative - no idea. We used to use the flat white casing/capping that is available in electrical shops, but this will be about 1 inch wide. Do you want to go with this ?
Old 3rd September 2022, 09:32   #2050
rajivr1612's Avatar
Thanks.
Yes, didn't find any decorative casing.
Went ahead with the usual 3/4" white casing.
Old 3rd September 2022, 13:04   #2051
HTC
Thanked: 1,385 Times
Try this contact : prakash - +91 81839 88717
HTC is offline   (1) Thanks
Old 3rd September 2022, 14:22   #2052
condor's Avatar
Thanks, @HTC. Called him. He doesnt do pigeon nets, but only mesh for windows.
condor is offline
Old 3rd September 2022, 15:01   #2053
deehunk's Avatar
Thanked: 3,288 Times
Infractions: 0/1 (5)
@condor, I suggest invisible grill for pigeon menace. It is almost invisible, zero maintenance and provides security. I have shared a photo from my apartment.
Home Construction / Makeover / Maintenance Thread-screenshot_20220903150012_chrome2.jpg
deehunk is offline   (2) Thanks
Old 3rd September 2022, 22:59   #2054
Thad E Ginathom's Avatar
Thanked: 29,983 Times
This is the first time that I have heard of a Condor having problems with pigeons!
More seriously... How does the invisible thing deter them, if they cannot see it? How does that work?
Thad E Ginathom is offline   (3) Thanks
Old 3rd September 2022, 23:33   #2055
deehunk's Avatar
The invisible grill neither allows the pigeon to come inside nor to sit on the grill, this grill is formed by rolling steel wire with a minimum spacing of 2 inches.
deehunk is offline   (1) Thanks
