Originally Posted by V.Narayan Oh my God. Your knowledge down to tail fin numbers is quite amazing. |
I have a full serial number list of almost all IAF fighters till date. I can't share it here or else the IAF would come knocking at my door, considering their orders to censor aircraft serial numbers in photos(new).
Originally Posted by V.Narayan Can you re-check this. The early direct supply aircraft had two pylons only and the first 6 pilots trained (including Dilbagh Singh, later CAS and Denzil Keelor) gave feedback on the need for a gun and need to carry it along with the fuel tanks and 2 AAMs. That led to the FL which fought in 1971 and those for sure had 4 pylons with the 23mm gun pack neutralizing the centre pylon, the wing inners used by the Atolls and the wing outers carrying the drop tanks. |
The first six pilots sent to the Soviet Union in 1963 to train on the Type 74 MiG-21F-13, which already had an internal gun, were: W/C Dilbagh Singh, S/L MSD Wollen, S/L S K Mehra, F/L A K Mukherjee, F/L H S Gill, F/L A K Sen, F/L Denzil Keelor and F/L B D Jayal.
No. 28 Squadron aptly named the First Supersonics, formed in 1963, curiously had two different generations of MiG-21 - the first generation Type 74 MiG-21F-13 and the second generation Type 76 MiG-21PF.
The Type 74 MiG-21F-13, shown below, was a daylight interceptor without radar, armed with one one or 30mm NR-30 cannon, IR missiles or rocket pods/bombs on two wing pylons.
Internal NR-30 cannon on the starboard side:
The Type 76 MiG-21PF, shown below, was a Radar equipped all-weather interceptor, armed with missiles on two wing pylons only. It did not have an internal cannon like the Type 74 nor was it wired to carry a gunpod. Like the Type 74, the PF could carry IR missiles or rocket pods/bombs on the two wing pylons.
During one CAP mission flown in the 1965 war by S/L MSD Wollen on the Type 76 MiG-21PF , he was chasing a PAF F-86 at low level when he fired both his K-13s at the fleeing Sabre, both failed to track and missed. Frustrated, the IAF pilot wanted to ram the Sabre with his MiG but better sense prevailed. Had he been flying the Type 74 that day, he surely would have shot down the Sabre using his cannon.
It was experiences like these that the IAF passed to the Soviets for a need to install a gun on the MiG-21. The MiG-21FL thus came wired to carry the GP-9 gunpod on the centerline but they had problems with gunsight accuracy until it was solved much later by using the Gnat's gunsight on IAF MiG-21FLs.
Sadly only two ex-IAF MiG-21PFs survive today and I was able to correctly identify it as a Type 76. It was earlier wrongly labelled as Type 77 MiG-21FL and I consider the correct identification as an achievement
Link
The Type 77 MiG-21FL(shown below) was basically a MiG-21PF but different and larger Fin type with a brake parachute container. Centerline (detachable) GP-9 gunpod are visible
As for the four pylon Type 77 MiG-21FL [what we call MiG-21FL(Late)], here's the story :
A number of FL airframes were sent into storage in the mid-70s as the new Type 96 MiG-21M & Type 75 MiG-21bis variants were being introduced into service. These aircraft were pulled out from storage again in the late-80s and retrofitted with two additional hard points under the wings. I am really not sure how true that story is because three MiG-21FL squadrons (Nos. 3, 4 & 45) converted to the MiG-21bis. MiG-21M & MFs went to former Hunter & Su-7 squadron(No.7,17, 101, 108 & the lone oddball 35 squadron which was formerly a Canberra squadron).
Also early 1st & 2nd gen MiG-21s(F/F-13/PF/PFM/PFS/FL) I believe could not carry drop tanks on the wings, they could only carry it on the centerline station.
Even during the 1971 war, IAF MiG-21FLs were flying with only two wing pylons. Here's an article which a MiG-21FL launched two K-13s at a PAF Sabre Mk.6 but both failed to track. On the centerline station he was carrrying a drop tank instead of the gun(for range considerations)
Wish I had a Gun!!!! Quote:
On 4th December 1971 I was detailed to escort a strike mission of four aircraft equipped with 57mm rockets led by the Squadron Commander Wg Cdr B K Bishnoi (Bhoop). My number two for the mission was Flt Lt David Subaiya (Dadoo). Our aircraft were equipped with two K-13 infra-red homing missiles, one under each wing and a single long range fuel drop tank under the belly of the aircraft.
Even Arab MiG-21PF/PFM/FLs suffered against Israeli jets because of lack of an internal gun.
