BA added to Ikon 1.6 Ok Guys! Here goes my tale of my experimentation with adding BA to Engine Oil in my Ikon 1.6 2002. Now run 1,05,000kms. done on saturday night.
Details First:-
1. Engine Oil : Castrol Magnatec semi-synthetic 10W40.
2. Engine Oil capacity : 4.5ltrs.
3. Engine Oil 400kms used after put in fresh in service two weeks ago. New Ford OEM Oil Filter.
4. Amount of BA used 95-100gms approx. mixed with 500ml of Castrol Magnatec.
5. BA bought off the shelf from a chemist, pure BA (as per the packaging and mark by IPA-full for Indian Pharma Association or something like that.)
Took the oil and BA and mixed it in a 2ltr bottle of COKE. Me and my friend took turns shaking the bottle vigourously for half-an-hour, as the BA was in powder form and in very minute particles i did not feel the necessity of an electric mixer, the powder was very slippery when i took a pinch and rubbed it to feel any solid granular particles and to ensure uniformity of texture.
Then drove about 6kms to a CNG station to fill up and we decided that we will run the engine/car for 100kms continuously after adding the mixture. Since it was my car we decided that my friend will drive for 50-60kms so that when i take the wheel, i should feel a difference if at all there was any.
So after CNG was filled then we added the BA-Engine Oil mixture to the hot engine(as suggested by FT.) Then we took off for the Greater Noida Expressway at 9:30pm.
Started off with cruising at 80kmph-120kmph and then gradually building up speed to 150kmph and also stopped(with the engine running and A/C on all times.)to answer natures call and smoke a couple of cigs. Then i took the wheels and decided to do a 0-top end run as it was past 10:30pm and very few cars were on the road, but i was a little cautious so i was shifting at 5000rpms and took the car till 170kmph, A/C off. Then gradually settled down at an 80kmph cruise due to a number of trucks and vehicles in front.
Initially i did'nt feel any difference, maybe because when i drive at that speeds i am just concentrating on the road ahead and frequently gaze at the rpms and temperature and dont have time to notice anything else apart from these. But when i settled down to an 80kmph cruise which went on for quite some time, i noticed that engine felt sort of lighter, less stressed, as if little effort was required for it to run. And this became more evident when we headed back home when vibes were a little less than before.
But i was'nt convinced and thought maybe the car was run for so long and i was driving for such a long time that i was not able to make out any difference or maybe there was no difference at all. But i had gone out with a very neutral attitude before doing the experiment and thus didnt expect anything specific out of it.
The engine was put through all that one would face on a daily drive and a bit more.
1. 65% Highway 35% Traffic
2. From a crawl in traffic, to cruising at 60-80-120kmph, to high-speed runs of 150-170kmph.
3. Total distance covered 135kms after adding the mixture.
4. Engine ran non-stop during the above covered distance with A/C running all the time except for the 0-170kmph run.
Next day(sunday) i got up and headed straight for my car hoping that the car would start and that i didnt screw the engine.
To my surprise the car was noticably quiter and vibes were lesser that before, on running the car i did feel a difference, being that the engine was smoother than before, till 80kmph 4th gear, the car was much smoother and slilent than before.
Now the car has run 200kms since the BA mixture was added. Went to Ford today to change the Oil Filter but they had too many cars at hand and could'nt do it. So hopefully i can get that done tomorrow.
Few things that i noticed:-
1. BA is heavier than oil and not sluble in oil so it did settle down in the plastic bottle after a while if left alone, even after shaken vigourously. But hopefully BA when turned to Boric Oxide will stick to metal.
2. If incase the reaction of BA turning into boric oxide is not taking place then atleast BA is increasing the lubricating properties of the base lubricant which would explain the reduction in vibes and smoothness in engine running.
3. Removing the filter will tell the rest i.e if there will be white gooey stuff coming out of it or carbon deposits comming out of it. So lets wait for that.
3. Then changing the engine oil and getting similar results will also explain if actually BA worked or not because if it didnt then there would be white/creamish deposits with the oil and if it worked then there should be carbon deposits in lumps.
4. One should not expect a heap-load of difference in performance but yes difference is noticable.
5. Running temperature did not change before and after the experiment.
So to sum things up, mixed results as of now but hopefully as FT suggests, the experiments shows results as the engine clocks more kms.
I will keep updating, and i request that all the people who have tried it to keep updating on the results time to time. |
