Old 25th May 2015, 17:56   #1111
devrajman's Avatar
Thanked: 118 Times
re: OBD (On-board diagnostics) for Indian Cars
Originally Posted by nijelj View Post
Hi Guys, Can someone with a Wifi enabled OBD scanner,in Bangalore, let me know if I can check out to see if it works on my laptop. Please PM me your contact, I'll get in touch with you. Thanks!
PM'ed you my details.
devrajman is offline
Old 25th May 2015, 19:59   #1112
cs_rajesh's Avatar
Thanked: 325 Times
hi
perhaps you can inform over a reply on the forum and others like me could benefit from the information. I am as well looking for OBD and wifi would help
regards
Rajesh
cs_rajesh is offline   (1) Thanks
Old 25th May 2015, 20:17   #1113
devrajman's Avatar
Thanked: 118 Times
Originally Posted by cs_rajesh View Post
hi
regards
Rajesh
I asked for PM as he wants to try WiFi in blore at someones place
No info asked by him to reply on forum
Old 26th May 2015, 06:56   #1114
BenjiRoss's Avatar
Thanked: 1,330 Times
My mini ELM which I bought on eBay worked for six months and went kaput. The green light never comes on.
BenjiRoss is offline
Old 26th May 2015, 13:55   #1115
amitpunjani's Avatar
Thanked: 109 Times
I recently installed ELM 327 in my Sx4 2012 and paired this Samsung Tablet using Torque application. There is no issue in pairing, but unfortunately all the readings of various parameters are not being communicated to the app. Even tried, fun2drive, but only reading for Engine RPM, Coolant temp, speed are visible. Even the turbo boost reading is not appropriate. There seems to be considerable lag b/w the engine working and readings. Any thoughts?
Amit
amitpunjani is offline
Old 26th May 2015, 14:55   #1116
devrajman's Avatar
Thanked: 118 Times
Do check with ebay vendor, some have 6months warranty and can be replaced
devrajman is offline   (1) Thanks
Old 26th May 2015, 20:22   #1117
BenjiRoss's Avatar
I've dashed off an email to the seller. He is still selling the stuff. I hope he offers a refund.
Old 27th May 2015, 15:12   #1118
nijelj's Avatar
Thanked: 412 Times
Originally Posted by amitpunjani View Post
I recently installed ELM 327 in my Sx4 2012 , but unfortunately all the readings of various parameters are not being communicated to the app. Even tried, fun2drive, but only reading for Engine RPM, Coolant temp, speed are visible. Even the turbo boost reading is not appropriate. There seems to be considerable lag b/w the engine working and readings. Any thoughts?
I'm answering assuming the SX-4 uses the same communication protocol as the Ritz. The Ritz uses the K-Line protocol, which is slower than the CAN protocol. That could explain the lag. Regarding visible measurements, it might be because Maruti did not want too much data to be read out in the conventional way.
nijelj is offline
Old 3rd June 2015, 11:09   #1119
Thanked: 44 Times
Hi
Guys, I recently got a ELM327 mini OBD2 connector for my Ciaz. Now the problem is the adapter connects fine however the app is stuck at looking for a protocol and there is some random code that it's trying to read. I tried everything but no luck.
Can you guys help me out? Thanks
gargashwin06 is offline
Old 4th June 2015, 12:03   #1120
Thanked: 107 Times
All you knowledgeable folk out there,
Being pretty ignorant about a lot of stuff being discussed here I have a few queries:
1) I have a 2011 Toyota Etios (V-Petrol) - where do I find the OBD 2 port in this car? I believe this car has one since I had read an earlier post confirming this.
2) Which would be the best scanner for this - Elm 327 or Scangauge?
3) If Elm 327, does it always have to be linked thru Blutooth to an Android device for reading off the parameters or is there a model with an attached display?
4) Would any of the above give me readings wrt fuel for a) distance to empty b) average fuel consumption
5) Lastly, can any of these or other similar devices be sourced locally in Bangalore or alternatively who is the best online supplier and at what cost?
Many thanks in advance for a quickish reply!
sudsan is offline
Old 4th June 2015, 14:59   #1121
Thanked: 21,411 Times
It is above the accelerator pedal area, near the drivers right knee behind the dashboard. Bend down to see it exposed.
I recommend the ELM 327. Been using some 4 years! Reliable and not a battery drainer.
There are choices of Bluetooth one or USB type that get connected to your laptop.
Attached display not available. If you want a stand alone type - but a cheap android tablet and get the ELM 327 paired permanently.
A) Doesn't work
B) Yes it does give out data on Average FE.
BHPian Devrajman is in Bangalore where you can source it from him and that is his handle on Team-BHP.
a4anurag is offline
Old 4th June 2015, 15:57   #1122
Thanked: 107 Times
A4anurag - many thanks for your quick reply. Much appreciated.
Devrajman - If you get around to reading this how do I source this from you? (I am unable to PM Devrajman being a 'newbie' on this forum and not entitled to the privilege!)
Perhaps some kindly soul could do so on my behalf! Thanks in advance !
sudsan is offline
Old 4th June 2015, 17:43   #1123
I have sent him a PM.
BTW, which car are you looking to buy the OBD reader for?
a4anurag is offline
Old 4th June 2015, 20:07   #1124
Thanked: 107 Times
Many thanks a4anurag.
Like I'd mentioned in my earlier post it's for my Toyota Etios (2011-V-Petrol).
I hope the ELM 327 is compatible with this car!
sudsan is offline
Old 4th June 2015, 20:38   #1125
Oops, sorry, I forgot it.
I hope it works as I have seen that Toyota cars aren't friendly with the ELM 327. Do try it out before purchasing.
a4anurag is offline
