Old 15th March 2023, 22:08   #91
Kosfactor's Avatar
Thanked: 11,215 Times
Re: Engine Oil Additive
Academic question.
This is a modern and powerful, superbly responsive, exceedingly well tuned engine.
LiquiMoly Ceratec is supposed to enhance smoothness and reduce noise. And indeed I can feel the difference.
Is there some evidence to suggest that LiquiMoly Ceratec is detrimental in some way?
And for that matter since Mahindra recommends only semi synthetic oil, is using fully synthetic oil of the same grade, going to create any headaches?
Usually when you change to a thicker oil , engine tends to quiet down a bit especially at cold start. If you assume that is what this additive is doing that is changing the viscosity of the oil - it's not necessarily a good thing because engines are designed to operate with a certain type of oil, especially the one they have tested the engine with. This could cause sludge but then I am sure this company would be marketing something to 'Flush' it all down the pan.
Given the advanced engine design and tight tolerances , oil is not just for lubrication but also for cooling certain parts of the vehicle which once again makes viscosity crucial for best performance in that case.
I could be completely wrong , but then the owners manual tells you not to use any additives anyways , so there is that.
Given your time spent in the hills , Mahindra is a life line there, it's a hardy, reliable machine, let's keep it that way.
Kosfactor is online now
Old 4th April 2023, 14:18   #92
Thanked: 31 Times
Just bought a VW virtus gt 1.5 tsi. Was going through the owner manual and found out that I'm not supposed to add any oil additives. Can I use one of those engine oil flushing compounds at least? When changing oil that is..
apramey is offline
Old 4th April 2023, 14:46   #93
Jaggu's Avatar
Thanked: 17,296 Times
Adding a flush should not be an issue, but do wait for at least 10-15k kms, before that it maybe pointless. Also this will give you an opportunity to baseline engine performance and consumptions.
Jaggu is offline
Old 4th April 2023, 14:53   #94
condor's Avatar
Thanked: 16,889 Times
Just bought a VW virtus gt 1.5 tsi. ... Can I use one of those engine oil flushing compounds at least? When changing oil that is..
Why do you want to add the flush ? How much has the car done / are there any issues with the car ?
As long as the car has been serviced at VW, I dont see a need for flush. Only do it IF the manual says so.
condor is online now
Old 4th April 2023, 15:08   #95
Kosfactor's Avatar
No oil additives, no fuel additives, no engine flush - normal servicing is all that it needs.
You can spend the money on Petrol and explore the vast expanse of a country that we live in.
Old 4th April 2023, 19:46   #96
Thanked: 31 Times
Thanks a lot for all the replies. I was of the impression that adding fuel additives right from day 1 will keep the injecectors and valves and fuel lines cleaner.. i was of the same impression about engine oil additives.
apramey is offline
Old 5th April 2023, 07:49   #97
Thanked: 31 Times
The car has done just over 300km now. Got the delivery on 31st March. I read somewhere that during the first 1000km, there will be lot of carbon and metal shedding into the engine due to the run in process. Thus an oil change at 1000km will be ideal. That's why I was enquiring about the flush and oil additives. The manual says don't add any additives, i don't understand why.
apramey is offline
Old 5th April 2023, 14:56   #98
condor's Avatar
The car has done just over 300km now. Got the delivery on 31st March. I read somewhere that during the first 1000km, there will be lot of carbon and metal shedding into the engine due to the run in process. .
This was applicable to engines in old times. Today's manufacturing has come far beyond all that. Just stick to scheduled and recommended service, and your car will be good for a long long time. Flush is more to clean old oil that would have kind of become sludge-like when used for too long without being changed as required.
condor is online now   (1) Thanks
Old 5th April 2023, 16:00   #99
svsantosh's Avatar
Thanked: 8,053 Times
The car has done just over 300km now...
As long its a MMHT you can do whatever you want. Because even if you make a blunder it wont cost a arm or a leg to put it back together or you can even convince the warranty out of the A.s.s.
But the Germans, European cars (VW, Skoda, any other from that region) are waiting for some opportunity to decline warranty on an otherwise well engineered product. By bad luck if an out of warranty repair occurs you wont get the spare in local Mysore shops or even in JC road area of Bangalore. Lets just say it is difficult not impossible. That is why other than petrol dont put anything else inside the car for such brands.
PS MMHT...
Maruti
Mahindra
Hyundai
Tata
EDIT
Then please dont, also re-read the whole manual as to what you can do and not do.
svsantosh is offline
Old 5th April 2023, 22:53   #100
Thanked: 3,584 Times
One thing that nobody tells you: Your car cannot run with a flush inside the engine. That is, you cannot drive your car with it.
Reason: It is not a lubricant, it is a dispersant, which should be used on a static engine for a very short duration let's say 10 mins of idling.
Now the question is, why should we add something that is detrimental for the engine?
Here, the believers believe that the benefit of using it supercedes the risks it carries (especially for a sludged up engine).
For a healthy, already clean engine, the risk of using a flush is huge. Do not go that way.
Regarding your metal shavings in oil concern, yes, they are present, but flush will not do anything to these metal shavings. If used excessively, it will only increase them!
Flush is designed to emulsify sludge, disperse it into the oil and then when you remove the oil, it eliminates from the engine.
I am fond of researching oils and flushes and found that flushes contain the same dispersant which are present in engine oil, but at a much higher level, making them unsuitable for the engine. For me, the best flush designed for the engine is the engine oil. If in doubt, replace it more often (please consider environmental impacts also while doing it, be rational)
Baby shampoo is good enough for the infants, don't use adult shampoos on them, baby hairs are already clean and quite vulnerable.
MT_Hyderabad is offline   (1) Thanks
Old 5th April 2023, 22:58   #101
Thanked: 31 Times
Makes sense. I guess I’ll ask around about the fuel additives in the fuel additives section before going that way.
Last edited by Axe77 : 3rd June 2023 at 20:32. Reason: Trimming quoted post and fixing caps.
apramey is offline
Old 2nd June 2023, 19:44   #102
Thanked: 153 Times
I put 300ml LiquiMoly Ceratec into my Thar Petrol engine. The already smooth and silent petrol engine has now become whisper soft and buttery.
I also poured 300ml of Ceratec into my Gypsy. The smoothness of the engine that Ceratec imparts is unbelievable.
And 300ml of Ceratec into my 11 year
Old Cooper. Amazingly smooth response!
Did you add ceratec during oil change or midway?
If during oil change, did you do engine flush also?
yadavsid21 is offline
Old 2nd June 2023, 20:22   #103
Thanked: 27,232 Times
Infractions: 0/3 (13)
I added the ceratec just after pouring the requisite oil in the oil change. I reduced the oil by 300ml so as to accommodate the ceratec.
I did not do engine flush and havent done it for any of the cars. Mine are all older cars now. I wont take a chance with engine flush for fear of dislodging or further degrading some old seal inside the engine.
shankar.balan is offline   (2) Thanks
Old 8th March 2025, 20:12   #104
Thanked: 1,267 Times
How is your experience with Ceratec going? What schedule are you following? Did you still recommend it for petrol engines?
SilverSmoke is offline   (1) Thanks
Old 9th March 2025, 21:35   #105
I use Liquimoly Ceratec once a year in my 2012 Mini Cooper S along with its oil change.
Typically I do no more than 6000-7000kms running in a year in that car. It has now run around 70150kms all in all so far.
I prefer to follow the time led oil change schedule rather than the kilometres led one.
This last service in November 2024, I have used Liquimoly Moly Gen oil 5W30 and a can of Ceratec and the engine is running very softly and smoothly indeed.
With every tankful of petrol that I fill in my Cooper I also add one can of Octane Boost - either Proctane EVO or STP.
Yes, I endorse the fact that these products are good, basis my experience with them.
