Old 5th October 2007, 10:54   #136
BlackPearl's Avatar
Thanked: 17,377 Times
Originally Posted by 1100D View Post
Nothing will happen to the exhaust per se, but the cat-con might be suspect. I dont think Insurance will cover the catcon totally. I guess BP can provide the cat-con, in most probability he is running without one!
yes, my car is running wihout the cat-con...
BlackPearl is offline
Old 6th October 2007, 11:25   #137
shuvc's Avatar
Thanked: 359 Times
Originally Posted by BlackPearl View Post
if something has gone wrong about the exausts then dont worry, I have the entire stock set at my home, you can take it anytime.
Oh great. Thanks a lot.
Will be going to the workshop today and was wondering.
The car has run close to 24K kms. The brake pads soaked in water for > 72hrs. Should I change the brake pads? How much do they cost?
The service engineer said, no need. I said I want the brakes to be good, allowing me to come safely to a stop from say 140 . He still said, no need.
I'm still wondering ... any inputs?
shuvc is offline
Old 6th October 2007, 11:43   #138
Jaggu's Avatar
Thanked: 17,299 Times
rear break pads better to change, front liners will survive. also bleed the complete brake circuit and clean all the cylinders and replace the rubber cylinder kits (get repair kit as it is termed)
Jaggu is offline
Old 6th October 2007, 15:03   #139
nitrous's Avatar
Thanked: 333 Times
U mean rear liners will need change and the front brake pads will survive .
nitrous is offline
Old 6th October 2007, 18:50   #140
planet_rocker's Avatar
Thanked: 426 Times
Pics of the Silver Arrow @ the MASS
"somebody please get me outta here"...
the engine bay:
signs of rust:
no visible damage on the body:
condition of the elektras (RHS front coax) - looks ok IMO but not connected to the amp, HU is disconnected as well:
"jab kharcha hota hai - tab chhappar phar ke hota hai" just kidding - his new possession:
@ mods - imageshack acting up. uploaded it @ photobucket (resized)
planet_rocker is offline
Old 6th October 2007, 22:51   #141
shuvd's Avatar
So, how is the Silver Arrow doing now? Is the Arrow back with the owner?
shuvd is offline
Old 6th October 2007, 23:05   #142
Dude,
one simple thing. Have the car pushed out. Then let it drain for a few hours..make sure it doesnt remain submerged for long otherwise the wiring could start shorting. Invest a bit of money and get all fluids drained and refilled. Also check the boots, relubricate the moving parts in the axle and change the gear oil. Get a good interior clean up and your car should be good as new. I suggest u spare no expense because if the job is not done properly the tell tale signs could crop up in a few years when u goto sell it and people wont offer you a good price. Also replace/clean the headlamp reflectors..that is the first give away sign that the car has gone under water.
Check the tail lights as well. Remember to get it done 100%..i repeat this coz my friends C200 is still undergoing problems after 26/07/2005 in Mumbai!
sudarshansarma is offline
Old 7th October 2007, 01:03   #143
shuvc's Avatar
Thanked: 359 Times
Nopes. Not until another week at least.
As of now the climate control is the only major issue. AC is working fine, however on starting the engine the CC switches on automatically and none of the CC buttons are working. Today the service engineer said he's still not sure whether the root cause for this is the ECM or the CC circuitry. Says, he is unable to confirm since he does not have a spare ECM or a spare CC module. These 2 parts have been ordered for and will arrive early next week. Then after testing, he will change whichever has a problem. He's confident that insurance will cover the expense. ECM costs around 23-25K, CC costs around 14K.
Other than this, as @sudarshan has mentioned, the headlights do look a bit hazy. I might get them replaced with EuroII lights soon after she is back on her feet .. er wheels.
Brakes, oil changes, filter changes etc is planned for Monday.
First test drive is planned for Wednesday, latest Thursday. If all goes ok, cosmetic stuff will be taken care of in another couple of days.
shuvc is offline
Old 7th October 2007, 01:06   #144
BlackPearl's Avatar
all the best. keeping my fingers crossed for the final outcome.
O.T - we will soon be seeing another silver baleno added to the kolkata chapter thanks to vroooooom. 3 balenos not bad to start of a kolkata baleno club, what say??
Old 7th October 2007, 01:22   #145
Zappo's Avatar
Thanked: 2,746 Times
I am not sure but what is this red colored fluid kind of thing that seems to have dried in several places in the engine bay? If they dropped brake fluid accidentaly on the metal parts they may cause corrosion. So be sure to check for that.
Zappo is offline
Old 7th October 2007, 01:53   #146
shuvc's Avatar
Thanked: 359 Times
No worries there I guess. That used to be the Swastika, drawn when the 'car puja' was done 21 months ago
shuvc is offline
Old 7th October 2007, 22:01   #147
razor4077's Avatar
Thanked: 300 Times
Good to see the Silver Arrow on dry ground again! And even better to learn that most of the major components are ok.
Hope to see her up and running soon
razor4077 is offline
Old 8th October 2007, 16:50   #148
Thanked: 426 Times
Off-topic:
the Bangalore Baleno Club is known as BBC and now KBC (Kolkata Baleno Club)
Old 8th October 2007, 17:01   #149
shuvc's Avatar
Thanked: 359 Times
Brief update. Water had seeped into:
# Gear box (Gear oil needs to be replaced. Would anyway have done it)
# Clutch assembly (Clutch pressure plate etc to be replaced - was speaking to @shuvd earlier today that I'm not too happy with the clutch. So there goes, it's going to be changed anyway)
# Cat-con seems fine
No clear idea yet about how much insurance cover I'll get.
shuvc is offline
Old 8th October 2007, 17:53   #150
Thanked: 3,347 Times
Wow...cat con is OK?
See, there is God. And he worries about emission norms too.
anandpadhye is offline
