Old 10th January 2013, 14:54   #4966
Thanked: 9 Times
re: The Tata Safari 2.2L Technical / Problems Thread
i was looking for the safari workshop manual and one of my friend who has a dealership of tata commercial vehicles, promised me he will arrange one for me. i think this can also be used for Safari. once again thanks for sharing the link.
i.1979 is offline
Old 17th January 2013, 19:38   #4967
ankur_gupta10's Avatar
Thanked: 52 Times
My truck is failing Pollution check. I am being told the HSU% is greater than 65. There is no visible smoke, and my engine is also not noisy. Which leaves me very confused.
1. Can the system D i always add cause high HSU?
2. What is this HSU% and what causes it?
3. I have cleaned the air filter also.
ankur_gupta10 is offline
Old 21st January 2013, 14:30   #4968
Prowler's Avatar
Thanked: 1,416 Times
Check with another center to rule out a faulty meter if you really think that the exhaust doesn't contain smoke. HSU is Hartridge Smoke Unit which measures the smoke density.
Ideally you should check the Pollution after the engine has warmed up and reached its normal operating temperature ( your temp gauge should be at the center). Ideally before you check, drive spiritedly at high throttle for a few minutes to 'clear' its throat.
Prowler is offline
Old 21st January 2013, 14:40   #4969
cool_dube's Avatar
Thanked: 4,758 Times
Idle RPM on my Safari fluctuates (approximate range 800-600) for the first few minutes of starting the engine after the car has spent a cold (temp ~5 deg C) night in the outdoors. No start-up issues though - single crank start! No black smoke either! Also, no issues in regular city starts (Bangalore temperature does not go below 10 deg C in any case).
I had told this to TASS when I gave the vehicle for its 3-year service and as expected, I was told that there is "no problem as per laptop diagnosis". Faced this issue again last week. What could be wrong here - clogged injectors? Malfunctioning fuel temperature sensor?
cool_dube is offline
Old 21st January 2013, 15:37   #4970
Thanked: 52 Times
Where do people in Delhi get the PUC certificate without bribing?
Old 21st January 2013, 15:41   #4971
Thanked: 716 Times
Ask them to do injector back pressure test on cold engine. laptop will not show any error code. For this you need to leave the vehicle as it can be done only once in a day. Yes this is due to injectors clogging, Get it done if it is in warranty don't bother if you have to pay from your pocket.
amitk26 is offline   (1) Thanks
Old 22nd January 2013, 13:29   #4972
jaysmokesleaves's Avatar
Thanked: 1,466 Times
Of late I have seen that while turning the steering in parked vehicle, it often jams for a bit. So getting out of parallel parking spots is tough.
Steering damper was changed, but it did not improve things.
My SA is telling me that pump is weak, but if pump it weak why does it only jam at some points. I suspect something "mechanical" is causing obstruction somewhere.
What should I check?
Tanveer, when they replaced my steering box under warranty it initially behaved the say way as you mentioned. they tried a few adjustments here n there but no improvement.
So i gave up on the TASS and continued to drive around. The box has now "freed" itself.
jaysmokesleaves is offline
Old 22nd January 2013, 17:10   #4973
simply_sunny001's Avatar
Thanked: 19 Times
Go to gurgaon, when you go from Iffco Chowk towards malls, there is a Pump on left, get it done there. no hassles
and there must be many PUC booths as i was never even asked for test at any booth, they just took a pic of number plate and gave me the certificate.
30 Rs it used to be when i did last time in 2010.
simply_sunny001 is offline
Old 22nd January 2013, 17:33   #4974
mercedised's Avatar
Thanked: 449 Times
My car steers to right when braking hard, this generally happens when the speed is high and I have to brake hard, the steering shudders and I find it hard to keep the car straight. What might be the problem? The brakes are also feeling spongy, the brake pads are 10K kms old.
mercedised is offline
Old 22nd January 2013, 19:25   #4975
bj96's Avatar
Thanked: 1,554 Times
Originally Posted by simply_sunny001 View Post
...i was never even asked for test at any booth...30 Rs it used to be when i did last time in 2010.
Same here in Pune. They just ask casually "gaadi regular service mein hai na" (car is regularly serviced or not) . However, sometimes I insist them to probe the exhaust to be sure myself. The PUC rate is 120/- here I think (last done ~6 months back).
Originally Posted by mercedised View Post
My car steers to right when braking hard, ... speed is high ...The brakes are also feeling spongy...
Your Safari is a Rightist Jokes apart, usual suspects are alignment, unequal tire air pressure or leak in the hydraulic lines? Check signs of dampness around drain nipple on brake lines.
-BJ
bj96 is offline   (1) Thanks
Old 22nd January 2013, 20:44   #4976
condor's Avatar
Thanked: 16,902 Times
This may not help, but no harm in trying - run the vehicle at higher RPM's for a few minutes. If your normal running is at 2k rpm, then run it at 3-3.5k rpm (can do it by using a lower gear at relatively higher speed).
Try fuel from a different bunk.
THe System-D should not cause a problem.
condor is online now
Old 23rd January 2013, 08:26   #4977
Thanked: 716 Times
But key question is why it is failing emission test? Till now I get emission values far lower then the limit.
amitk26 is offline
Old 23rd January 2013, 09:38   #4978
sierrakamat's Avatar
Thanked: 77 Times
My GRANDE had the same problem was traced to a faulty heater plug after leaving the vehicle with TASS for 5 days.
This fault was not diagnosed on the laptop and before that they had tried to sort it out by replacing the injectors but that did not help.
sierrakamat is offline
Old 23rd January 2013, 12:01   #4979
Thanked: 52 Times
I decided to read all about the HSU% and what it is. It is just an opacity measure i.e. how black the smoke is. The smoke from truck exhaust is not at all black. The smoke is hardly visible, untill i accelerate real hard in 2nd gear. So i think the problem in delhi is rampant corruption, PUC guys want you to pay extra, and hence this tactic of saying that the vehicle is polluting. Best part is that they will not give you the fail certificate either. And incase you agree to pay them few bucks extra, you can have the pass certificate.
Old 23rd January 2013, 12:23   #4980
cool_dube's Avatar
My Safari is under extended warranty
You mean the glow plug?
