Old 18th February 2025, 23:50   #2176
NA-driver's Avatar
Thanked: 120 Times
Re: Maruti Suzuki Swift : Tyre & wheel upgrade thread
Originally Posted by Venue5366 View Post
Please do suggest some good tyre specs for the 15 inches. The ones i have in mind are 195/55/15 and 205/55/15. Also which brands should i go for.
The max you can go for is 195-section tyres, IMO even that's a little overkill for your car. You'll face a heavier steering wheel and might even drop in fuel economy.
There are several good brands available in this size for example - Michelin xm2, Continental UC6, Yokohama S-Drive etc.
NA-driver is offline
Old 22nd February 2025, 17:32   #2177
Got the Honda Jazz 15 inch Oem’s installed in myst swift. Similar to the zdi. Looks a bit more cleaner imo.
Maruti Suzuki Swift : Tyre & wheel upgrade thread-img_9067.jpeg
Venue5366 is offline   (1) Thanks
Old 22nd February 2025, 18:09   #2178
Thanked: 12 Times
The alloys just look like the ZDI alloys great choice.
Get the MS Alloy Wheel center caps and replace the Honda center cap and you are all set.
Prabu
PAL1155 is offline   (1) Thanks
Old 14th March 2025, 20:04   #2179
blackpanther13's Avatar
Thanked: 18 Times
Hello fellow BHPians.
I am looking to change tires on my Swift Zxi 2015 and considering below: (No specific sequence)
1. Conti UC6/CC6
2. Yokohama Earth 1
3. BS Sturdo
4. Anything else
Feel free to add your suggestions and inputs.
NOTE: Currently using Yoko Earth1 185/65 R15y. Mostly city driving with monthly Highway runs for trips.
blackpanther13 is offline
Old 15th March 2025, 02:20   #2180
Thanked: 12 Times
1. Conti UC6/CC6
2. Yokohama Earth 1
3. BS Sturdo
4. Anything else
Hello Blackpanther,
If you like to go for more comfort than Yokohama Earth 1, you can go with Continental UC6/CC6. But please do keep in mind that the cost may be higher than other tyres. If you are looking similar to the performance of Yokohama Earth 1, you can try Bridgestone Sturdo. Both are around same cost and performance is same.
Prabu
Old 16th March 2025, 07:26   #2181
pranjal1984's Avatar
Thanked: 104 Times
1. Conti UC6/CC6
2. Yokohama Earth 1
3. BS Sturdo
4. Anything else
I had driven my Swift ZXI 2015 with UC6 Conti tyres. You will enjoy it. Make sure the manufacturing dates are recent.
pranjal1984 is offline   (1) Thanks
