Old 9th December 2019, 00:39   #31
vaisakhr's Avatar
Thanked: 165 Times
Default Re: Maruti Ciaz : Tyre & wheel upgrade thread
Hey guys,
The stock tires are at the end of their life at 65k. Planning to swap them with some fresh rubber. I prefer soft compounds. Since I have been a fan of P3STs in my swift, wanted to go for 4ST. Sadly its not available in the stock size of the car. Do I have any other option rather than going for the 205 section michelins. Stock is 195/55/R16
Please advice
vaisakhr is offline
Old 9th June 2020, 18:39   #32
itwasntme's Avatar
Thanked: 5,804 Times
Planning to change the stock Ciaz Sigma 185/65/15 tyres from the OEM MRFs to Michelin. Focus is purely on rear seat ride quality & less noise. I am assuming Energy XM2+ is by far the best available in the Indian market?
Should I even think of upsizing? Please note I am on the stock 15" steel wheels and not alloys.
https://www.michelin.in/auto/browse-...sion/185/65/15
itwasntme is offline   (1) Thanks
Old 9th June 2020, 19:59   #33
PrasannaDhana's Avatar
Thanked: 8,327 Times
Trust me, the best choice for less noise and superb ride will be Michelin Primacy 4 ST. I am on the third set of tyres. After stock Apollo 185/65 R15, I replaced to Continental MC5 195/60 R15 , which is an amazing tyre if you are after road grip, although it is a bit noisy. My third set is Michelin P4ST 195/65 R15. You can also opt for 195/60 R15. I chose 195/65 for the 2cm increase in the ground clearance over the 195/60 sections.
You cannot go beyond 195 width as the ciaz 15 inch alloys are 5.5j spec. I don't know about steel wheels though.
The P4ST is totally silent (I enjoyed this fact even today while driving back from a 250km trip) and has very good ride.
PrasannaDhana is offline   (2) Thanks
Old 8th December 2020, 22:53   #34
Thanked: 100 Times
I am planning to change the tyres of my Ciaz zeta from 185/65/15 MRF to Michelin 195/60 R15 . However i want to add spacers so that the tyres are now flush with the wheels much more , from where can i get quality spacers in NCR and how do they affect ride quality and safety of the car ?
drift2race is offline
Old 8th December 2020, 23:02   #35
ptaneja's Avatar
Thanked: 400 Times
Nothing better than this >
https://www.rogermotors.com/productdetail/rogerab-duo
I guess they are available on Amazon too.
ptaneja is offline
Old 8th December 2020, 23:11   #36
Thanked: 100 Times
I am looking for spacers for my wheels
Maruti Ciaz : Tyre & wheel upgrade thread-71y6n0iqdll._ac_sl1200_.jpg
Old 13th December 2020, 12:19   #37
ptaneja's Avatar
Thanked: 400 Times
Guys which one would you recommend for replacing Apollo Alnac4G on Ciaz - 195/55 R16 ( 52k run )
I got the following quotes, would be great if someone can see if these are right ( and ofcourse if you have a known who can give further discount )
Bridgestone - 6500
Goodyear - 5250
Yokohoma - 6400
Ceat - 5400
Apollo - 6800
( Inclusive of balancing / alignment + 400 extra for buy back )
One dealer was very aggressively going for Ceat, and the reason being next day replacement. He said that as far as experience, now a days , Ceat creates the least amount of problems while replacement if need be.
Which of these would you guys recommend ?
ptaneja is offline
Old 13th December 2020, 12:25   #38
Why not Michelin/Continental?
It is available here, even in tier 2 cities.
Old 13th December 2020, 12:28   #39
ptaneja's Avatar
Thanked: 400 Times
No one quoted Michelin ( unless I specifically go to their store / site ) , and for Continental it's almost same as Bridgestone.
ptaneja is offline
Old 14th December 2020, 13:23   #40
ptaneja's Avatar
Thanked: 400 Times
While I am still searching for options, will the following work to replace existing tyres ( 52K kms / 5.5 years )-
195/60 - R16
OR
205/60 - R16
OR
OEM size of 195/55 - R16
The only purpose is to get extra few mm's of ground clearance.
Just dont want a heavy steering/drop in mileage/scraping the wheel well.
Please suggest as 50% dealers are confident that 195/60 will work even with 3 adults and boot full. Rest 50% want to go with stock.
ptaneja is offline
Old 14th December 2020, 14:38   #41
195/60 - R16
OR
205/60 - R16
OR
195/60 R16 will be ideal. It gives you 10 mm increase in GC and won't be heavy on the steering.
205/60 will give you more than 15mm in GC but it will also make the steering heavier and may scrape the wheel well.
Here is a comparison between 195/55 and 195/60
Maruti Ciaz : Tyre & wheel upgrade thread-screenshot_20201214143328.png
I have 195/65 R15 in mine and it has given a good improvement on GC over the stock (185/65 R15)
Old 22nd December 2020, 13:54   #42
Thanked: 16 Times
Can you post the pics of your car with 195/65 R15? I'm due for a tyre change now, and want to upgrade, but the tyre dealer is advising against 195/65. I have lot of issues with regard to ground clearance while driving in Kerala.
PS: Pls check your DM/PM. i have sent you something.
sandeep959 is offline
Old 22nd December 2020, 14:33   #43
Here they are
Maruti Ciaz : Tyre & wheel upgrade thread-img_20200626_093519715_hdr2.jpg
Maruti Ciaz : Tyre & wheel upgrade thread-photo-collage20200101_122756.jpg
Maruti Ciaz : Tyre & wheel upgrade thread-img_20201123_1028457142.jpg
I have completed 25000 km on these 195/65 tyres, not even a single issue. Infact I enjoy the increased ground clearance now.
Only reason why your dealer is advising against the 195/65 must be that he may not have it in stock and he wants to give you the 195/60 which he may already have.
PS: I didn't receive any PM
PrasannaDhana is offline   (1) Thanks
Old 9th February 2021, 12:36   #44
Veelubai's Avatar
Thanked: 61 Times
Hi Prasanna,
Just wanted to check and confirm regarding the practicality of 195/65 R15 with regard to tyre fouling with wheel arches or rear tyres scraping when loaded with 3 adults in the rear on highways etc.
Any issues faced while on full load? Drawing inspiration from your upgrade and finalising on my next set of tyres in 195/65 format.
Here they are
Attachment 2095815
Attachment 2095816
Attachment 2095828
Veelubai is offline
Old 9th February 2021, 12:41   #45
Originally Posted by Veelubai View Post
Hi Prasanna,
Nopes, nothing at all. I have driven it with 4 people on board with over 100 kg weighing books in the boot. Didn't face any problem.
What brand are you going for? Now that Michelin is unavailable, I hear great reviews for continental UC6
