Old 10th September 2008, 11:35   #16
hydrashok's Avatar
Thanked: 18 Times
Getting a sub-driver and building a box for it will be the less costlier option. I think Abhibh's post covers the best VFM option.
If you want a sub-in-a-box, I think the most VFM one available now is the BULL ESW-12 - 12" sub in a ported box. The box will be carpeted and will have the speaker-wire terminals outside. Rs.6700/- if I remember right.
As for cables, you will need a 4AWG power cable (8AWG might also do, but 4AWG is better, considering upgrades), 2 sets of 2-ch RCAs (for a 4-ch amp). Good VFM Cabling can be done in 2.5K, I should think.
hydrashok is offline
Old 10th September 2008, 11:57   #17
cooldude1988765's Avatar
Thanked: 213 Times
Wont a ported box be bigger than a sealed one ?
cooldude1988765 is offline
Old 10th September 2008, 12:16   #18
Thanked: 305 Times
It is for 8.5k approx, Also the sub is 200 watts rms. One can get better options in 8.5k
low_bass_makker is offline
Old 10th September 2008, 14:49   #19
nitin.dangayach
Posts: n/a
Guys trust me, I m totally confused. I cant cross the budget. If the SW itself is 7-8K, and cables demand at least 2K, my budget will get exhausted in these two itself. I need an AMP as well.
Ok getting to the basics, please let me know first that can the said requirement be fulfilled in the said budget ? Since I am sure I can not extend the budget, I would rather wait than going for a compromise on the sound.
The polks have good bass. All I was is to add some groove, some lows. If my budget is less, i'd rather leave the idea of upgrading :(
Suggestions friends.
Old 10th September 2008, 15:22   #20
Thanked: 213 Times
Do you want to add an amp to your front speakers also ?
kenwood/blau/jbl 4 channel 5-6k
pio/jbl/gz sub 4-6k
cables, box and installation 3k
That is about 12-15k
Old 10th September 2008, 15:32   #21
mobike008's Avatar
Thanked: 15,640 Times
pio/jbl/gz sub 4-6k
Don't we always have a solution to overshoot a fella's strict budget?
Even i think Abhibh's recommendation is best. CS1204 is the best value for money boom box. I have the original that comes with the box and it is more than decent in SQ. I got it for about 8K more than a year ago.
mobike008 is offline
Old 10th September 2008, 15:33   #22
nitin.dangayach
Posts: n/a
Ok that reminds me. The current output from my HU is good enough for the rears and fronts.
Can't I then go for a MONO AMP ? I am not sure if it'll be cheaper or not. Just wondering.
ANother cobination can be : Front coaxials on HU and the rears+SW on AMP. I can then go with a good 4ch AMP.
Any suggestions on that as well ? That way we can finalise the requirement.
The front speakers are good enough on the HU. Here are the specifcations for the fronts speakers :
db401 Car Audio Speaker from Polk Audio
Driver ComplementMid/Woofer1 - 4" Diameter (10.16cm)
Polymer/Mica Composite cone with rubber surroundTweeter1 - 3/4" Diameter (1.91cm)
Silk/Polymer composite domeElectricalOverall Frequency Response85Hz-22kHzNominal Impedance4 ohmsPower Handling (continuous)45 wPower Handling (peak)135 wEfficiency91 dB
What do you guys suggest ?
Old 10th September 2008, 15:36   #23
chiragh_bir's Avatar
Thanked: 74 Times
go in for Blaupunkt GT4 Special MKII. excellllent amp!
With B&W it costs 4800/-
more info here
Blaupunkt - Amplifier - GTA-Series - GTA 4 Special Mk II
chiragh_bir is offline
Old 10th September 2008, 15:49   #24
cyclops's Avatar
Thanked: 12 Times
nitin, i'd suggest you first try your setup by adding only an amp. sans any sub. if you still miss the lows, go for a sub..
even i'm planning to get an amp for my setup, but a bit short of moolah and a lot confused in the choices between the three amps, 8401/A-604/GT4 MK2
i've even compiled a comparo of these three amps in the attached pdf..
EDIT: Mods, can we create a separate thread titled "Best Entry level Amp" maybe with a poll and put this PDF there?
Sorry nitin, for going OT..
cyclops is offline
Old 10th September 2008, 16:03   #25
nitin.dangayach
Posts: n/a
WOW thanks cyclops. I am thinking of buying some stuff second hand to keep the cost within limits.
Old 10th September 2008, 16:41   #26
sonic_boom's Avatar
Thanked: 16 Times
If u want to get heavy lows at low volumes get this :
Kenwood/JBL 2 channel entry level amp(3 K)
JBL 12" 3K
Tsunami Kit (No specific idead but definitely under 2K)
(All prices approx and gray)
But beware....don't crank up the volume too much or you might end up embarrassed
sonic_boom is offline
Old 10th September 2008, 21:33   #27
the cheapest option woud be an alpine 4 channel amp i dont know the number but that silver coloured one.pioneer subwoofer or xplod subwoofer in custom made box. this setup is common in our city and bass is sufficient. the amp cost around 3k and the xplod woofer is around 2200 and pioneer is around 3k. all these are grey markit without warranty . but never heard any complaint
you can also exchange these if you want better stuff later on.
harry2223 is offline
Old 11th September 2008, 00:56   #28
rohan_fonseca's Avatar
Would an active sub be reccomended in the budget?
rohan_fonseca is offline
Old 11th September 2008, 09:27   #29
nickoo's Avatar
Thanked: 12 Times
mate..that's the fake alpine and i knw it sells like hot cakes at patiala
nickoo is offline
Old 11th September 2008, 11:03   #30
sonic_boom's Avatar
Thanked: 16 Times
Exactly...genuine Alpine 4 channel for 3K is certainly not possible.
If u just want boom...I guess it's adequate. But once you've hear better ,
you certainly wont go back to "Alpine"....
