35W Hylux Ballasts and 35W 4300K CN Bulbs Installed High Beam Failure Projector replacement
As I have explained in the earlier posts, the high beam in the projectors failed and Lumens Systems replaced the projectors under warranty free of cost.
Though I am very happy with the after sales support of Lumens Systems, being an engineer, I started looking for reason why the projectors failed, and how to prevent (atleast try to prevent) similar failure in the future.
When I had inspected the failed projectors, I found that the shutter mechanism in both the projectors had got stuck. As member sid93 had pointed out earlier, this could be due to the shutter mechanism expanding and deforming due to heat. Maybe the projectors are not rated for 55W HID system. When I looked up the specifications of Mini H1 projectors from Morimoto, (the ones installed in my car are Mini H1 replicas), these projectors are rated only for 35W HID systems. Only the latest v7.0 Mini H1 is rated for 50W HID system. In the many threads on various HID forums, people always suggested FXR projectors for 55W. When I analyzed the quality of the failed projectors, the plastic lens holder, the flimsy shutter mechanism etc further strengthened this theory that the projectors are not designed for a 55W system.
Though the new replacement projectors had a better construction with metal lens holder, and though Vinod of Lumens Systems insisted that these projectors will withstand 55W HID, I decided to play it safe and change to 35W. I had read in the "Best Xenon HID Coversion Kit" that in aftermarket kits, Hylux ballasts are of very good quality and CN Bulbs are the best in HID bulbs. Thanks to member Sam.k, I got the link to XenonPlanet who are located in Chandigarh and deal with Hylux ballasts and CN bulbs. Ordered the below from their website.
Hylux 35W Ballasts - INR 4800 for a pair
35W 4300K CNBulb HID - INR 2100 for a pair
Here I should mention about the excellent customer support from XenonPlanet. I had placed the order and had gone on a 10 day business travel, hoping to see the package when back. But due to some issue with their online ordering tool (not a great tool, I could place the order only on the third attempt), they were not aware of the order and had not shipped them. I messaged them on their FB page, and they responded within 10 minutes. They tracked the order, apologized for the issue and shipped the items by air the same day. I received them in two days after this.
This is what I received. Two ballasts and two HID bulbs
Hylux ballast with 3 year warranty (hope I never need to claim the warranty)
CN Bulb
Replacing the ballasts and bulbs was a straightforward job and took about 30 minutes.
Before I went for the downgrade to 35W some friends advised me against this saying the brightness will be too low. I had read in various online articles that a 35W HID system would give about 20% more light for 60% more power. So, I decided to do some tests to know how much will be the reduction in illumination in 35W. As I did not have a proper Lux meter to measure brightness, I downloaded an Android App called "Lux Meter" from Google Play. This App uses the light sensor in the phone (located near the front camera) to measure light.
Important Note: As the phone's light sensor is not a calibrated light meter, the absolute Lux readings from this app will be meaningless. For example, the meter may show 20000Lux for an actual brightness of 4000Lux. However, as my intention of this experiment was only to find the relative brightness between the 55W and 35W systems, I was not concerned about the actual values. The only requirement was that I take the measurements under same test conditions for both the systems.
I parked the car in my portico and measured the illumination near the hotspots of both the beams that were projected on the wall about 10 feet away. I moved the phone to various points in the hotspot and let the App record the highest value. As I did not move the car between measurements and took the measurements in total darkness in the night, I can now tell the % reduction in light. The results were very interesting indeed.
Below is the screenshot of the App for the 55W system for the left and right lights.
The left light had a intensity of 24523 max and the right 9396. The right side was just 38% of the left side. Ever since the projector installation, I had problems with the right side setup. Once the light completely failed and Vinod replaced the bulb. Even after replacement, I felt that the right side light was dim, but I had never made any tests to quantify this. Just to make sure that my measurement was not wrong, I made several measurements and the outcome was consistent - the right side light was indeed 40% of the left side. Maybe the ballast also was not good.
Below is the screenshot for the 35W Hylux/CNBulb system.
The left side has a max value of 19527 which is 79.6% the brightness of the 55W system, consistent with the information I got online. Also, the left and right sides are closely matched. The right side has a max value of 18876 which is 96.6% of the left side. I think this 3.4% drop could be because of the voltage drop in the wiring harness as the wire for the right side is longer than the left side.
Finally, took the car out for a test ride. It was just after some heavy rain and I found the light to be quite bright and distance visibility was very good as well.
As for the reliability, I will be able to comment only after may be a year of use.
Conclusion: We cannot expect consistent performance from aftermarket components while upgrading to projectors. If you are lucky, you can end up with good performance (like the left side light in my 55W setup). If consistent performance is desired, then we have to go for tested products - for example, Morimoto projectors, Hylux ballasts, CN bulbs etc. Though these may be on the expensive side, you will get the satisfaction of better performance.
PS: I have now ordered a DC clamp meter and a proper Lux meter. Once I get these, I will do another set of tests to compare the current consumption and light output of the 35W ballasts and also the 55W setup from Lumens systems (I know a few friends who have this setup), and also the light output from my Jetta which is a 35W 4300K BiXenon setup.
