Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 31st December 2007, 16:47   #1 (permalink)
Default Oil change for Honda Unicorn
Hi Guys,
I own a Honda Unicorn sports bike and have done almost 5 K on ODO by now. Bike is due for the 4th servicing in 2nd week of January. In all 3 servicings earlier, I had changed engine oil.
Bike has clocked almost 2.5K KM after 3rd servicing. Do I need to change the oil in now? Would like to know from experts, after how many KM engine oil should be changed?
Cheers,
Amit.
F1amit is offline   Reply With Quote
Old 1st January 2008, 02:15   #2 (permalink)
rider60's Avatar
depends on what oil grade(/brand) you choose to use and your usage.
well if you dont ride the bike past 4 rpm at any cost then changing the oil every 5K KMS is just fine and a 20W40 grade is fine!
if you do rip your bike then once in a while then change the oil sooner by 1000 to 1500 kms that is at every 3500 to 4000kms the same grade!
if you rip it periodically above 6rpm then the oil change is needed much sooner say every 3000kms and i would suggest you 20w50 grade oil for the bike! the shell helix or castrol GTX should be just fine and you will definitely have smoother gear shifts with this better grade oil!
even if you put in a higher grade oil i would say the equation is lesser the oil change intervals more is the engine life! this higher grade will cost more by about 50 bucks but worth it for the price!
the above said this i suggested are suggested according to the minimal cost maintainance plan,
if you want a good smooth engine, and a long engine life then i would say,
as a rule of the thumb, change the oil every 3000kms and use only the 20w50 grade, or change the oil every six months even if the bike sits idle, as you know even the oil does become old!
rider60 is offline   Reply With Quote
Old 2nd January 2008, 15:50   #3 (permalink)
Thanks rider 60 for your comments
Old 2nd January 2008, 19:36   #4 (permalink)
amit_mechengg's Avatar
oil change depends on the oil itself...i have found that shell lasts longer than castrol...and price also less....
put mobil synthetic and it will last for 10k kms....its best for unicon
Old 2nd January 2008, 21:15   #5 (permalink)
Ho0ligaN's Avatar
20w50 is not the recommended grade for unicorn, dont use it.
castrol gtx is not for bikes, dont use it.
get motul 3000 4t plus 20w40, I have been using it for almost an year now, real good oil 160 bucks a liter.
Ho0ligaN is offline   Reply With Quote
Old 3rd January 2008, 07:27   #6 (permalink)
rr_zen's Avatar
Have you tried this yourself ? I have had a few people tell me that synthetic oil is not advisable for bikes (esp four stroke ones) as they lead to increased clutch slippage. I would love to go in for Mobil 1 but want to have some first hand information from some one who has used it in his Unicorn.
__________________
Ships are safest in harbour. But thats not what ships are made for !!
rr_zen is offline   Reply With Quote
Old 3rd January 2008, 08:55   #7 (permalink)
rr_zen what you heard is correct. The only synthetic oil which can be used in motorcycle engines is the Motul 300V which is designed for motorcycles with a wet clutch. The automobile synthetics would induce clutch slippage. It doesn't matter if it's a two-stroke or a four-stroke motor.
The only bike in India which can use any synthetic oil is the Bullet and it's cronies. These engines don't share the engine oil with clutch casing.
F1Amit, you can use the Castrol Magnatec in your bike, it's semi synthetic and a very good oil. It doesn't induce clutch slipping i have tried it in my old RX and in the bullet clutch casing.
__________________
Crank
Old 3rd January 2008, 10:56   #8 (permalink)
Ajaybiz's Avatar
If you are using the oil supplied by Showroom then every 2k you have to replace the oil.Go through the manuals given by Honda.
Ajaybiz is offline   Reply With Quote
Thread Tools
Unicorn Rear Tyre Change: Suggestions? asault11 Motorbikes 16 11th October 2008 22:55
Oil change query sriturl Technical Stuff 1 22nd May 2008 01:23
Hero honda splendor - Which nut to open to change oil? vinfriend Motorbikes 1 27th August 2007 13:03
Castrol R4 superbike engine oil for Honda Unicorn devsus Motorbikes 4 4th May 2007 11:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
