| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #4 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Take to a garage with diagnostic equipment and check for the code, mostly it would be O2 as reported by many in TBHP
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #7 (permalink) | ||
| BHPian | Quote:
Even after the OBD scan shows it is the O2 sensor and if you are being too prudent to spend on it, ask whoever does the OBD scan to reset this error and take your car for a short drive, if the MIL indicator does not reappear, keep driving. If it reappears again with the same error code, just change the O2 sensor and go on with your drive. Quote:
YES!!! good for you, if it goes off after the ignition.
__________________ ...looking forward to sit a few feet above mean road level and away from potholes... | ||
| | #8 (permalink) |
| BHPian Join Date: Oct 2007 Location: bangalore
| thanks everyone! knew i'd get good advice! did take it to the service station. they did everything as 'gbspcars' has mentioned. its definately the 02 sensor. they wanted to replace it right away. but it costs 17000 bucks and thats steep. so i called my regular service guy. he's replaced a few sensors in other OHC's with ones available in the market. cost 5-7k. he says they aren't that reliable and 2 out of 5 fail in about 2 years. but i think...what the hell, i might as well try it. any suggestions? |
| | #9 (permalink) |
| BHPian Join Date: Nov 2006 Location: Chennai
| raftaar..... there was this t-bhp member from cochin i think who got his o2 sensor replaced from a piece his friend picked up for him in thailand. his landing cost was around 4.5k-5k. why don't you snoop around before you get it replaced.
__________________ An architect's most useful tools are an eraser at the drafting board, and a wrecking bar at the site - Frank Lloyd Wright |
| | #11 (permalink) | |
| BHPian | Quote:
i was that member...had this problem as soon as i landed in chennai from cochin.. a ex honda guy from the cochin dealership got me the sensor for 4k - works fine... but do have your sensor head cleaned of carbon deposits even before u invest this 4k.... | |
| | #13 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| Have you tried driving around after re-setting the ECU to see if the error reappeard, Just clean the Sensor head and also clean the Exhaust. At times a O2 error also comes with a Bad(RICH) Air-Fuel Mix, so check the plugs and clean the Air Filter and Throttle. In my XETA I sometimes got a Lamda Error ( O2) at that time the car was on Open Loop system( Rich CNG-Air Ratio),However later after the Closed Loop fittment, no more Lamda Errors, So it did not mean that the Sensor was defective or damaged.
__________________ " When was the last time, You did something for the first time " |
| | #15 (permalink) |
| hey everyone...am going to try fit the new sensor (not from showroom). narayan...don't know how i missed it...but you're right! the original sensor isn't reliable either! that's why i'm in this position. to answer other queries...i did get it checked at the showroom. they rest the thingy and tried other things too. but it obviously was a prob with the o2 sensor. anyways...will get to know today. will keep you guys posted. |
| Thread Tools | |
Similar Threads | ||||
| Pls guys!! Loan interest rates advise!!! | rndsoft1 | Indian Car Loans & Insurance | 41 | 29th November 2007 10:29 |
| Subwoofer for OHC - suggestions pls. | gbpscars | Ask the Gurus | 1 | 3rd October 2007 11:16 |
| GPS system for Bangalore- Pls advise | himanshugoswami | Modifications & Accessories | 13 | 16th October 2006 15:49 |
| Malfunction light glowing in my Innova…. | Mr.Bangalore | Technical Stuff | 5 | 22nd September 2006 01:59 |
| Car relocation - Hyd to Delhi-Pls advise | paharino1 | The Indian Car Scene!! | 5 | 15th February 2006 18:06 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
