Old 28th March 2011, 19:00   #10786
rg_chn's Avatar
Re: Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q
I just got my hands on a 91 Chevy Caprice, and, I'm in the process of restoring it. This car came with a Bose amp. Since it's 20 years old, I want to know if the amp is still working. How can i check?
P.S - There are no lights on the amp, from what i could see.
Thanks in advance.
rg_chn is offline
Old 28th March 2011, 19:07   #10787
pavansr
Posts: n/a
Re: Audio Gurus, please advice!!!
You can contact Mr. Jaanu Aggarwal in Delhi for Audio installation. His mobile no is +91 98115 67809. He sells lot of good stuff in Delhi.
Originally Posted by sheelz View Post
HI Guys
I am also planning to upgrade ICE of my Tata Safari. I am planning to go for Infinity REF6530CS components rated 90 W rms at 2 ohm. I am also planning to go for Infinity REF1260W sub rated 300 W rms at 4 ohms. I am planing to power all these with single 4 channel JBL GT5-S644 amp. Also I intend to retain the OE speaker in rear doors powered by the HU itself. I am also changing the OE alpine HU to pioneer 9350(alpine has only one pre-out).
Now my plan is to power the front components through two channels of the amp and bridge the rest two to power up the amp. Since I am no audio techie, I would like the Gurus to enlighten me as to how do I go about matching impedance/resistance/bridging channels etc. If you thing the amp is inadequate then please suggest me another but the amp budget is restricted to 8000 Rs. Is JBL 1004 available still? Its not listed in the site. The total budget without HU is around 22K.
Also I would like to install the front components in the doors without any metal cutting. Is it possible with the said components? Gurus can suggest some other also. I am not sure if Safai door can accomodate 6 or 6.5 inch components. Also is it required to go for damping.
Since I live close to Delhi (300 km-Gwalior!!!), any good installer to get it done neatly.
Thanks in advance..
Happy Motoring..
Old 30th March 2011, 15:56   #10788
Twiny's Avatar
Thanked: 63 Times
I read that, Kenwood M845 Amp accepts speaker level input. Considering Alpine 560 (has 1 pre-out for Subwfr), if going for 845, can I use it without High to Low converter.
What all the cons of using convertors.. (does this catch noise, alternator whine..)
Please share few good 4channel Amps(5-8k) which accepts spkr level inputs....Thanks
Twiny is online now
Old 30th March 2011, 16:14   #10789
pavansr
Posts: n/a
Hertz has 4 ch amps (HE4) which accepts speaker inputs from OE head units. You can try them.
Old 30th March 2011, 18:47   #10790
Twiny's Avatar
Thanked: 63 Times
Thanks pavansr.. how much does Hertz EP4 costs?
Twiny is online now
Old 30th March 2011, 18:52   #10791
pavansr
Posts: n/a
The MRP is 10,990/-. It's with 70W x 4 Ch output @ 4 Ohms.
Old 31st March 2011, 14:39   #10792
vampire's Avatar
Thanked: 12 Times
Hi Twiny I beleive even if you dont have speaker level inputs you can do with an RCA 4 or 2 channel convertor for using any amp.
vampire is offline
Old 31st March 2011, 14:59   #10793
fine69's Avatar
Thanked: 1,468 Times
HI Guys
I am also planning to upgrade ICE of my Tata Safari.....
I'd advise you to visit the Delhi/NCR directory for trusted/recommended installers. If you give them a call they can answer most of your queries including possibility of fitment of components without any cutting.
May be after you've spoken to them you can post your queries that were still unanswered.
fine69 is offline
Old 31st March 2011, 23:51   #10794
Thanked: 16 Times
which is better choice to power front compos and rear coax(SPL setup)
infinity kappa 4
DLS RA 40
moscono gladen one 120.4
focal solid4
procircuit_234 is offline
Old 2nd April 2011, 16:13   #10795
fine69's Avatar
I play an mp3 that is alleged to be 320 kbps but when I check the properties this is what I find.
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q!-untitled.jpg
So what does this audio codec at 280 kbps mean?
Most of the english mp3 that I checked had both the bit-rate & audio codec listed as 320 kbps but in the hindi ones bit-rate shows 320 while the audio codec varies from 256 to 280.
fine69 is offline
Old 5th April 2011, 09:48   #10796
navin's Avatar
Thanked: 9,960 Times
Are these recorded with CBR or VBR? Do you knwo the origin of these recordings? Did you make these recordings yourself?
navin is offline
Old 5th April 2011, 10:45   #10797
fine69's Avatar
Downloaded off the internet. No clue about the origin.
Reason why I doubt certain recordings are because some mp3s with 320 kbps bit-rate play so clean while others not so clean though both show 320 kbps bit-rate.
Basically what I wanted to check was that can such mp3s be tweaked to make Windows Media Player show bit-rates/audio codec values that aren't actual.
fine69 is offline
Old 5th April 2011, 11:57   #10798
blackfire_9's Avatar
Thanked: 192 Times
Hi all,
I am in the process of upgrading my car's HU. I had in fact posted a query on my thread in the Sound Off & Show Off section but before spending my hard earned money on this upgrade, I want to be sure if this is actually what I need or something I want.
The reason that got me thinking towards an HU upgrade is the lack of 3 RCA pre-outs in my HU. Mine has 2 pre-outs (2V each) with splitters on each since my car is running 2 amplifiers. Upon reading a bit over the internet & TBhp, I seem to understand that a high voltage pre-out ensures more clarity & better sound. Is it true? Would there be any perceivable difference if SUPPOSE my existing HU had higher voltage pre-outs i.e. 4V instead of 2V? If no, then I guess I would shelve the upgrade for now.
Apart from this, my HU supports only CDs & at times, I feel the need of USB support because it's not possible (or convenient) for me to keep buying or recording CDs for every new song that I start liking.
Please pour in your advises & help me reach a decision.
Thanks.
blackfire_9 is offline
Old 5th April 2011, 13:28   #10799
navin's Avatar
Goor or poor encoding is a matter of a few variables. You need to ensure the output levels of the encoder are set so that they result is not distorted.
For the past 6 years or so I have used EAC and LAME. Both have been stable
for the past 10 years - I think both were first released in 1998 or 1999.
I would strongly advise using EAC/LAME with AccurateRip or something like dbPoweramp. See this guide
Exact Audio Copy Guide Thoughts - Club MyCE
The cheapest HU I know of that has 3 pre outs is the JBL 333. However this HU does NOT have a CD player.
If your install is well done and the wires used are of good quality then a 2V signal is more than adequate most amps are happy with 1V or less. A 4V pre out only ensures that you dont need to turn the gains on your amp too high. When you turn up the gains on your amp up they often also amplify any noise in the wire hence with a 4V pre out you are less likely to amplify noise.
navin is offline
Old 5th April 2011, 17:08   #10800
Kimified's Avatar
Thanked: 81 Times
Audio guru's here. Please advice.
I have Infinity Kappa 60.9 CS comps in the front and JBL GTO 1004 Amplifier in my I20 . But i am not all that happy with the sound. The sound produced is definitely better than the stock speakers but i am looking for something better.
1) I am looking at replacing the stock HU with the JVC AVX 836. Searched the thread on the JVC, Found that some people have a problem with the mic. Could not find anything more on the 836 as not many have written reviews on the same. I have an option between pioneer 4250 and the JVC 836. The JVC is feature rich compared to the pio and thats why i am leaning towards it (offers more value for the same price). Bluetooth and Detachable face plate. I don't really know the difference between the SQ's of the 2 HU's and i could not audition the JVC anywhere :( . Can someone tell me how good or bad the JVC is compared to the Pio. I have heard people say that the Pio has a better screen compared to the JVC, But when i checked the specs, The resolution on both of them are the same. Or, Am i missing something?
2) I am looking at installing a Sub woofer too. My overall budget is 40 - 42 k. The JVC HU with the Fascia and the Steering mounted control interface will come upto 34 approximately (28 + 3.5 + 3). Please suggest me a good sub woofer in the 5 to 8k range. I will audition all different ones suggested here and then decide on one based on my taste. Lesser space occupied, the better.
PS : I am new to this forum, I presume that i have posted my query in the right thread. Please move it to the appropriate thread if its not appropriate. Thank you.
Kimified is offline
