Old 6th November 2024, 12:09   #7711
Thanked: 3,031 Times
Re: The home / office air-conditioner thread
Originally Posted by jomyboy View Post
There is a difference between extended warranty and extended comprehensive warranty and LG is not all inclusive. Only Godrej, Haier and Voltas provide comprehensive warranty.
Well this is what LG AMC Covers
The AMC shall cover the following parts under the normal product warranty based on selected plan code
HA/AC Products: Compressor, Thermostat, Relay, OLP, Fan Motors, Timers, PCB, Heaters, Air dampers, Ice maker, temperature sensors, Evaporators, Condensers, Refrigerant charging, Driers, Capillary, Blowers, Fan Blade, Control box, Magnetron, Electrical switches, transformers (internal), Diodes, Capacitors, Wire harness, Wash & Spin motors, Gear box, Clutch Assy., Drum, Inner tub, Bellows, bearing & lip seal, Drain motor, Pump, Electrical valves, Buzzer, Suspension, Key Membrane, Remote-PCB.
HE Products: Chassis, PCB, LCD module, Electrical switches, PDP module, SMPS, Speakers, Capacitors, Diodes, Transformer, Transistors, IC, Remote-PCB.
Plus there are two services per year included.
Aroy is online now   (1) Thanks
Old 7th November 2024, 11:27   #7712
Thanked: 439 Times
That is all fine, but they don't cover gas charging, unless gas leak due to compressor fault. If you are fine with that, then by all means go ahead. I just spoke with my experience, gas leakage fraud is something these AC guys are minting on day in day out.
jomyboy is offline
Old 7th November 2024, 12:37   #7713
Read carefully. They cover gas charging, for what ever reason it may be. (Unless there is a distinct sign of physical abuse). Checked it with LG engineers. The warranty also covers replacement of the IDU, ODU condensers. Had changed the IDU condenser in the first AC I bought. The change was required due to repeated dismantling for pressure washing. Now a days they do not need to dismantle as they have pressure washers with a plastic hood to prevent water spray. Also in the event that the condenser is clogged totally they will replace it. That can happen in extremely dusty environment followed by high humidity if the AC is not regularly serviced or serviced without pressure washing. The good thing is that the LG Extended warranty comes with two free services annually. More if there is a problem.
Old 29th November 2024, 17:51   #7714
Thanked: 30 Times
Hi guys.
What’s your advice on the best window A/C to buy currently .
I need to replace my old General. It’s badly corroded and is using a lot of electricity.
Revvhed
revvhed is offline
Old 29th November 2024, 18:08   #7715
IamNikhil's Avatar
Thanked: 3,306 Times
Check out Voltas or Bluestar.
IamNikhil is offline   (1) Thanks
Old 19th January 2025, 17:15   #7716
ashis89's Avatar
Thanked: 12,223 Times
Need to purchase 4 ACs for home. Between Daikin vs. Hitachi, which one would be better? Daikin is quoted 3-3.5k more expensive than comparable Hitachi.
ashis89 is offline
Old 19th January 2025, 17:49   #7717
PaddleShifter's Avatar
Thanked: 2,911 Times
Both Daikin and Hitachi should be a good option. Better to check regarding the service availability (I see Daikin more commonly than Hitachi).
Regarding Hitachi, I am a fan of their engineering because of small attention to detail but have never owned one.
Recently, I stayed in a guest house for more than 3 weeks and used a Hitachi split AC. It performed wonderfully and the best thing was that there was no annoying white LED showing the set temperature in a so called hidden display inside the indoor unit. It beeped very gently while changing the settings in contrast to my Carrier that can wake up a person sleeping in the next room. This is problematic when there is an electricity interruption in the middle of the night (resulting in loss of silent mode setting).
My LG and BlueStar AC at home are also loud in this regard. Hats off to Hitachi engineers for being intelligent beings.
PaddleShifter is offline   (3) Thanks
Old 20th January 2025, 09:55   #7718
I have had both Hitachi and Daikin AC's. Their products are very good, but their service is quite bad. Now I am an LG fan with five AC's. The good thing about LG is their extended service which takes care of all the service and parts related issues for 5 years at around 10K. All parts, gas and annual services are included.
Aroy is online now   (3) Thanks
Old 10th February 2025, 11:39   #7719
Su-47's Avatar
Thanked: 364 Times
Thanks for your recommendation. I'm looking at buying another AC and thinking of going with either Samsung or LG this time. Drawing a parallel with cars, there was a time when Honda was a lot more reliable than Hyundai, but now Hyundai is good enough. Similarly, I think that LG/Samsung are good enough now, and the ease-of-service angle can't be overlooked. Interestingly, Samsung seems to be offering extended warranty for 5 years with 1.5Ton 5-star inverter model, which makes it rather attractive proposition. Or am I missing something here?
Originally Posted by Su-47 View Post
Based on a friend's recommendation, bought a Toshiba Inverter AC and it is ridiculously quiet. The ODU is pretty silent as well. When it is silent outside in the nights, I can hear a Samsung ODU which is 3 floors down but not this one which is only 5 feet away.
This Toshiba AC installed 8 years ago, is holding up very well. No gas leaks, no perceivable increase in noise or reduction in cooling performance, so didn't get it checked or serviced ever! Please note this is in Bangalore, so operating conditions are relatively mild and the environment is non-corrosive. Am I pushing my luck too far and should I get this checked/serviced this year? I'm worried that the act of "checking" may disturb a perfectly working machine. If at all I should get this serviced, what do I ask them to check?
And, I noticed that the modern Samsung ODUs don't make as much noise as the old ones used to. Or, is it just a matter of time before they degenerate into noisy ones?
Su-47 is offline
Old 10th February 2025, 12:12   #7720
Most manufacturers give extended warranty at a cost. So please check the cost for Samsung AC's. It is around 10K for LG if taken out within first month. The rates are on their site.
For those who go for extended warranty please check if the following are covered :
. Gas
. Heat exchangers (radiators/grills)
. Fans
. Motherboard (though that is covered for 5 years in the normal warranty for most)
. Body rust
. Cartage if the AC is to be taken to workshop.
In fact LG covers everything (except a few plastic parts) parts, labour and gives two free services a year.
Old 11th February 2025, 07:18   #7721
sandeepmohan's Avatar
Thanked: 6,056 Times
Get yourself one of those cordless (Or chord) air blowers and blow the outdoor unit yourself. If you are handy with a screw driver, lift the lid off the outdoor unit and give it a nice internal blow out (Cooling coils, etc), while not directing too much air pressure around the electronics. Take out indoor unit internal filters and wash them with warm water, air dry them and place them back into the indoor unit. Thats all the service you need to do. I can almost guarantee that the service engineers will water blast the unit. There is no need to do that.
Almost all modern aircon units come with compressor jackets, hence the reduced noise.
Last edited by libranof1987 : 11th February 2025 at 18:29. Reason: Fixing broken quote tags
sandeepmohan is offline   (1) Thanks
Old 11th February 2025, 09:21   #7722
. If the environment is dusty; as in Delhi; then pereodic washing of the ODU is necessary. My service engineer uses high pressure water to wash the ODU, both the fins and the fan. There is so much dust accumulated in 4/5 months that it takes five to ten minutes of washing for the dripping water to trurn normal. Initially it is jet black.
. Inverter AC ODU make much less noise than the the non inverter AC. The reason may be that inverter AC ODU fan is also regulated so the speed is adjusted to the heat load. After a few minutes of switching on, the heat load reduces, so does the cooling requirement, hence lower fan speeds -> lower noise.
Old 11th February 2025, 20:55   #7723
fast_elegance's Avatar
Thanked: 294 Times
Hi All, I am in the market for a new AC and visited Reliance Digital last weekend. I went in looking for LG models, however, the sales guy was pushing for the Samsung WindFree™ Inverter Split 1.5T 5star model. This comes with Freeze wash + Wifi and was available at a final price of 45K after some card cashback. I liked the design and also looked very modern compared to all the other models available. Anyone here who has experience with this model? Are these just gimmicks or are they useful practically? Looking for some feedback and recommendations. Thank you.
fast_elegance is offline
Old 12th February 2025, 10:21   #7724
In my experience a "Wi-Fi" in appliances is an overkill. I have used it only once in my WM. WIFI only makes sense if you use it regularly else the expense is not worth it.
Most of the Inverter AC in the market have similar functions, it is just that each manufacturer gives them different names. In my experience it is more cost effective to go for a brand that has excellent after sales service, rather that an AC that is high end but lacks good service support.
Both Samsung and LG have similar prices (give or take a few, depending on dealers and schemes) so you can choose which ever takes your fancy.
Old 12th February 2025, 10:53   #7725
sagarpadaki's Avatar
Thanked: 6,848 Times
I suggest you get the ODU washed or wash it yourself with hose pipe if it is accessible to you. The amount of dirt present in the fins will surprise you. I usually get AC service done by Urban Company. They do a fine job.
sagarpadaki is online now   (2) Thanks
