Old 26th August 2010, 07:07   #241
gkrishn's Avatar
Thanked: 149 Times
Lastly, 7" Galaxy TABLET being launched on Sept 2nd!.
Yes, and a host of accessories fo.r GS too. Love that car dock
not sure when they will be available in india.
Sooner the froyo comes the sooner I can get rid of this lag fix.
gkrishn is offline
Old 26th August 2010, 15:15   #242
Rehaan's Avatar
Thanked: 36,088 Times
Kaushik_s and anyone else whos GPS is working well on the Galaxy S - i need a favour!
1) via *#*#1472365#*#* can you please tell me ALL your settings for :
Application settings :
Session Type -
Test Mode -
Operation Mode -
Start Mode -
GPS Plus -
Dyn Accuracy -
Accuracy -
Use SkyHook -
Use PC Tool -
SUPL/CP Settings :
Server FQDN Type -
Server -
Port -
Secure Socket -
AGPS Mode -
2) If you have the app GPS Test could you tell me roughly :
- How many satellites you typically find "in view"
- How many satellites you typically find "in USE"
- The average SNR of these satellites (i never get above 40! Typically ~20-30)
Thanks!
R
Rehaan is offline
Old 26th August 2010, 15:26   #243
gkrishn's Avatar
Thanked: 149 Times
These are default settings. i have not changed them. gps works fine. Both in google maps and in mytracks.
Session Type - tracking
Test Mode - SW test
Operation Mode - Standalone
Start Mode - Hot start
GPS Plus - on
Dyn Accuracy - on
Accuracy - 50
Use SkyHook - off
Use PC Tool - off
SUPL/CP Settings :
Server FQDN Type - custom config
Server - supl.google.com
Port - 7276
Secure Socket - off
AGPS Mode - supl
gkrishn is offline
Old 26th August 2010, 22:06   #244
kaushik_s's Avatar
Thanked: 165 Times
Hi Rehaan,
My settings are as follows. GPS is working fine with my mobile nowadays..
BTW, got the SIM changed today. Seems to be working fine now. Phone was reachable while at office after the change. Will be updating the final results tomorrow or by Monday.
Session Type - Tracking
Test Mode - S/W Test
Start Mode - Hot Start
GPS Plus - On
Dyn Accuracy - On
Accuracy - 50
Use SkyHook - On
Use PC Tool - OFF
SUPL/CP Settings :
Server FQDN Type - Auto Config
Server - h-slp.mnc045.mcc404.pub.3gpp
Port -7276
Secure Socket - OFF
AGPS Mode - SUPL
- How many satellites you typically find "in view" -- 7-10
- How many satellites you typically find "in USE" -- Need to check
- The average SNR of these satellites (i never get above 40! Typically ~20-30) -- not Sure again.
Thanks!
R
kaushik_s is offline
Old 26th August 2010, 23:02   #245
saurabhdadhichi's Avatar
Thanked: 78 Times
Milestone
I have motorola milestone over past 2 months & I am enjoying every bit of it. Android is a definitely a challenge to Apple OS & MS OS.
I have observed only one limitation till now & that being not sure if it will get Android 2.2 Froyo, as according to Motorola's official communication, this decision is under evaluation.
saurabhdadhichi is offline
Old 26th August 2010, 23:03   #246
jkdas's Avatar
Thanked: 1,497 Times
OT I guess.
Checked out my friend's HTC Legend;looked very plastiky to me :(
jkdas is offline
Old 27th August 2010, 00:11   #247
kaushik_s's Avatar
Thanked: 165 Times
OT I guess.
Actually Legend seems to be of much better build than say Samsung Galaxy S. Not sure what you meant by plastiky as the phone is made of a single piece aluminum.
Old 27th August 2010, 00:25   #248
v.anand's Avatar
Thanked: 97 Times
^^@kaushik, I think you have mistaken Nexus One build for Desire and they share the same colour along with internals. N1 has an unibody construction metal body but Legend is built similar to SGS with plastic at the rear. The quality of plastic, I don't know since haven't seen one in person yet.
As for the build of SGS, I have noticed a small rattle in the chrome trim on top of the screen near the connector port, head phone port and ear piece when pressed. Have you noticed the same in yours? Otherwise the build seems to be fine but the back plastic has a tendency to get scratched easily.
v.anand is offline
Old 27th August 2010, 00:35   #249
kaushik_s's Avatar
Thanked: 165 Times
I'm talking about the Legend only, but now I'm bit confused as it has been some time since I've hold the Legend and that time I felt it to be well built. And I'm pretty sure that it was single block aluminum but I'm kind of unable to remember the feel of the back cover though. Will check again. Nexus One is obviously of a better build.
Exact same thing here too. You can depress that part a lil'. So I guess it's a common thingy for SGS.
Old 27th August 2010, 07:13   #250
Thanked: 9,251 Times
HTC Legend is a solid phone, Aluminium unibody construction.
N1 too is built around a Aluminium chassis which wraps around the phone and two plastic panels - battery cover and lower part.
HTC Desire i think is based on a an aluminium chassis, but of different design, since both N1 and Desire weighs almost the same.
Sankar is offline
Old 27th August 2010, 09:47   #251
v.anand's Avatar
Thanked: 97 Times
Oh yes! My bad, I was talking about Desire. Got confused between Legend and Desire. Legend too is a metal unibody phone and when I held it, found it too slippery. Desire has a soft touch matt plastic cover at the back holding the body, quality of which looks to be better than SGS, but haven't seen it. Legend was long out of contention when I was looking to buy SGS due to inferior specs and slightly higher price. I feel if Legend is priced on par with Samsung Wave, it will do wonders.
v.anand is offline
Old 27th August 2010, 11:45   #252
kaushik_s's Avatar
Thanked: 165 Times
Absolutely correct. They can reduce the price of Legend to be in and around 15-17k and that phone gonna sell like anything. 24k is bit too much for the low specs that the phone have.
Old 29th August 2010, 22:16   #253
I bought Samsung galaxy 3 , I5801 about a week back.
The gps seems to be really bad on this. I am not sure
whether it is on my phone only. Can some one confirm the gps performance on samsung galaxy 3.
Try with the gps test from android market.
I tried on open area with my iphone and with the other android mobiles like HTC Wildfire and Sony X8. In all these phones the GPS picks up the signal in less then one minutes but in galaxy i5801 some time it takes more then 10 minutes but the signal keeps dropping off. Some times it takes much more then 10 minutes. Before gps could catch the signal I arrived the destination etc.
Cam some one please confirm the GPS performance on samsung i5801.
rreddy18 is offline
Old 29th August 2010, 23:29   #254
adi99's Avatar
rreddy18 - Where in Blore did you buy the I5801 and how much did you pay? I have been looking for this phone and no seller has it!
adi99 is offline
Old 30th August 2010, 09:04   #255
Bought in jaynagar , ph: 080-26536384 41235572
rreddy18 is offline
