Old 29th April 2016, 00:33   #91
anycatd's Avatar
Thanked: 151 Times
Re: Above the Ordinary : My Crossover, the Maruti S-Cross
DDiS200 is of a VGT configuration in both S Cross and Vitara Brezza and is tuned differently. Swift engine is of FGT configuration.
I know that fact but does VGT improve efficiency too?
anycatd is offline
Old 29th April 2016, 10:11   #92
Thanked: 219 Times
The suspension is a bit stiff in city conditions and it is a lot like European cars. High speed ride quality is excellent and the car remains absolutely flat, ironing out all of the road imperfections.
Nonetheless, ride quality isn't disturbing nor does it have the suspension crashing through bad sections of the road.
Please take an extensive TD before deciding on the car.
Thanks for your comments. As you rightly mentioned, an extended TD with wife seating at back would probably answer to my questions.
sups is offline
Old 1st May 2016, 13:36   #93
Thanked: 78,609 Times
With a VGT , the configuration of the turbine housing helps the engine acceleration, the turbo's aspect ratio can be maintained at its optimum.
Hence the VGTs have a low boost threshold, and are very efficient at higher engine speeds.
volkman10 is offline
Old 28th May 2016, 21:06   #94
An unexpected update, courtesy - Service campaign!
Since the campaign announced had received 3 calls informing of the parts availability and to do the same at with prior appointment.
Well today had decided to go for the same. Reached the service center at 9:30 and completed the task by 11:00 am
Jobs completed - Service campaign and Smartplay software upgrade for carplay!
Understood from SA the following on the campaign.
1. All cars affected will have the caliper assembly replaced ( rear)
2. The new ones are of higher brake pressure
3. No problem as such with the old ones, a few cases low brake pressure reported (
warning light on)
4. The old parts are couriered back to Maruti Suzuki
S Cross in Nexa service Bay
Above the Ordinary : My Crossover, the Maruti S-Cross-20160528_091149.jpg
Rest in pics!
a. Handbrake being loosened.
Above the Ordinary : My Crossover, the Maruti S-Cross-.jpg
b. Accessing the brake caliper assembly and removal of the same,
Above the Ordinary : My Crossover, the Maruti S-Cross-b.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-c.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-d.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-f.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-g.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-h.jpg
c. The new caliper Kit ( caliper assembly + 2 washers for banjo fitting/ caliper assembly)
Above the Ordinary : My Crossover, the Maruti S-Cross-i.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-j.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-k.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-l.jpg
d. Old parts kit - identifying with Chassis nr and vehicle Reg nr. for dispatch to Maruti Suzuki
Above the Ordinary : My Crossover, the Maruti S-Cross-n.jpg
e. Topping up brake fluid and bleeding of brake lines on all 4 brake units.
Above the Ordinary : My Crossover, the Maruti S-Cross-o.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-p.jpg
Additional work - Software upgrade ( carplay compatibly),
Above the Ordinary : My Crossover, the Maruti S-Cross-q.jpg
Car ready with Updated brakes
Above the Ordinary : My Crossover, the Maruti S-Cross-r.jpg
S Cross continues to deliver on mileage in Bangalore moderate traffic
1. Early morning drive and mileage
Above the Ordinary : My Crossover, the Maruti S-Cross-m.jpg
2. Mid day drive and here is a drop in figures,
Above the Ordinary : My Crossover, the Maruti S-Cross-20160528_110618.jpg
3. Avg. Evening drive , marginally lower than mornings
Above the Ordinary : My Crossover, the Maruti S-Cross-e.jpg
Next planned update - @ 10K km service
volkman10 is offline   (23) Thanks
Old 28th May 2016, 23:12   #95
Thanked: 88 Times
An unexpected update, courtesy - Service campaign!...Next planned update - @ 10K km service
Hi Volkman thanks for this update. Quick query- I have driven close to 700 kms in Chennai traffic and my car which is also 1.3 Zeta variant is delivering 15.3 kmpl. Should I be worried about it as my mileage seems to be on lower side when compared to yours? Should I complain on this in 1st service or is it due to my driving style? Earlier had been driving only petrol cars. Pls advise.
Last edited by FlyingSpur : 28th May 2016 at 23:53. Reason: Please do not quote entire large posts. It inconveniences our small screen / mobile users. Please go through our forum rules.
Ananthc is offline
Old 29th May 2016, 13:07   #96
Completed one month and and took the customary service (1 month or 1000 km).
Hi Volkman, I have just crossed 1000 kms. I will be taking my car to the service centre tomorrow. The rev meter is always above 1200 even in idling. I wish to address this issue. Is there anything else in general that needs to be done during first service.
Update - Post 1000 Km
- Changed all Tyres to pressure @ 40psi , Nitrogen
Is this the right tyre pressure?
I had kept the tyre pressure@33psi nitrogen as mentioned on the driver door but I don't find it to be up to the task. It's mostly just 2 people travelling in the car. I will also try to increase the tyre pressure.
BenHarPree is offline
Old 29th May 2016, 13:40   #97
Attachment 1511466
Attachment 1511467
Attachment 1511477
Did you enquire about the rust near the disc which you had mentioned earlier?
Old 29th May 2016, 17:28   #98
For first 1000 km drive as recommended and the FE figures will hover close to 16 km/L, post 5k km service expect a better mileage.
For a light footed driver the FE figures will be higher as the accelerator seems very sensitive. Do not change your driving style unless an abnormally low FE that you get.
Nothing more since 1k Km is just a check of all oils etc. If yours is an Alpha/Zeta you can get the Samrtplay upgrade if applicable.
Tried 38 psi and above, felt the ride was best at 40 psi.
Checked with SA and saw this in all S Cross's that had come for service.
Old 29th May 2016, 17:36   #99
Mine is zeta. Will check if smartplay upgrade is applicable. So, No issues with the rust. :thumbup:
Old 29th May 2016, 18:16   #100
Sree73's Avatar
Thanked: 1,010 Times
The idling RPM for 1.3 is 750 and 900 (with AC). If your vehicle is 1.3, 1200 RPM is way too high. I'm not sure about the 1.6 idling RPM though.
Sree73 is offline
Old 1st June 2016, 17:10   #101
Completed the first service. They have adjusted the idling RPM. It is hovering between 850 and 900.
Old 2nd June 2016, 16:43   #102
Suz
Hi Volkman. Glad to see your detailed regular updates.
I have a 1.3 Sigma which I have now driven for around 2000 kms returning an average FE of about 16. Was thinking of getting an oil change done. Considering that Kalyani NEXA SA is saying they will use the 0W40 oil which with the filter change will cost me around 4300 Rs, do you think its worth it ? Also please do let me know when was your first oil change done and the oil grade which is currently used in your car. As the manual says SAE 5W-30 grade is to be used which costs a fair bit lesser I am a little confused and thought of taking opinions of a few members here.
Where do you dock your car for service ?
Suz is offline
Old 2nd June 2016, 19:40   #103
Sree73's Avatar
0W40 is a fully synthetic oil and hence the higher price. Maruti does not recommend fully synthetic oils for their cars.
Sree73 is offline
Old 2nd June 2016, 19:53   #104
I have done the first oil change at 5k km though the SA was insisting to do it on 10k as recommended by MS.
As noted I have gone for the mineral oil and not the grade specified by you which is the synthetic as mentioned by Sree.
I do the service at Bimal motors.
Old 2nd June 2016, 19:56   #105
Dr.Naren's Avatar
Thanked: 17,277 Times
Maruti recommends fully synthetic 5W40 engine oil for all cars with 1.3 multijet engine. I think for Baleno/S-Cross it's 5W30 though.
It was 5W40 fully synthetic oil for my SX4. Later Maruti sent a circular to dealers saying even mineral oil can be used based on customer demand. Recently my service manager told Maruti is back to fully synthetic oils for all new cars.
Dr.Naren is offline   (1) Thanks
