Old 25th August 2024, 19:33   #811
Thanked: 26 Times
Re: Comprehensive guide to LED Headlight upgrades
Hi @Vignesh Vee..thanks for your very useful post. Couple of questions..
1. How much did it cost you ?
2. Where did you purchase it from ?
3. Will it fit into my scope rapid rider 2020 ?
Many Thanks
Originally Posted by Vignesh Vee View Post
Hi Everyone,
I have upgraded my 2014 Swift's Halogen headlight bulbs to the newly launched Philips Ultinon Weather Vision direct fit LEDs.
The reason why I bought these bulbs is because of their 3500K color temperature (the same as halogens) and direct fitment, which prevents alignment problems.
traveller_riz is offline   (2) Thanks
Old 25th August 2024, 20:45   #812
Thanked: 281 Times
I am satisfied with these bulbs. I recommend these bulbs to those who are not interested in cool white lights
What was the wattage of the halogen bulbs you had before? I'm trying to figure out if 20W LEDs are brighter than 50W Halogens
bravo6 is offline
Old 25th August 2024, 20:56   #813
greenhorn's Avatar
Thanked: 4,910 Times
I am running 16w ultinon g2 which i found on par with Philips Xtreme vision high output 55w which was a decent upgrade from stock halogens
greenhorn is offline   (1) Thanks
Old 25th August 2024, 22:15   #814
Thanked: 153 Times
Originally Posted by rahul_goyal View Post
I have a Kia Seltos (2019) HTK+. The OEM headlight setup is highly inadequate.
Get osram 50W led with 4300K color temp.
yadavsid21 is offline
Old 25th August 2024, 22:20   #815
Thanked: 153 Times
Originally Posted by kruzr View Post
BTW the dust cover grooves were slightly cut to fit in the LED and have already started to see dew formation on right headlamp which I'm not happy about.
Never cut/drill the dust covers. Not just moisture but dust will also enter.
If the oem dust cover touches the led then get bigger silicon dust covers, i bought from auxbeam india for ~₹450/pair
Old 25th August 2024, 22:29   #816
Thanked: 834 Times
Hi Everyone,
Looks promising, especially since it has 3500k "halogen like" color temp.
Is it a direct fit for the Hycross (since the car already has an LED setup)?
jinojohnt is offline   (1) Thanks
Old 26th August 2024, 09:59   #817
Vignesh Vee's Avatar
Thanked: 481 Times
I purchased this from Amazon for 5199 rupees. Yes, it will fit on the Rapid Rider. Choose the H4 socket variant.
Stock 60/55W bulbs.
Yes, it will be suitable. Check the type of socket in your car before purchasing.
Since your car has white color lights, you can go with 6000K Philips Ultinon Access direct fit LEDs.
Thanks.
Vignesh Vee is offline   (2) Thanks
Old 7th September 2024, 17:29   #818
piiyush21's Avatar
Thanked: 29 Times
Hey everyone, I needed a suggestion
I have a 2018 Ciaz as my daily driver. Recently I decided to upgrade the headlamps from company fitted halogens to LED, however, a few people created a doubt in my mind that it might require wire cutting and addition of some new components.
Can you please let me know if there is a way I can get it done without wire cutting? Also some suggestions about good car accessory shops in Delhi are welcome
piiyush21 is offline
Old 8th September 2024, 22:23   #819
Thanked: 23 Times
I believe your car has one H7 bulb for high beam and one H7 bulb for low beam with low beam being projectors.
LEDs are a very easy, plug and play installs for the most part which doesn't require any wire cutting and directly draws power from the socket. It is a pretty easy affair too unless the bulb you are replacing with doesn't accomodate inside the dust shield.
For the bulbs I suggest getting 50-55 W 4300k temperature ones even though they are scarce. 6000k ones which are widely available are cheaper but cause glare and are bad in the rain (from personal experience)
Also LED bulbs inside projectors may not work as well as in a regular reflector housing. Perhaps other BHPians can shed light on why this is so.
Chaman K is offline   (1) Thanks
Old 11th September 2024, 14:46   #820
rroy92's Avatar
Thanked: 233 Times
I am looking to replace the brake light and reverse light of XUV700
For LED Brake Light bulbs, Socket is 1156 P21W
For Reverse Light bulbs, Socket is T15 W16W
https://www.team-bhp.com/forum/test-...ml#post5839761 (The Silver Surfer | Mahindra XUV700 (AX7L D AT) | Ownership Review)
I found a matching product from Osram but am yet to find a retailer selling it here.
https://www.osram.com/ecat/LEDriving...1/ZMP_4062010/
Any other suggestion on what to use and where to get it from. Thanks.
rroy92 is offline
Old 11th September 2024, 22:37   #821
Mortis's Avatar
Thanked: 1,683 Times
Hi Everyone,
I checked these out. On the product page it mentions that the life of these bulbs is UP TO 1500 hours only !
That seems quite low for an LED bulb. Obviously I didn't expect the usual 35-50000 hr rating of LEDs in other applications due to the extreme conditions and compromised cooling of headlights so I did a bit of research.
For other bulbs, the rated lifespan seems to be in the 2500-5000 hour range. The shady bulbs obviously state a full 50000 hrs but I'm not inclined to believe them.
So all things considered these bulbs still have lower life vs othe LED bulbs but the warm white colour is a good enough counterpoint to them. IMO they would be great in fog lamps where usage is lower.
Mortis is offline
Old 12th September 2024, 11:58   #822
bajoseph04's Avatar
Thanked: 132 Times
Hi Everyone,
I had plans to upgrade to the the weathervision LED but then gave up the plan because there was no clarity weather the bulbs has both high and low beam. So, purchased Racingvision Gt200 from amazon. But totally disappointed with the brightness. May be I'll wait for the next amazon sale and get the weathervision LED now that you've clarified that it has both high & low beam. Thanks!
bajoseph04 is offline   (1) Thanks
Old 22nd September 2024, 19:19   #823
Hello all,
Yaris 2018 Top-End variant. Attached stock image for a review.
What would be a good upgrade for my projector headlamps and the company fitted fog lamps. I'm 80% highway driving out of which 30% is night driving.
mehargags is offline
Old 29th September 2024, 19:59   #824
Thanked: 53 Times
Originally Posted by mehargags View Post
Hello all,
After having experimented with different solutions here are a few options you may want to consider:
1. If your projector supports normal bulbs (H8/H11/HB3/HB4) I'd suggest you get a auxbeam 240W GX ultra from aux beam website. Been using it on the highbeam of my Honda city GM6 and it's been really great.
2. If you want to consider more drastic measures of retrofitting, get the AES LS850 Headlamp retrofit projector.
3. For foglamps, consider the AES F75 bi-laser projector. Covers both width and has great forward visibility in high beams.
Hope this helps !
iBokehlicious is offline   (1) Thanks
Old 29th September 2024, 20:01   #825
Thanked: 53 Times
Hi
You might want to try the autobahn technologies website for some high quality bulbs. Have used various indicator / tail light bulbs from them and not been disappointed yet (going on 2 years)
Link: https://autobahntechnologies.com
iBokehlicious is offline   (3) Thanks
