Team-BHP > Motorbikes
Old 5th October 2024, 16:46   #886
VijayAnand1's Avatar
Thanked: 3,563 Times
Re: Royal Enfield Himalayan 450 Review
Originally Posted by balenoed_ View Post
Just curious to know, did you get this replaced? And how is the new one doing? Is the joy stick really a problem across or was it just a one off case?
The joystick woes are to continue for a long time to come. The tactile feel will be robbed as days pass by and it's extremely cumbersome to operate especially with gloves on. This isn't a one-off case, there are numerous cases of joystick failure where the complete switchgear is offered as a replacement due to it either going completely out or working intermittently especially post rainy day ride or a pressure wash. 4 in 10 bikes are randomly affected by this joystick problem, low-down I get straight from SVC folks.
Cheers!
VJ
VijayAnand1 is offline
Old 5th October 2024, 17:05   #887
Thanked: 16 Times
Cheers!
VJ
Same issue, the RSA refused to replace the joystick, they demanded for a video of the malfunction for any warranty claims.
ThatWhitei20 is offline
Old 5th October 2024, 17:42   #888
Thanked: 282 Times
Got the second service done today. Got oil changed as I have a big ride coming up. Also replaced rear brake pad, they reckoned there was only 1k km worth of life left. Kept the old brake pads. Surprised they have only lasted 4900 km.
Common problem. My bike says Joystick Malfunction on turning on. They didn't have stock - have said 10 days for the part. Hoping it comes soon - need control for my long ride.
Shur'tugal is offline   (1) Thanks
Old 5th October 2024, 23:26   #889
aviator1101's Avatar
Thanked: 3,046 Times
Ownership Update : Bagheera crosses 13000 kms
Present day odo reading : 13796 kms (post completion of Spiti ride)
Two servicings done in between :-
  • Third Free Service
  • General Check-up post Spiti ride.
Third Service details
Odo reading : 9763 kms
Got it serviced a little early as I was on a ride to Spiti and had stopped at Delhi for this servicing and few other preparations.
Work done
  • Engine Oil Change
  • Oil Filter Change
  • Air Filter Change
  • Steering Stem fastener bush change
  • OBD scanning
  • Torque check of all bolts
  • Chain slack adjustment
  • Chain clean/Lube
  • Rear brake pad replacement
  • General check up
Total servicing cost : ₹ 5839.00 including rear brake pads (costing ₹ 3300.00)
Few pics from the third free servicing.
Odo reading during the third free service
Opened up and awaiting servicing.
Must mention here that Mr Nitin, the head technician of Kaytee RE who is also OEM trained on Himalayan is a sincere soul who is really good at his work.
Oil filter being changed
The new oil filter dipped in fresh engine oil prior to installation : a good practice
In goes 2.1 litre of Liquid Gun
The air filter seemed to have lived it's life and was replaced
The rubber bushes of steering stem fastener were changed and the bolts tightened to correct torque specs
OBD scanner was used to diagnose problems, if any
All parameters were found to be satisfactory
General check up details
Odo reading : 11727 kms
Got this servicing done after returning to Delhi from the Spiti ride. It was a well deserved pampering of Bagheera who took all the beating at Spiti without batting an eyelid.
Work done
  • Air Filter Cleaning
  • Air box cleaning
  • Steering Stem fastener kit change
  • Chain clean/Lube
  • Both brakes servicing
  • General check up
Total servicing cost : ₹ 1318.00 including Steering Stem Fastener Kit(costing ₹ 720.00)
Few pics from the general check up
Odo reading during the general check up
Awaiting service at the bay
The air filter housing was found to be full of fine dust. Hence taken out for thorough cleaning
Surprisingly, the throttle body was found absolutely clean
A rare view of the engine head. Notice the spark plug
Another rare view of the hardware : the radiator fan
An interesting fact : the HT coil is attached to the air box.
The air intake was also found completely dirty and required thorough cleaning
The air box after thorough cleaning : spick and span
The steering stem fastener kit was changed for the third time : problem was excessive play in handlebar.
The culprit : worn out stem fastener rubber bush
Both bushes were found damaged.
Some "kat kat" noise had developed from front end due to centre nut getting loose. The same was changed as part ot the steering stem fastener kit
Correct torque application using the torque wrench
Thread locker applied to both steering stem fastening bolts.
And finally correct torque application to steering stem fastening bolts
The front sprocket cover was removed and sprocket cleaned thoroughly
Overall, decent work done to satisfactory standards by the technicians at Kaytee RE.
Have covered more than 6000 kms in last 18 days. And I must say, I'm more than happy with my decision to add Bagheera to my stable. Hoping to cross many more milestones and make many more memories together.
PS : Spiti ride details coming in travelogue section soon.
aviator1101 is online now   (59) Thanks
Old 14th October 2024, 20:01   #890
CrAzY dRiVeR's Avatar
Thanked: 79,136 Times
Not sure if this was posted before, and everyone watched it. Chris from Bike World did a rally on an almost stock Himalayan. The experience documented here -
CrAzY dRiVeR is offline   (4) Thanks
Old 15th October 2024, 17:14   #891
Thanked: 23 Times
Originally Posted by RaviSk View Post
Update : vehicle is at 7800 km and APS sensor failure appeared again. will take my vehicle to service center once again.
Changed all the wiring on my H450 ( as company recommended) and took it on a Ladakh trip the very next day. I completed 3,500 km with no errors in sight. The bike performed beautifully, but I bent my front rim, though.
also 3rd service invoice attached after laddkh trip. + 2100/- for front brake pads.
+ The front indicators (due to buzzy noise) and front brake light switch are due for a change under warranty, and the parts have been ordered.
RaviSk is offline   (5) Thanks
Old 16th October 2024, 21:37   #892
rishi.roger's Avatar
Thanked: 597 Times
I am reading about a lot of cases of bent rims. In my understanding these rims are from Excel Malaysia which produces high quality products. So is it that the owners are pushing the machine to the extremes leading to this or there is legit issue with the product in itself ? We can't blame RE here for sure as RE doesn't manufacture them, it simply procures them.
Anyways, the thing I am trying to put forward here for discussion is that if the Excel Rims are getting bent so easily - what are we expecting from the relatively cheaper rims from some Indo-Chinese collab company that is being procured for a substanially cheaper cost.
Or is it that people are actually blowing the bent rim examples out of proportion since off-road units do tend to get their rims bent. Isn't that why rims are given in the first place so that they can be repaired on the go (mostly).
Ps, I have ordered the cross spoked rims a while back from RE CO dealership but they don't have any news about delivery yet. Running the tubeless conversion done Excel rims for now - and it's working well so far.
On a side note, has anyone here used a Rear Paddock stand with Himalayan 450 ? For those of you pulling your hair out on this question, there are some of us who have removed it for weight savings and hard stop sound when not having resonator box in its intended place. I recently purchased one but I can't seem to find a correct way to place it under the swingarm. It makes we wonder if the swingarm design even allows the room for it ? Is there any scope of using bobbins ?
rishi.roger is offline   (2) Thanks
Old 17th October 2024, 21:53   #893
Thanked: 23 Times
In my case, that was totally my fault. bumped my bike at 70-75 km/h into a big stone (lying on the road) on an otherwise smooth road. Somehow, I managed to keep control of my bike and was pretty sure the rim was completely gone, but to my surprise, it was only a little bent.
That rare moment when I enjoyed having tubed tyre.
RaviSk is offline   (7) Thanks
Old 18th October 2024, 11:54   #894
MileCruncher's Avatar
Thanked: 1,378 Times
Himalayan 450 Sales Figure
Is the Himi 450 a sales success in India?
Reason I ask this question is because still I'm not seeing enough numbers of them in Mumbai streets. And this begets the questions, how many are they selling monthly in India and how many are going for export. Any data points?
MileCruncher is online now
Old 18th October 2024, 12:11   #895
b16h22's Avatar
Thanked: 2,813 Times
Re: Himalayan 450 Sales Figure
You can find the August 2024 figures here. About 2k units, which is decent for a 400cc motorcycle.
https://www.team-bhp.com/forum/motor...ml#post5848326 (August 2024: Indian Motorcycle & Scooter Sales Figures & Analysis)
b16h22 is offline   (1) Thanks
Old 18th October 2024, 12:13   #896
Thanked: 845 Times
I see them in Hyderabad but not in large numbers. But in Himachal Pradesh, and Ladakh, every 2nd or 3rd bike on the road is a Himmy 450. Most of them being rentals.
amyntor is offline   (2) Thanks
Old 18th October 2024, 13:18   #897
The numbers are very interesting. From 3.3K Unit in May 24, its dropped down to 2K Unit in August24.
This could be either because:
  1. Guerilla is taking some of the Himi 450 volumes
  2. Initial euphoria over, sales are stabilising.
But still the numbers are better than KTM 390 by a large margin.
And another thing to note is its selling almost 70% of Xpulse numbers inspite of being 2X more expensive.
Kudos to RE team!
MileCruncher is online now   (1) Thanks
Old 18th October 2024, 15:59   #898
balenoed_'s Avatar
Thanked: 5,677 Times
Question on this tubeless rim. Will there be tubeless rims of two types, one the orange one for Hanley Black models and one for rest of the models? Or will everything get orange? Or everything gets normal steel color?
balenoed_ is offline
Old 18th October 2024, 17:31   #899
Turbojc's Avatar
Thanked: 1,925 Times
Hi @balenoed, for brand new bikes specced with the tubeless spoke wheels, only the Hanle Black version will come with the golden rims. All the other colour options get black rims. Existing owners however are free to choose either the golden or black rim, as per their preference.
Cheers!
Turbojc is online now   (1) Thanks
Old 19th October 2024, 15:36   #900
Thanked: 282 Times
Got the joystick replaced at the service centre yesterday. Working fine now. I think the issue is not the joystick, it's the connector - I saw a video where the creator came to this conclusion.
It makes sense to me because my mode button was also not working, but it is now. They only changed the joystick and the wiring it comes with.
Here's a link to the video -
Hopefully this fix is permanent, or at the very least holds up through my upcoming long ride.
