Old 12th April 2025, 07:40   #2581
Thanked: 789 Times
Re: Leh, Ladakh and Zanskar - The Ultimate Guide
Originally Posted by Love4Cars View Post
Please suggest with your insights.
4x4 is needed when you are trying to do offbeat tracks in Ladakh. If you are going to do the typical circuit, any car would do. I did Ladakh 12 years back in my humble Ford Figo.
The only suggestion I'd like to give is, take a car that has good space for all your luggage since 4 of you are traveling together.
shipnil is offline
Old 20th April 2025, 22:05   #2582
Was curious, do these "6L oxygen Can" being sold around actually work ?
Or a proper cylinder is the only way to go ? If so what size should be taken ?
I understand that if we see AMS symptoms the only right thing to do is to descend.
automash is offline
Old 24th April 2025, 19:33   #2583
Thanked: 50 Times
Originally Posted by rakutty View Post
@rakutty & @automash - my start date is also May 1st. Now as the region's situation is escalating, I am wondering what you folks are planning.
I am still thinking of pursuing with the original plan, and take a call after hitting Ambala. If situation look right, we may push further on to Ladakh, else we would fork out to Himachal. Just wanted to get your views as well please.
mikepapa is offline
Old 28th April 2025, 10:36   #2584
Thanked: 351 Times
@mikepapa my Leh journey was a part of the longer 28day road trip to Tuljapur, Ujjain, Ranthambore, Mathura, Dehradun, Kashmir,& Leh. We had already started with the journey when this happened.
With the changes in the valley i was not comfortable driving though Srinagar. Also we dont know when the roads will close for whatever reasons. So to do away with all these uncertainties (if ,then, else) we have decided to not do the Kashmir Leh part for this year. We are going to be doing off the grid Himalayan hikes and villages in the Chamba areas .
rakutty is offline
Old 28th April 2025, 16:20   #2585
I have dropped this plan as well. It is not worth the risk according to me.
I will be driving to Delhi on 1st and then take a call on where to go. Currently thinking of turning towards Spiti via Shimla. Will update if I am able to make and concrete plan.
automash is offline
Old 29th April 2025, 12:45   #2586
Hi, I am travelling from Bangalore to Ladakh (via Jammu-Srinagar-Kargil).
Leaving on 1st May. We can keep in touch and exchange information or do some part of the trip together. How can I contact you? I am new to this forum.
sujithbhat is offline
Old 29th April 2025, 16:13   #2587
KSingh's Avatar
Thanked: 142 Times
I’ve planned a trip from Chennai to Leh in mid-May. The original itinerary was to travel via Srinagar to Leh and return through Manali. However, due to the recent developments following the Pahalgam attack, I’m uncertain whether it will be safe to stick to this route or if I’ll need to take the Manali route to reach Leh instead. I’m scheduled to arrive in Srinagar on 17 May. Any updates on the current status or expected opening of the Manali-Leh highway around that time?
KSingh is offline
Old 30th April 2025, 00:32   #2588
Your plan is still happening on 1st May?
Old 30th April 2025, 08:13   #2589
nareshtrao's Avatar
Thanked: 1,122 Times
Folks, Please do some more research and check with the appropriate authorities and destination sources before leaving. There are reports of lots of closures of various spots across J&K by the govt. as a precautionary measure. Additionally many sections of the roads are also reportedly closed intermittently. You do not want to be stranded half-way unable to proceed.
nareshtrao is offline   (3) Thanks
