Old 11th September 2011, 18:21   #2461
Guderian's Avatar
Thanked: 1,459 Times
Re: Mahindra Scorpio : Issues & Solutions - Use of spurious/ defective Clutch parts
Originally Posted by hvkumar View Post
Yes, that appears to have been the case, which is why the engine started racing occasionally in the higher gears (and also how I discovered something was wrong).
Any further updates after the M&M chaps contacted you ?
Guderian is offline
Old 11th September 2011, 18:25   #2462
hvkumar's Avatar
Thanked: 3,467 Times
Ganpati Bapa Morya! Inspection by M&M was scheduled for Saturday but postponed due to ongoing Ganpati festivities in Bombay region.
I discovered today that the clutch pressure plate used by Global Gallarie, Thane, is not the correct specs - it says it is meant for CRDE, whereas my Scorpio is the non-crde model! AFAIK, the 2 models have different clutch plates!
hvkumar is offline
Old 11th September 2011, 18:29   #2463
Guderian's Avatar
That may have been one more or the only reason if the dimensions are different !
Guderian is offline
Old 12th September 2011, 10:55   #2464
SPIKE ARRESTOR's Avatar
Thanked: 1,545 Times
Both clutches are 240 mm dia IIRC. CRDe clutches have higher FOS and have been made standard across "most" models. There is no harm if you use a higher FOS clutch on a Non-CRDe Scorpio.
Spike
SPIKE ARRESTOR is offline
Old 16th September 2011, 17:49   #2465
AVR
AVR's Avatar
Thanked: 873 Times
Hi Scorpio owners,
I own a Safari and am very happy with it. lol. end of message.
P.S.
I find it a bit odd to post on this thread as this has always been the "other side" but c'est la vie.
Ramkya1 and I recently did a trip to Lonavala in his CRDe Scorpio and I enjoyed driving the car so when he mentioned he's going in for a replacement, I asked him to pass it on to my fiancee who's not been able to decide on a vehicle for a year now but was suddenly tempted by the idea of driving a Scorpio. She's very happy driving it but a critical thing that I feel the Scorpio needs is a rear windshield wiper.
Can someone suggest if I should go to an authorized workshop? This is the first ECM-based vehicle that I am trying to play around with and I don't understand electric stuff. period. So please guide accordingly on the following things:
1) What all needs to be changed/added?
2) What would be the costing?
Thanks again,
Adi
(From the other side aka Safari owner/lover)
AVR is offline
Old 16th September 2011, 19:40   #2466
Thanked: 151 Times
Originally Posted by AVR
Hi Scorpio owners,
P.S.
Thanks again,
Adi
It depends on how far you want to go with it. You can simply add a rear wiper motor and arm (assuming the holding mount is already there) and a switch upfront. For more detailed install, you can check if the steering mounted controls have provision for rear wiper and replace it if not. Cost wise, it should be about 1.5k
gharika is offline   (1) Thanks
Old 16th September 2011, 19:40   #2467
SS-Traveller's Avatar
Thanked: 28,767 Times
Originally Posted by AVR View Post
... I feel the Scorpio needs is a rear windshield wiper.
...you sound like the 249 pages of this doesn't exist!
Your solution is simple. Don't fiddle around with the existing circuitry. Add a standard wiper motor to the rear door, and run a separate wiring and fuse to the dashboard to install the control switch. You can build in intermittent wipe into the circuit too, and power up the whole system through the ignition power supply.
Cost ~ 1500-2000 INR including the motor and wiring would be my guess - will depend on the electrician doing the job.
SS-Traveller is offline   (2) Thanks
Old 16th September 2011, 20:20   #2468
ramkya1's Avatar
Thanked: 434 Times
This is a precision job, the ASC hates to do it, the hole has to be exact; reportedly even a few mm can much up the whole thing. That's why I did not attempt to fix it.
Yes to the wiring and everything else SS said about it. About the cost at the ASC would be about 4 K.
--Ramky
ramkya1 is offline   (1) Thanks
Old 17th September 2011, 10:05   #2469
MileCruncher's Avatar
Thanked: 1,374 Times
@AVR: This might be a far shot, why not change the rear door itself. You can definitely get an accidental piece for cheap and exchange with your present door. And then do the electrical circuitry as SS mentioned.
MileCruncher is offline
Old 17th September 2011, 10:57   #2470
Originally Posted by MileCruncher View Post
...why not change the rear door itself.
Naah - no way would I suggest changing to an accidental door. How much would a new rear door cost anyway? And the cost of repaint? Methinks drilling a hole to take the wiper motor spindle should not be rocket science, just a matter of positioning the centre of the hole correctly. Mercifully, the motor is not mounted on the rear glass as in some other cars.
Old 17th September 2011, 11:08   #2471
AVR
AVR's Avatar
Thanked: 873 Times
Thanks guys. Changing the door will be too costly. Will enquire with a smart electrician I know and see if he's willing to do any jugaad so to speak.
Dumb question but does the ecm get affected by any electric circuitry added? I am, somehow more comfortable changing an engine on a non-electronic vehicle but very cautious on adding anything to a ecm-driven vehicle!
AVR is offline
Old 17th September 2011, 11:30   #2472
ramkya1's Avatar
Thanked: 434 Times
MhHWK ELECTRONICS GOING APES!!!
1. The microhybrid does not kick in. 1 kms after switching on it's supposed to cut the engine when you engage neutral and idle at signals; does not happen regularly. It's like the fasting season for our politicians, has a mind of its own.
2. The hand brake warning voice over comes on when it wants, I deliberately engaged it and moved yesterday, it chose to remain silent!!
3. Don't understand the rain sensor, read about how it works etc., know the technology. When it's on & when it rains hard (fortunately the rainy season is also going apes and is on now) it does not move, sometimes when it drizzles the wipers do a frenzied act!!!
Been driving on heavy rains and doing some wading on roads Looks like the whole thing needs to be checked with a ASC lappy or the module changed.
Any suggestions?
--Ramky
ramkya1 is offline
Old 17th September 2011, 11:35   #2473
ramkya1's Avatar
Thanked: 434 Times
Adi,
Do this slow and careful, it's not that simple, only a good electrician in combination with a lathe guy can drill that hole accurately. If you want to add a washer to the rear too, you need plumbing.
As far as I know, wold not affect the ECM in any way.
--Ramky
ramkya1 is offline
Old 17th September 2011, 15:20   #2474
Ramky is right...
Sensor trouble!
MicroHybrid malfunction is most likely related to clutch pedal position sensor.
Handbrake VMS - does the red light on the dash light up but the voice doesn't speak? Or do both don't work?
Rain sensor - switch off and on again if it acts funny. Or use the mist-wipe function once to stop that frenzied act.
Old 18th September 2011, 22:42   #2475
ramkya1's Avatar
Thanked: 434 Times
Ramky is right...
Sensor trouble!
Tnx. Will check out the clutch pedal sensor.
The red light comes on but the voice does not speak; today everything worked perfect.
Will try the mist wipe function and report.
--Ramky
ramkya1 is offline
