Old 18th January 2024, 10:16   #556
Thanked: 9 Times
Re: About clutch wear & replacement
Originally Posted by mithun View Post
Clutch slippage usually happens at higher gears when the clutch is in the death-bed. Soon it will slip in any gear at any speed.
If the vehicle is abused, then a clutch replacement can happen even at 15K KMS.
Go to a competent garage ASAP.
Is there any chance a clutch line bleeding would cure the issue? This issue seems to have arisen after a brake and clutch fluid change. Baleno Diesel has a hydraulic clutch. The car is driven in a sedate manner and has not been abused in any way. The clutch seems to be fine in all other aspects. Wondering whether a clutch line bleeding for trapped air would cure the issue. Any thoughts??
babukvishnu is offline
Old 18th January 2024, 10:27   #557
Thanked: 268 Times
Clutch bleeding will help if:
1. The clutch pedal is spongy.
2. It is difficult to disengage the clutch
3. It's hard to shift gears.
mithun is offline   (1) Thanks
Old 18th January 2024, 17:06   #558
Thanked: 9 Times
Thank you for the prompt responses. I had the vehicle inspected by a MASS mechanic suggested by a friend of mine. He was of the opinion that the gearbox oil seal might be failing and gearbox oil might be leaking and might have contaminated the clutch disc and hence the slipping clutch. A visual inspection of the gearbox did not reveal any oil leakage signs and hence he was of the opinion that the leakage might be negligible and minor and the vehicle can be safely driven for another 20k or more and when the problem worsens,the gearbox can be dismantled and issue rectified.
Old 18th January 2024, 17:08   #559
Thanked: 9 Times
Can the clutch pedal free play of a hydraulic clutch be adjusted?
Old 30th January 2024, 20:38   #560
PearlJam's Avatar
Thanked: 1,829 Times
As updated previously, my clutch was replaced a few months ago due to slippage, and now there is absolutely no slippage. There is no issue in slotting the gears too.
However, I sometimes face a shudder when going at extremely slow speeds in the 1st gear (like in crawling traffic). This happens during half clutch only, and once the vehicle picks up speed, everything is perfect. It can happen either when starting from cold state, or can happen after driving for a long time - so I don't see a pattern that can be attributed to "heating" of the clutch plates.
The key word here is "sometimes". When this problem does happen intermittently, I have noticed that the clutch pedal feels a bit "grainy" or "sandy", and not perfectly smooth.
Could this be a bad master cylinder? Or bad slave cylinder? Or both? These were not replaced when the clutch was replaced.
Or, could it just be air in the lines and needs bleeding?
Thanks!
PearlJam is online now
Old 30th January 2024, 21:44   #561
SunnyBoi's Avatar
Thanked: 4,461 Times
Nope
Thanks!
Bleeding the clutch line will definitely help, do it first. If the problem reoccurs, one of the two components is bad and will need replacing. Its almost always the slave cylinder that goes bad - master cylinder going bad is not common.
SunnyBoi is offline   (1) Thanks
Old 19th February 2024, 11:34   #562
PearlJam's Avatar
Replaced the slave cylinder, and the problem is fixed now. Verified under various city conditions for few days. Thanks Sunny!
PearlJam is online now   (2) Thanks
Old 28th February 2024, 11:20   #563
febin8055's Avatar
Thanked: 78 Times
Dear Fellow BHPians,
I'd like to share an issue I've been experiencing with my VW Polo, in the hope of gaining your insights and hearing if anyone else has had similar experiences.
In brief: I bought my Polo back in 2012, brand new, and it has since clocked roughly 108,000 kms. Up until 40,000 kms, I was the primary driver, and since then, my wife has taken over.
The clutch was replaced at 102,500 kms at an authorized VW service center in late October 2022. Since then we've covered an extra 6,000 kms on short-distance drives, 90% of time in rural Bangalore. However, this new clutch unexpectedly failed on 23rd February 2024, leaving the car unmoved even with the gears functioning smoothly. We had to get the car transported to the Hosur service station, where they concluded that the newly installed clutch was damaged and needed replacing.
I am utterly perplexed at the short lifespan of only 6,000 kms for the new clutch. In fact, since the first clutch lasted about a 100,000 kms with the same driving pattern, this seems absolutely puzzling.
The service center team strongly suggests that the damage could be due to improper driving. However, the driver and the usage pattern have remained the same and the logic given by dealership does not make any sense to me
I have taken up this issue with VW India and they maintain the stance of the dealership, attributing the problem to driving habits. This to me feels like a convenient dismissal, rather than a thorough investigation and resolution. I feel confident that the damage is either due to a faulty part installed or incorrect installation process, and not negligent/improper driving.
I would like your opinions on this. Has anyone else faced a similar issue or can provide any insights into this perplexing problem? Your feedback would be greatly appreciated.
Best regards,
Febin Mathew.
febin8055 is offline
Old 23rd March 2024, 17:13   #564
Thanked: 154 Times
Update:
I finally got this repaired by Hyundai. They said that the gear box oil had leaked into the clutch system, and that's the reason for slippage in higher gears. Apparently the oil seal breaks with age after some years, so it's not an uncommon issue. Since the gearbox is designed to always have a reservoir of oil below a certain level, it will never seize.
They changed the clutch plate, pressure plate, and release bearing, since it was already near it's end of life, and also got contaminated with oil. The flywheel was fine so didn't need a replacement.
The gear box had to be opened up to fix the leakage. I was a bit apprehensive, but the SA assured me that it was simple and routine job of just fixing the seal. "All in a day's work", and "we're not a roadside garage, this is nothing new for us" assurance from them .
They did a fantastic job, to their credit, and the car was returned in 24 hours flat, with regular WhatsApp updates about the status, along with pictures. Contrast this with the painful experience of just changing my VW Polo battery, but that's another topic
Absolutely no slippage now, with a softer clutch pedal as bonus. The clutch action from standstill is a bit aggressive, though. I remember this was how it was when the car was new. Cost me around 16k.
Looks like same situation as my car. To repair the sealant they opened gear box and then said it is better to replace clutch plates etc as you can save labour costs and quoted tentative cost as 18k.
sirius is offline   (1) Thanks
Old 7th May 2024, 15:05   #565
kavensri's Avatar
Thanked: 853 Times
I need inputs from the experts here.
My Etios Liva GD has run more than 1.4l kms and Clutch has become hard now. I want to get it replaced from authorized service center.
When check with them, they are quoting around 15k for the parts (whole clutch assembly) and around 3.5k for labour.
As I do not know details about these things, I want to know if this is reasonable.
If not, can I go to any other car garage and get it replaced if the cost difference is high?
kavensri is online now
Old 7th May 2024, 15:14   #566
sagarpadaki's Avatar
Thanked: 6,799 Times
Sounds about right for the labor cost. Outside you may save around 1000 rupees compared to TASS. For clutch plate to be replaced, the gear box, driveshaft and in some cars even the subframe has to come out. It is a labor intensive job and will take 3-4 hrs from start to end.
The following parts are usually replaced
1. Clutch plate
2. Pressure plate
3. Release bearing
4. Clutch Slave cylinder.
Flywheel can be checked for condition and re-surfaced. But TASS will only replace
Use fresh gear oil unless you have replaced the gear oil recently. In which case the same can be re-used
Old 20th May 2024, 11:43   #567
Thanked: 9 Times
In a Baleno Diesel variant ,is the clutch release bearing and clutch slave cylinder two different parts or is it a single part? The vehicle has clocked 150k kms and the last clutch change was at 98k kms. Clutch disc, pressure plate and release bearing along with flywheel was changed during the 98k service. Unfortunately,the clutch has started slipping in higher gears and the mechanic suggested a slave cylinder damage as a likely cause. He says release bearing and clutch slave cylinder are two different parts. Is that right?
Old 27th May 2024, 18:30   #568
Clutch and Gear Issues - TUV 300
Guys,
Hello,
I am Abhi and am new to this forum although I've been following the Team for many years now.
I just wanted your advice on a problem I've been having with my car for about a year now. I have a 2015 TUV 300. Lately, I've had multiple issues with the clutch and gear shifting. In September 2023, during a routine drive, the vehicle stalled in the middle of the road (the clutch had started to feel loose and smooth/spongy for a few days before that incident and the gear shift was hard and sometimes, was unable to shift from neutral to 1st unless I switched off the engine and switched it on again). I got the vehicle towed to a highway mechanic. The clutch disc, pressure plate and release bearing were replaced (all OEM parts). Although not smooth like butter, the clutch seemed ok after the replacement. But the issue with shifting gears remained although surfacing intermittently.
I took it to Bosch Service in April and they said it might be the master cylinder since the clutch disc, pressure plate and release bearing had been replaced recently. They replaced the master cylinder. Heaving a sigh of relief that everything would be OK now, I took the vehicle from Bangalore to Kerala to attend a function. It drove fine and I didn't notice any major problem with the gear shift or clutch except when I was in slow-moving traffic.
The gears were hard to shift in lower gears and the clutch was a bit hard. The next morning, after reaching Kerala, I thought of taking the vehicle to a good mechanic and looking into the issue. I had driven about 20 km from home when the vehicle stalled again and refused to shift into gear while the engine was running. I started the vehicle while in 1st gear and was able to limp to the nearest workshop. They examined the car, removed the gearbox and concluded that the flywheel was gone as its spinning surface had reduced from one end only. They said it couldn't be machined and that the entire set i.e. the flywheel, clutch disc, pressure plate, release bearing and also the starter motor needed replacement as this was a known issue with 1st generation TUVs. Mahindra recommends the replacement of the set ACC to them. Believing them, I replaced the entire thing.
I drove back to Kerala a couple of days back and unfortunately, the clutch travel (pushing the pedal down and up) feels rough (like grinding) sometimes. No noise or vibrations though. Mostly in slow-moving traffic and lower gears. There are little jerks while reversing the car as well. Also, I noticed yesterday that upon plugging in the key and turning it for ignition, it's as if the vehicle is struggling before eventually starting. I am at my wits' end trying to figure out what the real issue might be. Any insights would really help.
Thanks.
Abhi
Last edited by Aditya : 28th May 2024 at 19:11. Reason: Edited for better readability
maverickk.one is offline   Received Infraction
Old 30th May 2024, 16:34   #569
Thank you Aditya. Could anyone please advice me on this.
Thank You
Abhi
Old 14th June 2024, 06:10   #570
Thanked: 126 Times
Hi to all following this thread, hope you're all doing great!
Can anyone of you suggest me a good place to get my clutch set checked and replaced if necessary? I live in Bangalore.
drive1987 is offline
