Old 11th November 2020, 12:28   #346
balenoed_'s Avatar
Thanked: 5,676 Times
Re: Mahindra Scorpio : Tyre & wheel upgrade thread
In the current variants, the S9 variant does not come with Alloys. I am planning to go for alloys (new car purchase), and is that a good idea? If so, is there something that I need to be wary of. Does the alloys have the same width for the stock tyre to go in exactly like how it was with steel rim?
The alloys costs a bomb as part of dealer accessory and not many designs to choose from. Whereas there is no dearth of choices from outside. Can I go for an outside shop which also looks to be cheaper and great choices available. Any warranty issue would pop up? Any thoughts overall?
balenoed_ is offline
Old 8th March 2021, 16:43   #347
Prithvi's Avatar
Thanked: 26 Times
Planning on changing my 5 year old 28000km done OE tires on my Scorpio S10 AT to the BFG AT 265/65/R17. Will this upsize work as the stock is 235/65/R17?
Prithvi is offline
Old 8th March 2021, 18:14   #348
hserus's Avatar
Thanked: 9,322 Times
Use a tyre calculator like the one on tyrestore.in and see for yourself
Current RR: 368.65 mm
New RR: 388.15 mm
Current circumference: 2316.29 mm
New circumference: 2438.82 mm
Difference in circumference: 122.53 mm or 5.29%
It should be 2% or less to be a feasible upgrade.
You can try 255/60 R17 - barely 0.8% difference and some good tyres. Do you really need all terrain tyres? If not highway/terrain ones give you far more choice.
hserus is offline   (1) Thanks
Old 4th August 2021, 09:52   #349
Thanked: 545 Times
Need a recommendation.
My Bridgestone Dueller 235/70/R16s are nearly 8 years old and have covered close to 55ks. While the tyres in general are good for another 5000 kms, my regular tyre maintenance guy mentioned that the quality has gotten impacted on account of the lock down and limited running of the tyres (I do move my vehicle in and out, drive around in my building)
With the age, I presume it is normal for the wear and tear. I am thinking of swapping to newer tyres in the near future.
I see that the Falken Wildpeak AT 01 and Falken Wildpeak HT 01 are available for under 7k per tyre. Do we have any feedback on it?
My understanding is that for Scorpio 2010 model, it is recommended to stick with either the JK's or Bridgestone. Would it be good to try out other brands like Continental, MRF or Good Year
diwakarmuthu is offline
Old 4th August 2021, 10:00   #350
hserus's Avatar
Get Michelins if you like and you can justify the extra cost by higher running. Else get MRF.
hserus is offline
Old 4th August 2021, 10:57   #351
Kosfactor's Avatar
Thanked: 11,229 Times
Considering the age of the current tires, any new set will feel better. Avoid AT tires, the ride will become harsh and noisy. Use an HT tire instead. MRF Wanderer used to come factory fitted in certain batches.
The proper replacement is Bridgestone Dueler D689 105 S, it is worth it.
Kosfactor is online now
Old 13th December 2022, 15:54   #352
mr_hardcore's Avatar
Thanked: 130 Times
Hello All,
My Dec'2018 S-7 has now crossed the 110K mark and is due for a tyre change, the third set.
First set was a mistake of aftermarket alloys and Accelera 255/55/18 which served for a mere 45K kms, second set: S11 OEM alloys +Yokohama Geolander SUV 255/60/17 profiles done 65K+ kms with another 5-8K kms bite left.
Just wanted to check if someone has used Maxxis Bravo 980s (255/65/17) on Scorpio? If yes, will it be a recommended change?
I would have preferred BF Goodrich, however, the desired profile is not available.
mr_hardcore is offline
Old 12th January 2024, 11:11   #353
Thanked: 1,329 Times
Hi everyone,
I see that this thread has not been active for the past year but still, it's better to post here than start a new one.
So, my dad's 2016 Scorpio S4 is with me temporarily and I noticed that while the tyres have maybe 3000 Kms of life, the rubber is almost fully infested with micro cracks. They're Apollo Apterra HP 235/65 R17 104H tyres.
The car has done 38200 kms as of now. The distance is minimal but the tyres are 8 years old now as we speak. So I went to one tyre specialist who deals with Apollo, Bridgestone and Yokohama. He quoted the below prices.
Apollo - They have a few models ranging from INR 12000 to INR 14850
Bridgestone - INR 14400
Yokohama - INR 14000
I went to the MRF franchise centre after that and checked with them.
MRF Wanderer Street - INR 11000
The Scorp is RWD and mostly used for City and Highway runs, that is, there is no point in off-road or heavy tread tyres and hence only highway tyres are being looked at.
All the above tyres are from really good brands indeed but the price difference between MRF and the rest is substantial (difference of 12K approx for four tyres). Please give me some pointers regarding the pros and cons and other points to consider.
Many thanks!
that_sedate_guy is offline
Old 9th April 2024, 03:17   #354
Thanked: 963 Times
MRF Wanderer Streets may not be the best out there but they will be more than good enough for your usage pattern. My first choice would be Apterra HT2 but the MRFs' are not that bad for the price. I'd suggest you to negotiate for the HT2s' or go ahead with the MRFs'.
Amrit@wheels is offline
