Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 18th August 2008, 17:10   #61
DirtyDan's Avatar
Thanked: 1,671 Times
Now that this is completed maybe we can get him to paint his front and grill. Something must be done!
DirtyDan is offline
Old 18th August 2008, 20:53   #62
headers's Avatar
Thanked: 564 Times
No, bad idea. Please note that forward wheels are used for steering the vehicle, front wheels turn in different speeds everytime you turn the steering. You will break the axle in no time.
Sir, I am a little confused about the lockers, they are lsd to me if there is no lever / switch to turn them on/off. And if it is LSD then you can use them in the front / back.
Also, there are enough vehicles which full have Diff locks in the front.
Agree that, we should NOT use them on hard ground.
Originally Posted by khan_sultan View Post
. This will be done every 10K Kms and also before that if there is any abnormal behavior.
Shanavaz, you need NOT open the diff every 10K kms.
BTW, are these full lockers or LSD? I'm zapped here. if there are full lockers, how can you turn the vehicle in high speed ?
headers is offline
Old 18th August 2008, 20:59   #63
khan_sultan's Avatar
Thanked: 6,476 Times
Originally Posted by headers View Post
... BTW, are these full lockers or LSD? I'm zapped here. if there are full lockers, how can you turn the vehicle in high speed ?
They are full lockers and not LSD. They are always locked and their design is such that they unlock during cornering/turnings. (A spool will NOT allow differentiation of wheels during turning. NOT a locker)
Here is the link to Lock Right Locker Website that explains it's working:
A quote from the website:
The LOCK-RIGHT's operation is fully automatic..... While traveling straight the LOCK-RIGHT will lock the axles together similar to a spool. However, when the wheels need to differentiate in a turn, the LOCK-RIGHT will allow the outside wheel to rotate faster to complete the turn. The internal gears on the LOCK-RIGHT will overrun each other to allow this differentiation.
When operating off-road, the LOCK-RIGHT will always send the engine power to the wheels that need it most. For example, if you are rock crawling and one wheel is in the air (complete loss of traction), the wheel on the ground will receive the engine power and keep you going. Whether it be snow, sand, mud, ice, etc... the LOCK-RIGHT will give you the traction you need.
khan_sultan is offline
Old 18th August 2008, 21:08   #64
gotzuk's Avatar
Thanked: 118 Times
Hi Shahnawaz,
Is the correct part number for the Lock Right rear lockers LR 1510?
I am about to buy one and i want to be sure that i am ordering the right thing.
gotzuk is offline
Old 18th August 2008, 21:12   #65
Originally Posted by gotzuk View Post
Hi Shahnawaz,
Welcome to the club Gotuzk. . You will NOT regret the lockers. Take my word for it.
for Gypsy 413, it is LR 1530 [This is what I had]
For Gypsy 410 it is LR 1510 [Not sure. maybe LR 1520]
Also, there are options to order without the coupler (and use the existing side gear itself). I had the one which replaced the side gear also. Maybe 1510 is the option w.o the coupler. Not sure.
Cheers,
Shahnawaz
Old 18th August 2008, 21:44   #66
1100D's Avatar
Thanked: 4,117 Times
Waiting eagerly to see more on this space.
1100D is offline
Old 18th August 2008, 21:50   #67
Thanked: 571 Times
I am waiting for a drive on this beauty!
HappyWheels is offline
Old 19th August 2008, 01:22   #68
gotzuk's Avatar
Thanked: 118 Times
Cheers,
Shahnawaz
Yes,
I did some search on the part numbers and found that the LR1510 can be used on both 410 and 413 as it retains the stock side gears.
The LR1530, however comes with a coupler meant for the 413, as the stock side gears are not used.
The LR1530 is on the way..
Cheerscheers:
gotzuk is offline
Old 19th August 2008, 01:32   #69
.anshuman's Avatar
Thanked: 11,136 Times
Good to see this lockers fever spreading this fast.
.anshuman is offline
Old 19th August 2008, 08:48   #70
headers's Avatar
Thanked: 564 Times
hey shanavaz, thanks for the info. Congrats on your install.
Are you getting the gypsy to the pondy meet?
headers is offline
Old 19th August 2008, 10:17   #71
Yes,
GREAT.!!!! Good that your ordered the 1530. I would not advise folks to use the existing side gear.
. Nothing lmore exciting than making your 4x4 more capable.
hey shanavaz, thanks for the info. Congrats on your install. Are you getting the gypsy to the pondy meet?
Thanks Vikram. Most probably I will be driving to pondy in my S10.
Old 19th August 2008, 12:45   #72
headers's Avatar
Thanked: 564 Times
Hey, you are prompting me to get my car too..LOL
BTW, which vehicle i come in is a last moment decision. There is a massive fuel shortage in the city today and all my vehicles are kinda Stuck.
My gypsy has the creature comforts too. If there are no fuel crisis, i have no issues in bringing it!
Also, I have recently added "peddars" gas filled shocks to the vehicle to give it a better landing on a jump!
headers is offline
Old 19th August 2008, 13:13   #73
Thanked: 5,408 Times
Dear Shahnawaz - great to see your enthusiasm and attention to detail in doing this job. There is another way too, which uses a multiplate clutch inside the differential unit. It used to be standard supply for some models exported.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline
Old 19th August 2008, 14:28   #74
Thats a huge compliment sir.. Really appreciated. If I can have 1/10th of the enthusiasm and attention to detail as you, I would be more than happy.
It's people like you who are an inspiration for auto-enthusiasts like me.
There is another way too, which uses a multiplate clutch inside the differential unit. It used to be standard supply for some models exported...
Don't know. Would that be a LSD?
Old 19th August 2008, 15:03   #75
Yes you are correct, normally LSD comprises of a wet multiplate clutch under production setups. What you have used is an aftermarket solution provided to you because you cannot change any boundary dimensions. As the parts in your Gypsy are "post-production" fit, I suggest you go a little easy on them and get the reliability quotient established and sorted out before you floor the right pedal to metal.
And by the way - you can dispense with the "sir" bit. It makes me feel old. I am only 23 years old, you know. My medical age does not matter to me.
Best regards,
Behram Dhabhar
