Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 25th August 2008, 13:02   #106
VJ_MAVRICK's Avatar
Thanked: 34 Times
So Shahnawaz bhai i certainly missed the OTR yesterday and thanks for remembering me and calling as well. Had some already chalked out plans and hence could not make it.
Anyways so you got the Lockers tested and how about the TriPhase?
VJ_MAVRICK is offline
Old 25th August 2008, 13:02   #107
DirtyDan's Avatar
Thanked: 1,671 Times
Originally Posted by khan_sultan View Post
  • Literally ZERO tyre slipping in 4wd. It just goes on and on -- over everything effortlessly. Just loved this part.
  • One noticeable difference I feel in OTR now is that I can now make my Gypsy crawl a lot better than before (in relative terms to the MM's). This by itself is such a huge advantage that Gypsy OTR drivers can imagine. This helps as we don't have to rev the Gypsy to bring it into it's power band.
Good! I have been waiting for your test of your new rear lockers. Has this changed your mind about adding any further enhancements? If I am reading your post correctly you had occasion on this run to go uphill in 4x4 mode and around sharp turns? And it worked well on the turns, too? This would stress things a bit, and be a good test, that is why I am asking.
DirtyDan is offline
Old 25th August 2008, 13:15   #108
khan_sultan's Avatar
Thanked: 6,476 Times
Originally Posted by DirtyDan View Post
... Has this changed your mind about adding any further enhancements?
NO. I will have more mods/enhancements done. It's just personal satisfaction of making your 4x4 more and more capable. My end goal would be to have a 4x4 (based on Gypsy) that could be a worthy "Camel Trophy" 4x4.
Having said that, my gypsy in current form is capable of handling most terrains here in India.
Yes. You are right. and this is something I am very happy about. in 4wd with lockers it just goes on and on crawling (again, in relative terms. Gypsy folks would know this) -- and less need of revving the Gypsy to bring it into its power band. The terrain was similar that you would have up there in hills (NOT roads. I meant loose rock pebbles terrain climbs). At times there were shrp turns and NOT just plain turns. They were turns with rocky ruts/ loose rocks.
No problem buddy. There is always a next time. Man, was tooooooo busy and occupied with the locker that I did not even pay attention to the tri-phase. I would post a separate review in the tri-phase thread.
khan_sultan is offline
Old 25th August 2008, 13:57   #109
mjothi's Avatar
Thanked: 233 Times
So, you had fun again in the OTR. Good. Wish it was a pre-planned Else I would not have missed.
mjothi is offline
Old 26th August 2008, 09:27   #110
Mud Terrain Tyres
Friends,
Time to plan the next set of modifications for my Gypsy (To be executed in the next 4-6 weeks).
Have started a thread in the 'Tyres & alloys section'
Geolanders/Maxxis
Need you views on the same.
Mods: Don't know if that thread belongs in 4x4 section or the tyres section or should be merged with this one. Please do the needful if required.
Cheers,
Old 26th August 2008, 09:40   #111
mjothi's Avatar
Thanked: 233 Times
Oh, already started the next mod. Great.
OT: Did you got any recent hike or incentive from your company.
mjothi is offline
Old 26th August 2008, 09:44   #112
Originally Posted by mjothi View Post
....OT: Did you got any recent hike or incentive from your company.
...I WISH..!!!!
I have cut down on all other forms of fun right now -- that includes movies, going out, new clothes, shoes etc.. etc.. etc.. .
Old 26th August 2008, 12:04   #113
mjothi's Avatar
Thanked: 233 Times
...I WISH..!!!!
I wish you include those cigars in these etc. Did you?
mjothi is offline
Old 4th September 2008, 20:40   #114
Got stuck with locker also :-)
Had been to an OTR yesterday and for the first time, after the locker install, got stuck and had to be pulled out.
And if you see the pictures, it seems the most simplest of places to get stuck . Just one of those 'innocent looking rut' that totally sucked up all traction from the front wheels and was more deep than it seemed at first.
See the picture -- one of the rear wheels is in air and the front 2 are simply stuck and just can't move forward and also the t-case is in mud.
Gypsy on Steroids: Lockers installed and tested now-img_0156.jpg
Gypsy on Steroids: Lockers installed and tested now-img_0161.jpg
Apart from this place, the gypsy performed admirably and went through all places very comfortably and the lockers performed perfectly with no stress and literally zero tyre slippage.
Cheers,
Old 4th September 2008, 21:34   #115
4x4addict's Avatar
Thanked: 4,651 Times
Was this because all four wheels spinning or the torque was insufficient to pull out? I think if you had mud terrain tires you would have been able to pull out.
4x4addict is offline
Old 4th September 2008, 21:42   #116
2 tyres were spinning (front right + left rear) and I agree that with mud terrain tyres would have pulled me out. I don't think torque was an issue.
However, even the t-case was stuck in mud -- soo it's just one of those innocent looking rut that really amazes you once you are stuck. You know, 9 times out of 10 you would look at the rut and firmly believe that you an make it :-)
Old 5th September 2008, 05:48   #117
4x4addict's Avatar
The MM540 with the 4 speed kia gearbox has the t case sticking out underneath. I have had the same concern about the t case getting hooked on a rock or something. The newer NGT transmission with the Borg Warner transfer case has the transfer case to the side and doesn't stick out under the vehicle as much.
Old 5th September 2008, 07:47   #118
headers's Avatar
Thanked: 564 Times
Shanavaz, if you have the full locker on rear wheels, then the rear left alone should not spin, theoritically, i.e. even if it is in air, right?
Wonder how it spins in this situation. Yeah, agree with you that the most demure of obstacles can really be AN OBSTACLE to cross over..
Anyways, hope you are having fun as usual
headers is offline
Old 5th September 2008, 09:19   #119
2 tyres were spinning (front right + left rear) and ...
Wonder how it spins in this situation...
My mistake in posting. I meant that there was no traction in these 2 wheels -- one was in deep mud/rut and the other in air.
The rear set of tyres were spinning together and not the left rear alone. The locker worked perfectly fine.
...I have had the same concern about the t case getting hooked on a rock or something...
Just wait for the next set of pictures & report :-)
Old 5th September 2008, 09:47   #120
S@~+#0$#'s Avatar
Thanked: 43 Times
@Shahnawaz: I had the same questions as headers. Good to know your lockers performed as expected.
Eagerly waiting for more pictures and stories. Keep em coming
S@~+#0$# is offline
