Old 2nd July 2006, 17:22   #3826
jkdas's Avatar
Thanked: 1,497 Times
Originally Posted by kb100
JK... Sony 222 is way too meek for sub duties.... I know - I own one!
not even 100W? bridged?
then maybe he shoudl look at 65.2 for sub @ 6.5k
jkdas is offline
Old 2nd July 2006, 17:39   #3827
kb100's Avatar
Thanked: 23 Times
Yup!!... maybe the 502/444 anything but the 222!
kb100 is offline
Old 2nd July 2006, 18:06   #3828
harmon_bro's Avatar
Thanked: 29 Times
NOTE: guys I am planning to use the 222 to drive my Infinity ovals in the rear and not the SUB...
Now tell me if the 222 can drive my rear Infinity ovals.
harmon_bro is offline
Old 2nd July 2006, 18:41   #3829
kb100's Avatar
Thanked: 23 Times
Sure it can.. and will be much better than the HU's in built amp too ! ... How loud do you like your music?
kb100 is offline
Old 2nd July 2006, 19:53   #3830
harmon_bro's Avatar
Thanked: 29 Times
The Infinities sound better when its hooked with an amp...
Old 3rd July 2006, 10:14   #3831
kURETI's Avatar
really............................................ .................................................. ....
kURETI is offline
Old 3rd July 2006, 12:03   #3832
satish_appasani's Avatar
Thanked: 110 Times
Originally Posted by satish_appasani
As a first step to my upgrade, I am planning to put JBL 5" components in the front and power them using my existing Sony 222 AMP. Planning to power the rear speakers directly from HU. Any suggestions? Later i will put a better AMP and woofer. My choice of music is i listen to everything though my priority is smooth Jazz. I want something that plays jazz better but gives decent quality when playing pop or rock or filmi music. I also listen to podcast. Then I put my Equalizer preset to Vocal and that sounds good.
Any suggestions for JBL Compo models?
Still i am looking for a cheaper solution to connect my pocketpc to HU.
On Saturday, I installed GTO 607C components in my car. They replaced the 5" Pioneer coaxials. I got nice pricing due to the influence of Sam. Thanks Sam.
As said, the comps are powered by the Sony 222 2-channel AMP for the timebeing. Have to wait until i add another AMP in few months. I wanted to put the tweeters in the rear view mirror assemblies on either side. But the installer mentioned that the tweeters are big for that. On my insistance he opened the mirror and checked that. Right now, the tweeters are at the corners on the dashboard. Though Sam suggested 507 as they don't require any alteration to the car, i was tempted for 607. The map pockets on the doors were scaled from inside nears the speakers and a spacer was placed on each door to accomodate the bigger speakers.
The sound in the front is much better. Can feel the smooth flowing sound. But can feel the loss of lows because the rear ovals are now playing directly from the HU. Have to bear this until i put AMP.
satish_appasani is offline
Old 3rd July 2006, 12:46   #3833
Sam Kapasi's Avatar
Thanked: 2,479 Times
Congratulations on your first set of components and i am glad you got a good price (Though I have no idea how but enjoy my friend)
Sam Kapasi is offline
Old 3rd July 2006, 12:49   #3834
Sam Kapasi's Avatar
Originally Posted by prince85
Me thinks You are getting confused regarding the model numbers man. Its the JBL CS 300.1 (and not CS 301.1 as you say). And its JBL GTO 301.1 (and not 300.1 as you say)
The JBL GTO 301.1 (rated 204W @ 4ohm) is available for around 13k whereas the JBL CS 300.1 rated (200W @ 4ohm) is available for around 10k i guess.
Both good mono amps but i would pick the JBL GTO 301.1 even though it costs around 3k more than the CS amp.
Sameerji, how do these two amps compare????
It's not often that someone can point something out to my man JK. Thank you prince, I enjoyed that
The GTO amplifier is superior yes, to the CS (As is the nature of all GTO products to CS). However, honestly, the CS monoblock is excellent excellent value for money.
Unfortunately i cannot comment beyond this, as the rules do not permit me to.
That said, it's not often someone addresses me as Sameerji Thank god for that.
Old 3rd July 2006, 14:04   #3835
harmon_bro's Avatar
Thanked: 29 Times
SAM I already have a Sony 222, is it fine to use this amp to drive the Infinity 9361i ovals? I will upgrade to a better 4 channel amp later along with JBL compos once I have the dough. And for now going in for the CS mono block and a sub.
inputs please.
Old 3rd July 2006, 14:22   #3836
airfoil's Avatar
Thanked: 81 Times
Free Air Subs for spare wheel well?
Could I get some advice about which brand/model of free air subs I should be looking for please. I'm not sure about which size would be the best fit, but I imagine a 12" sub should fit in a Palio's 14" upside-down spare wheel rim.
This will go into my Palio and most likely be driven off a JBL 75.4 or a CS 60.4, which will also power the front components.
Front speakers are likely to be GTO 607s and for the rear, I'll shoehorn in the largest speakers (JBL?) a Palio can take within the stock pods.
Thanks!
airfoil is online now
Old 3rd July 2006, 14:30   #3837
Thanked: 110 Times
Is there any ideal position for fixing the tweeters in my Palio. Right now they are sticked to the farmost corners on the dashboard facing skywards. I see lots of accessories in the box but instructions in the manual are not clear to me.
Old 3rd July 2006, 15:44   #3838
jkdas's Avatar
Gurus say that
1) never point teh speaker directly at you
2) if possible direct the right to left and left to right.
comment pls...
jkdas is offline
Old 3rd July 2006, 15:50   #3839
Sam Kapasi's Avatar
inputs please.
Yes. For now a Sony 222 is enough to drive the ovals. It will sound nice.
When you have the dough,upgrade your amplifier, will sound even better
Old 3rd July 2006, 16:43   #3840
Sam Kapasi's Avatar
That would still be 5.25" in the rear, unless you make a pod.
