Old 12th September 2022, 20:56   #2566
condor's Avatar
Thanked: 16,902 Times
Re: Tools for a DIYer
Procure screw extractor of the correct size
Have you tried this ? I was in a similar situation when the stalk of the mirror of my scooter broke. I tried this method, but the bit began to get worn out rather then drilling a hole into the broken stalk.
Or may be these extractors dont work on all types of metal.
condor is offline
Old 12th September 2022, 22:48   #2567
GutsyGibbon's Avatar
Thanked: 5,101 Times
You would need something made from carbon steel. Something that is stronger/harder than the steel that the screw is made out of. If you dont do a lot of tinkering with old vintage stuff, you may never use these extraction bits again. I have cheap ones from discount stores, but have never used it.
Couple things that has worked for me is to file couple sides of the screw to form flat surfaces that you can grip with an extracting plier. The other is Superglue. Super glue the correct size bit into the stripped screw, secure with a tape. Let it set for 24 hours. Now spray some WD40, it should come out with ease. Do not use the WD40 before applying superglue. The superglue may not hold.
GutsyGibbon is offline
Old 13th September 2022, 06:32   #2568
Sebring's Avatar
Thanked: 12,186 Times
Infractions: 0/2 (11)
I use my DREMEL to make a deep wedge and use a flat screwdriver to extract it
Originally Posted by Majumdarda View Post
I had visited the local servicing guys earlier today and requested them to try and remove the screw.
Sebring is offline   (3) Thanks
Old 13th September 2022, 10:23   #2569
Thanked: 3,031 Times
Yes, successfully.
There are few do's and dont's
1. The drill size should be matched to the extractor - I think slightly smaller than the shank of the extractor.
2. Use WD40 or similar to loosen the jammed screw/bolt.
3. The extractor has to be made of high strength carbon steel. Many cheaper stuff is not.
Finally as advised, you can cut a new slot on the screw and use a screw driver, but usew WD40 before that.
Aroy is offline
Old 13th September 2022, 14:19   #2570
Majumdarda's Avatar
Thanked: 1,192 Times
Success at last
Thank you all for your support. This morning I was ultimately able to open this up by a "desi" jugad. Got hold of a good quality screwdriver and a hammer. Since the top of the screw was slightly visible, I had a bit of leverage with this approach.
With the flat head screwdriver, I began to lightly hit the head of the Philips at an angle (anti-clockwise direction). After a few hits and some WD, I again changed the striking location. Though a very little surface area was available, ultimately it budged, and I could extract the screw from the housing.
Lessons learned the hard way and now no more ventures till I get a proper tool set.
Thank you all for your support and the approaches offered.
Majumdarda is offline   (3) Thanks
Old 22nd September 2022, 00:39   #2571
Ashtoncastelino's Avatar
Thanked: 2,282 Times
Hey Guys, Can anyone recommend me a pair of Sturdy Jack Stands?
Ashton Castelino
Ashtoncastelino is offline
Old 22nd September 2022, 00:43   #2572
Thanked: 2,361 Times
Ashton Castelino
Been using Amazon basics 3 Ton and a Stanley 2 ton in pairs, they are definitely good. Big Red is also another reputed brand.
DRIV3R is offline   (1) Thanks
Old 22nd September 2022, 00:46   #2573
Thankyou for that super quick reply DRIV3R. Tending towards getting the Amazon basics 3 Ton pair. How old are yours and how are they holding up ?
Old 22nd September 2022, 15:12   #2574
They are about 2-3 years old, holding well. I use them maybe once in 2 months invariably. Last I checked, couldn't find them in stock. Hence had procured the second set from Stanley. The Stanley ones have an additional safety lock.
Old 1st October 2022, 18:43   #2575
Thanked: 33 Times
Is there anywhere i can procure genuine 3m vhb tape? Amazon only has one listing and that isn't deliverable to me.
I found some on www.planetcarcare.com but do not know the reliability of the site.
I also tried searching for it through mgp and while i can find the adhesion promoter for the tape but no luck with the tape it self
Mumbgamer is offline
Old 3rd October 2022, 10:22   #2576
sagarpadaki's Avatar
Thanked: 6,848 Times
They are pretty good. I have purchased from them. Shipped and delivered on time. Customer service is also responsive over whatsapp
sagarpadaki is offline   (2) Thanks
Old 19th October 2022, 12:59   #2577
Jaguar's Avatar
Thanked: 2,896 Times
Need thoughts on which is the best tool for removing car lug nuts
1. The stock wheel spanner
2. A breaker bar along with the stock spanner
3. 1/2" ratchet drive
4. Cross wheel spanner
I got it from a local hardware store. One 3M car care fellow directed me to the store and said they also procure from the local stores.
Jaguar is offline   (1) Thanks
Old 20th October 2022, 11:18   #2578
If the lug nuts are not super tight then a stock wheel spanner will do the job. A cross wheel spanner is easier to handle, so use it if you have one.
If the lugs are super tight then you may need some more leverage. In that case an extension rod on your 1/2" ratchet or a pipe on the stock wheel spanner is needed.
Aroy is offline
Old 20th October 2022, 11:38   #2579
Stock wheel spanner with a 3/4 inch steel pipe of 1 meter length to act as leverage when needed should be good enough.
If you want something fancy this telescopic handle works very well. I use this
https://www.amazon.in/TSTOP-23768-55...%2C750&sr=8-17
Old 20th October 2022, 12:57   #2580
carthick1000's Avatar
Thanked: 2,905 Times
If you have used a torque wrench to tighten the wheel lug nuts in the first place, then a Stock wheel spanner or a cross wheel spanner should be sufficient for normal passenger cars.
My suggestion is to spend on a quality torque wrench if you can. And btw, if you really cannot exert enough torque with stock wheel spanner, use biomechanics to your advantage instead of carrying around a breaker bar. ie put on gloves or wrap a thick cloth around the spanner handle to increase the grip-span diameter which effectively help you apply more torque.
carthick1000 is offline
