Old 17th November 2011, 15:58   #541
raj_5004's Avatar
Thanked: 3,168 Times
Re: The DATA Card and USB Modem discussion thread (Reliance/Airtel/Tata)
Guys, Planning to buy a USB modem. I am a noob in this. I have heard of USB modems from Reliance Net Connect, Vodaone 3G, Airtel, Idea & Tata Photon.
My usage would be very very minimal, its a substitute to the broadband connection in my office (maybe I would go for a zero rental postpaid plan if available). Requirements are good & strong connectivity, fast browsing & of course, the price. It should be value for money. free roaming would be icing on the cake!
Which one would be apt for me?
@raj_5004; All can be equally good or bad. A lot depends on the signal level and load in your area. I have a Photon+ for two years. No real problems, and I normally get 500+kbps peaking at 1.9kbps. However, in Bangalore recently while the signal level was full, I barely got 25kbps. Must be congestion.
In our area (fringe on all) Reliance was supposed to be bad, but last night on my phone (EVDO) I saw 1.8+Mbps. I will not commit until I see similar performance a few more times.
My suggestion is to borrow a few units, and actually test them out in your location.
Damn! Late reply sir. I just bought Vodafone's USB stick. I actually wanted to buy TATA Photon+, but then thought to give Vodafone a try especially since their store was very near to my place.
raj_5004 is offline
Old 17th November 2011, 19:27   #542
khoj's Avatar
Thanked: 1,288 Times
Re: Buying help - 3G USB Modem Unlocked
Originally Posted by nishantgandhi View Post
So I'm looking to replace my (stupid) Tata Photon+ data card with a more reliable and faster 3G data card.
Since I do a lot of road trips, which takes me to many non-metro and Tier 3/4/5 locations, I feel a service provider like MTNL would suit me best, since they have have BSNL's infrastructure to latch on to. Correct me if I'm wrong.
I used to use a Tata Photon data card, the kind that goes into the PCMCIA slot and had umpteen problems with the same. Changing to the Photon+ USB stick resolved them. My travel profile too used to be similar to your own and most of the times I enjoyed data connectivity even while travelling in trains etc.
However for almost an year now, there are issues with the connect speeds. They average less than 100 odd Kbps on most days and the stick refuses to work when signal input is set to "Photon+" mode only. I have to keep signal input on hybrid mode (photon & photon+) to make it work. The problem remains unresolved even after several complaints to the service provider.
I will look forward to reading about your experience with MTNL/BSNL combo.
khoj is offline
Old 24th November 2011, 23:28   #543
Fillmore's Avatar
Thanked: 597 Times
Appreciate if anyone can give me some inputs here.
Is there any player in the market who can offer a prepaid kind of datacard where you re-charge and have a validity of at least 6 months ?
Reason is my usage would be very minimum, used only when traveling. That too might be max 3 days a month. And for this short duration I don't want go for a monthly rental plan.
For my regular use I have an Airtel landline plan which suits me well.
Fillmore.
Fillmore is offline
Old 25th November 2011, 07:26   #544
sanagg1's Avatar
@nishantgandhi
If you are not going to use this in Mumbai extensively, I would suggest get data card from BSNL from nearby places like, pune, satara etc. whatever suits you.
With free roaming on BSNL 3G you will have good coverage and no interconnection issues.
sanagg1 is offline
Old 25th November 2011, 09:52   #545
nishantgandhi's Avatar
Thanked: 156 Times
Originally Posted by sanagg1 View Post
@nishantgandhi
I bought the Huawei E1732 (Idea branded, but unlocked by seller) off Ebay for Rs 1250. Got an MTNL 3G (Jadoo) SIM yesterday.
I was told by the MTNL official that it will be activated within 24 hours. However, I still went ahead last night and plonked it in the data card.
While it was connecting to internet, the speeds were fluctuating wildly (from 0 kbps to 45 kbps) and never did the connection stabilize. Infact, the signal showed EDGE Dolphin.
Is it not supposed to show Dolphin 3G? Or does this mean that 3G has not yet been activated at all?
Can 3G users on data card confirm what they see in the Huawei connection
window?
nishantgandhi is offline
Old 25th November 2011, 12:56   #546
DerAlte's Avatar
Thanked: 2,920 Times
If the signal strength is OK, you should be able to see HSUPA or something like that. If it is showing EDGE, quite likely the BSNL signal is not so great where you are sitting. Try moving to another part of your place to check what shows up.
The 'fluctuation' you are noticing is the actual speed of transfer - which means you are connected alright. If there is no traffic to or fro your machine, it will show 0. For short transfers, the reading doesn't really convey anything. The average speed during, for example, a large file transfer is what matters. Test your average speed on speedtester.bsnl.co.in. It shows the download speed only, unfortunately, but is a reliable test otherwise. The upload speed will be ~400Kbps. You could also check your speed at speedtest.net.
DerAlte is offline
Old 25th November 2011, 13:16   #547
Thanked: 156 Times
I think because I quoted the post above me, there was some confusion. I have bought an MTNL 3G SIM, not BSNL.
Also, I just tried out the data card. It works well and the Connection Manager software is indeed showing HSDPA DOLPHIN. The LED on the data card has been on BLUE (color for 3G), instead of GREEN (color for EDGE) as was showing yesterday. I guess last night the 3G service was not yet activated.
Also, a better source to check data speed is Speedtest.net - The Global Broadband Speed Test. Across 3 different tests, I got a download speed raning between 1.4 mbps to 2.7 mbps. Upload is capped at 0.35 mbps.
The best part - I started my Netbook in Ubuntu and plugged in the data card. It automatically sets up the connection along with the correct APN (FYI - under windows, I had to manually change the APN for prepaid!).
Old 26th November 2011, 15:25   #548
Raja's Avatar
Thanked: 70 Times
I am based in Pune, but looking to get a usb modem for ALL INDIA use. Do the networks allow FREE roaming (or part of your package) even in circles where they do not have a licence?
I know the alternative is BSNL who do hold a pan India licence, anyone else?
I will also need a USB Modem, which one to get, buy from the network or from an independent and just buy the sim separately? I have not set a budget for the modem. Two good models I have read about are the Huawei K4505 and Huawei UMG1831. Any other to consider?
Raja is offline
Old 27th November 2011, 08:02   #549
sumannandy's Avatar
Thanked: 997 Times
I am using Alcatel modem (unlocked), bought from Letsbuy for about Rs. 1700. The max. speed is 3.6 Mbps, which I barely get with any operator.
sumannandy is offline
Old 13th December 2011, 15:26   #550
Fillmore's Avatar
Thanked: 597 Times
Anyone using any 3G wifi router ? and what is your experience ?
I am looking for one which is compatible with Airtel 3G USB stick.
Looks like the standard ones are >3.5k
Fillmore
Fillmore is offline
Old 13th December 2011, 18:55   #551
vishaltanksale's Avatar
Thanked: 74 Times
I have been using vodafone 3g mifi router for last 1 month. Got it for 4.5k and activated with 3gb @850 plan.
Works perfect for normal browsing, mails and ocassional youtube. No issues with the coverage in Mumbai and Pune.
vishaltanksale is offline
Old 19th December 2011, 14:01   #552
Thanked: 24 Times
Fillmore
We use Bigpond 3g router. Unlike other routers wherein you will need to plugin 3g usb stick, here you just need to insert a 3G SIM and you are good to go. The router too has some better features like DDNS support, better reception due to 2 antennaes for 3G and WiFi support.
pranxter is offline   (1) Thanks
Old 2nd January 2012, 08:53   #553
Fillmore's Avatar
Thanked: 597 Times
!!! Airtel 3G - Pathetic !!!!
Just thought of sharing my feedback, and also would like to get any inputs from anyone facing the same issue.
I went for an Airtel 3G USB based datacard, this was primarily for limited use when I am out of bangalore.
In Bangalore it was fine, However was totally disappointed by the horrible performance of the card when I went out of Karnataka.
I was in TN and 3G would not work, the 2G network speed was between 0KBPS to 20KBPS. It was almost impossible to browse at this pathetic speed, even Gmail page would take ages to load.
Calling up Airtel support was practically useless, they claim that due to some Govt regulation 3G is not supported in roaming mode and with 2g on this card, this is all they can do.
Since I purchased this card primarily for use when out of Bangalore, its practically useless to me. Any inputs on how to get Airtel to refund the card amount/ any workarounds to increase the speed would be appreciated.
Fillmore
Fillmore is offline
Old 2nd January 2012, 10:41   #554
DerAlte's Avatar
Doesn't Airtel cover TN? The Govt. ruling was about operators not extending 3G coverage for roaming to another operator who has not taken license in that circle.
DerAlte is offline
Old 2nd January 2012, 12:01   #555
Fillmore's Avatar
Thanked: 597 Times
Airtel does cover TN and I could find the Airtel Network in TN with good signal strength. However Airtel support claimed that if I want 3G in another state then I need to use a SIM card purchased from that state.
Their workaround was change the settings to GSM 2G mode, which gave pathetic network bandwidth of 0 to 20 KBPS speed.
Fillmore is offline
