Old 12th August 2015, 15:22   #5386
Thanked: 18 Times
Re: The Home Appliance thread
Originally Posted by Juggy View Post
Unless you have something specific against buying online, the 4 jar Panasonic is available at 4600/ on Amazon COD. No exchange required. Most appliance shops can use the motor of old mixer grinders and would pay you upto 1000 if serviceable. The old Jars nylon bushes are also easily obtained. The Panasonic jar has had its bush replaced twice for 60 bucks each time.
I have nothing against buying online. But observed that now there are many sellers who are new or just launched where feedback is very much limited in numbers. I prefer Amazon fulfilled or like that. These new players prices are lower however those who are old and having more feedback numbers the prices are high. I have ordered small items like pendrive, memory card and even MotoE online earlier.
New development is the Mixer is working now though its white plastic body is turned yellow. So new mixer is on hold for the time being. The thing is that its blade of chutney mixer is sharp and pointed and two prongs are upward facing which makes it difficult to clean.
HydroFuel is offline
Old 12th August 2015, 15:26   #5387
rjstyles69's Avatar
Thanked: 845 Times
Gents, my washing machine has kicked the bucket and I am in the market looking for a replacement. The old one was a front loading 6.5kg from Sam'D'ung. The quality sucked to say the least, the damn piece started rusting around the soap dispenser tray and on one of the sides.
I am looking at something in the 7kgs range. Any recommendations ?
rjstyles69 is offline
Old 12th August 2015, 16:13   #5388
archat68's Avatar
Thanked: 642 Times
I have, and also now own one. Very useful, esp when travelling. However, they cannot give you a razor sharp crease, but remove wrinkles very well. So you have to decide.
Which brand are you using?
archat68 is offline
Old 12th August 2015, 16:39   #5389
Gannu_1's Avatar
Thanked: 20,681 Times
Front loading or top loading?
If its the front loading type, do take a look at the machines from Bosch. Been using their cheapest 5.5 kg model since the last 3 years and it has been working exceedingly well. Never had to prescrub the collars or cuffs before washing them and they've come out clean. I'd recommend these units. My unit has been kept in the kitchen balcony for the last 10 months and I haven't observed any rusting on the exterior bits. I've used a plastic cover (Amazon) to protect it from rain and dust.
I am waiting for the decade-old IFB noisemaker at my hometown to die so I can replace it with a Bosch unit.
Gannu_1 is offline
Old 12th August 2015, 16:50   #5390
archat68's Avatar
Thanked: 642 Times
I'm using a LG frontloader for last 3.5 years. No problem. We use it daily. Somedays even twice in a day.
archat68 is offline
Old 12th August 2015, 17:15   #5391
babhishek's Avatar
Thanked: 36 Times
Would recommend lg as well
babhishek is offline
Old 12th August 2015, 18:11   #5392
vinitbhavi's Avatar
Thanked: 1,166 Times
Highly recommend the LG washing machine. We have been using our top loading one since a couple of years which was a replacement to an older LG machine. No problems at all. We use the machine nowadays more than once. Only recently we had an issue of pulsator overhauled/replaced but this was due to our error of the drain pipe not being completely vertical which caused water to remain in the drum and rust some parts due to stagnation. Service in Mumbai at least is efficient.
vinitbhavi is offline
Old 12th August 2015, 18:14   #5393
Thanked: 1,911 Times
My LG toploader has now crossed 10 years. No AMC taken ever - I don't believe in AMCs for any personal purchase. Total money spent on maintenance in 10 years is probably less than Rs. 2000.
carboy is offline
Old 12th August 2015, 20:20   #5394
rjstyles69's Avatar
Thanked: 845 Times
^^ Thank you gentlemen. These were the only 2 options on my mind
- Bosch
- LG
and has to be a front loading one.
I am not very sure about Bosch's service in Bangalore. It's very inconsistent but LG I can bet my bottom dollar. I had a 7 year old vacuum cleaner which had stopped functioning and I even picked up a new one as a replacement( was darn lazy to call the service center and get the motor replaced on the old one).
Quite recently I simply called LG and gave them the model number of the old vacuum cleaner and asked them if it can be repaired ? It was a positive and the service engineer came home in less than 48 hrs since I called and fixed the vacuum cleaner.
As for my AC's I dint think twice , simply brought an LG.
Thanks again, this weekend will scout around and see what LG and BOSCH has in their range.
Old 12th August 2015, 23:52   #5395
khoj's Avatar
Thanked: 1,288 Times
Look at LG & Panasonic, drop Bosch
...this weekend will scout around and see what LG and BOSCH has in their range.
khoj is offline
Old 13th August 2015, 09:41   #5396
Thanked: 346 Times
@rjstyles69: We have LG front loader from last 11 years. No AMC taken. No Only technician came once so far. Works flawlessly even today.
RaguHolla is offline
Old 13th August 2015, 10:31   #5397
Thanked: 3,008 Times
Even though I went for long term AMC, in last three years our LG Front Load has not required any attention.
Aroy is offline
Old 13th August 2015, 15:12   #5398
sgiitk's Avatar
Thanked: 4,809 Times
I have been on LG front loaders for over 12 years and have my second one now.
sgiitk is offline
Old 13th August 2015, 18:25   #5399
Pallavi's Avatar
Thanked: 38 Times
Gents
And Ladies..
One more vote for LG washing machine. Been using the 7.5kg front loader almost daily for 8+ years and still going strong
Pallavi is offline
Old 13th August 2015, 18:45   #5400
sbala's Avatar
Thanked: 164 Times
I am using LG trom front load washing machine for past 8+ years. No complaints so far. Highly recommend LG
sbala is offline
