Using Liqui Moly Gear Box Additive in my Thar CRDe:
Synchro rings have a habit of wearing out in the Thar CRDe, especially if you drive in bumper-to-bumper traffic and have the habit of shifting gears often instead of lugging on a higher gear at half-clutch.
Somewhere around 20,000 km, during my synchro-ring replacement, I got a brainwave of adding a tube of Liqui Moly Gear Box additive to transmission oil. I felt that the gear-box had become ultra-smooth, but it was good while it lasted.
At around 30,000 km, I again had a problem with worn-out synchros. I did not have much time to spare, just had the synchros replaced and used Mobil's trasmission oil.
I had no problems until I reached 85,000 km. When I replaced the synchros, the old Liqui Moly additive bug bit me hard. I used
two tubes of additive with Motul Gear Box oil after the gearbox was fully overhauled.
Guess what? After barely 8,000 km the synchos failed again!
I then did a lot of research on the Liqui Moly Gear box additive. It should
NEVER be used in gearboxes with brass synchro rings.
Initially, the additive gives the placebo feeling of a very smooth shift, when in fact the molybdenum in the additive doen not allow the synchronizers to function and in fact, causes them to prematurely wear.
Having learnt my lesson the hard
(and expensive) way, I had the transmission overhauled once again and replaced all synchronizer rings with their hubs.
Oil used was Mahindra's genuine transmission oil with NO additives. Replaced a couple of parts along as well.
I have been driving around for a while now and the gear-box is buttery smooth.
No more experiments with truth!
After reaching 93,000 km now (12.75 years), decided to give the engine a total flush. Replaced the engine oil with AMSOIL 5W40, replaced the diesel filter, air filter element and oil filter and the Jeep is as good as new!
The engine gently purrs. Got to drive some more to really fathom how different it is from the Liqui Moly Molygel 5W40 I had used earlier
(replaced after 12,000 km).
