I had the freakiest of accidents on Ganesh Puja day, when my car was in parked position. Actually, when I parked on Tuesday evening in my covered parking spot, I found a few drops of water trickling from the overhead pipe and falling on my car's roof. I ignored it as the drain pipe overhead does leave a bit of water now and then, when it rains, or when they water the plants above the parking level.
On Wednesday, I took my WagonR for a small outing and noticed more water around the Fiesta from a distance. I thought that the cleaner had used lot of water to clean the wheels and car. But when I returned in the night and took a peep, I found that the trickle had turned into a small downpour, mostly on the rear glass and roof. In order to protect the car, I moved it to an empty parking nearby.
But when I wanted to reverse, I found 70% of the rear screen was opaque, as if covered with a light film of ice. I put the defogger on for a few minutes, but only one side got cleared partially. The spot where the water had directly trickled onto the screen was still opaque. I parked the car with some difficulty, and took a cloth to clean the glass.
To my utter shock and dismay, I found that even after wiping it, the grime was not getting cleaned. To make matters worse, even the rear boot lid was almost covered with whitish grime, that was stubbornly clinging on. Some of it was also on the left quarter panel till the fuel filler cap. Some trickle marks on the area near the number plate too. But poor illumination prevented further scrutiny.
With a petrified mind, I sought advice from a few friends. Some suggested using white vinegar diluted with water to clean the glass. But in any case, I had to wait till morning for a better picture.
After a disturbed sleep thinking how much $$$ it would set me back by, and wondering who to blame, I tried the vinegar solution in the morning, but the glass area got cleaned only by 10%, and the stubborn grime was just not going away. I was wondering if I'd need to change the rear screen with defogger, as well as paint the boot and quarter panel, all of which would cost me lots of money.
As I'd got some small denting and painting done earlier by an FNG nearby, I called him . He said not to worry and to take the car at 11 am. He also said it could be acidic water mixed with lime as it was from a drain pipe. He also advised not to delay, else the grime would stick more, forcing a paint option.
I took it there are 11 am, and it took them 3 long hours to set it right. Here is what they did:-
- Used some kind of squarish paper to wipe the metal and glass by dipping it often in water . The paper was plain to touch, not sandpaper type. This process took an hour. As a result, the hard stains on the metal of the boot and spoiler, and part of the left quarter panel almost vanished. But there were still stubborn stains on the rear windscreen where the drip directly fell on----this was around 20 % of the glass area.
- Used a buffing machine and and rubbing compound and twirled it on the boot. After around 10 minutes, the boot was shining to glory.
- Applied method 2 all over the car---especially on the roof where some water dripped onto, and then on the front bonnet and all sides of the car. This took around half hour. Only major item pending was the rear glass.(I told them to do the buffing job on the entire car, so that it would shine uniformly)
- After coming to know that the defogger lines were inside the glass (I thought they were outside), the guy tried with some thinner on a small area. It just dried up and did not do any good. Tried again with petrol and with the same disappointing result. Then another guy stepped in and said he'd done a similar job to another car a few weeks ago. He brought a squarish paper with a sharp edge that is used for luppum job on the wall, and with that he started scraping the stains, taking care not to scratch the glass. This took him nearly 30 minutes and lo behold, the stains were gone!
- I told them to check stains with the boot opened so that they could clean whatever drip marks were there, and also to remove drip marks here and there (incl the team-bhp sticker).
I got the car back spick and span, and better than before, as it shines all around now.
Lesson learnt:
- Never trust any darn car park, however secure it might appear to be. There are unique ways of getting screwed up. And if you ever suffer such an ordeal, take the car to an FNG asap. I should have taken it on the first night itself, in which case the effort would have been less.
- In the first place, I ought not to have parked my car there when the dripping had started, and I lost another chance of removing the car when I went for an outing on the Waggie.
And if you are curious to know how the pipe leaked, it was due to some nitwit in the 1st floor who'd left his pipes on and gone out of station for two days. The drainage pipe could not stand the pressure and started leaking at places. My car was the biggest victim.
Here are a few pics of how bad the car was, and some of the car getting buffed:-
First glimpses of the damage early morning:
In brighter light:
Buffing in process:
See the contrast between the boot and the quarter panel after buffing:
