Old 8th June 2023, 20:52   #4486
Thanked: 623 Times
Re: Mahindra Thar : Official Review
Originally Posted by ph03n!x View Post
The two sizes are not interchangeable - the AX has 30.5" dia wheels from factory, while LX has 31.1". As the LX comes with ESP, TCS, BLD etc., may not be a good idea modifying the wheel dia without calibrating the electronics.
The right downsize to match factory spec of the LX will be 255/75 R16 or 275/70 R16.
You are right about the wheel dia changing, however its under the 2% change limit which seems to be commonly used limit when changing tyre sizes.
Would the electronics have to be recalibrated even when upsizing the tyre ? because that seems to be quite common amongst Thar owners. A few posts above user shankar.balan had posted that the correct upsize for 18inch is 265/60r18 which gives a 1.7% smaller circumference, wouldn't that also require the electronic aids to be reworked ?
Turbolove is offline   (2) Thanks
Old 8th June 2023, 22:03   #4487
Thanked: 153 Times
Originally Posted by aamishdhingra View Post
7. Earlier was a Convertible top - purchased the OEM Hard top.
Nice mods. Do you mind sharing the cost of HT and installation.
yadavsid21 is offline
Old 9th June 2023, 00:40   #4488
Thanked: 1,043 Times
Hi, your Thar looks stunning in black. Also, would mind sharing the reason you converted your CT to HT? And how much did it cost? Whether you are happy with the HT fitting? I assume that you got it fitted somewhere outside the Mahindra Service Centre.
sahil624 is offline
Old 9th June 2023, 01:02   #4489
Thanked: 838 Times
Hello fellow forum members, I recently created a thread where in I am looking for a replacement for my Polo which is our secondary car with Harrier being the primary. So far we haven't been able to find that one car that can make us feel comfortable in letting the polo go. This car will be primarily driven by my Spouse for her city commutes and will also be used to ferry our overly pampered Golden Retriever. So the car needs to be Safe, Proper Automatic and less than 4 m in length. We weren't able to finalise any car so far until we had a surprise wildcard.
A Surprise Wildcard Okay hear me out on this one, from Polo to Thar might make it seem we are all over the place, yes I agree it seems that way but it doesn't hurt to try all options when you are on a tight budget , does it ?
Thar RWD Petrol AT :- We stumbled across the Mahindra showroom which was nearby to Kia and TATA and thought of checking out Thar again because coming from a family where we had Bolero, Armada, Gypsy King and Scorpio I have always drooled over the Thar and wife likes Thar as well. We had to let go of idea of owning Thar last year because we needed a 'family car' and Thar wasn't that. Hence we shifted towards XUV 700 and Harrier with Harrier ultimately being picked. However, we now have that family car so we can consider a lifestyle vehicle as the second car ? I mean it's less than 4 m in length, it's safe, it has a road presence and it is to be driven sedately. Add to that waiting periods are now down to 1 month
with these thoughts in mind we did take TD of Thar RWD Petrol Automatic and I , yes I was in love with it all over again. The petrol engine is tactile, quick and super responsive. Aisin Gearbox is definitely aimed towards aggressive shifts which makes the car fun to drive. The typical BOF high seating is heavenly. BOF also leads to pitch and yaw being pronounced But that's the beauty of it. This TD reminded me of our Scorpio which we had for a decade before it was sold. I think I am in Love again but , I will have to keep my emotions in check as it's my Partner for whom we are looking for a replacement and not me.
My partner has her reservation towards it. She did enjoy the TD herself and is definitely elated by the idea of owning a Thar for herself specially the Red Rage colour but isn't sure how practical it would be to replace a Hatchback like Polo with Thar. So I look to your advice, have you been using Thar for your city runs and more importantly if your partner drives the Thar how comfortable it is for them or their views regarding it.
Any advice would be much appreciated.
Cheers !
BleueNinja is offline   (2) Thanks
Old 9th June 2023, 02:46   #4490
ph03n!x's Avatar
Thanked: 6,162 Times
Honestly, I'm not the expert. But I play it safe and try and stick to the same dia as much as I can. The electronics may work perfectly with upsize most of the time, but I'd ideally want then to with perfectly all the time. M&M won't say it will (or won't) with a different dia tyre.
Which is a pain with this vehicle, as there are no "right" upsize or downsize if you want to stick to 255mm tyre width (or even 265) and the dia.
A lot of Thars have upsized to 265/60 R18 or even 285/60 R18. But in my Thar, it was easy for the wheel alignment to get messed up enough for the tyres to rub against the lower arm. At factory settings/ perfect alignment, there's hardly an inch gap at full lock - which means I'll have to go with a negative offset rim to safely upsize the width. And that's another can I don't want to open - and at 50k KM on stock CEATs, I'm looking for a tyre change.
ph03n!x is online now   (3) Thanks
Old 9th June 2023, 11:55   #4491
highwaypatrol's Avatar
Thanked: 830 Times
Hi Phonenix, I guess we both are on the same boat. I just finished 45K kms and my Thar is craving for a shoe change.
Iam very much interested in BFG KO2 or Maxxis Bravo AT 980 in 265 60 R18, however exorbitant prices quoted for BFG (Upwards of 22K by multiple dealers) and unavailability of Maxxis tyres in India is delaying my plans.
Most of the distributors are not getting stock of Maxxis Bravos for the past few months at least here in Bangalore. Anyone in Bangalore can connect me with the correct Maxxis dealer who has stocks? I would be grateful.
Please do keep us updated about your tyre plans!
Highwaypatrol
highwaypatrol is offline   (2) Thanks
Old 9th June 2023, 12:28   #4492
Thanked: 623 Times
You're right about there being no correct upsize or downsize options while maintaining the wheel dia. However besides the wheel dia we would also have to consider if the tyre section is increased, wouldn't that result in more stress on the tie rod ends and ball joints ?
Turbolove is offline   (1) Thanks
Old 9th June 2023, 21:49   #4493
ph03n!x's Avatar
Depends - if the alloys are not changed, and are wide enough to take the new size, the impact is relatively less because the overall CG of the wheel with respect to the vehicle wouldn't change.
But if one were to go with a negative offset (tyre jutting out of the wheel arch while at the same vertical plane of reference vs stock), will load the joints and ends more.
And not going with a negative offset when going for a wider tyre width will make the tyre touch the lower arm as there's barely an inch gap there at stock.
ph03n!x is online now   (2) Thanks
Old 9th June 2023, 22:15   #4494
DCEite's Avatar
Thanked: 3,481 Times
For Tall persons with long legs, a dead pedal in the new Thar is a hindrance and not a help. The already cramped footwell gets further cramped on the left side.
As a tall person I am happier that this dead pedal can be added on as an after market accessory for those who require it. There are plenty of options available for this.
I drove a friend's Thar's Diesel AT today for about 10 kms. What immediately took me by surprise as soon as I got on to the driver's seat was how cramped the footwell is !
Mind you I am 5'11 and have slightly longer legs than an average joe (I get issue of my knees touching left lower dashboard on many cars including Harrier/Safari, Nexon, Punch), BUT, Thar is on another level. I had to bend my knees in an uncomfortable way and still could not figure out how to manage the cramped feeling for the left leg.
I am surprised this issue has neven been highlighted (except rarely like in the above quoted post), but it is a deal breaker for me if I ever plan to buy the Thar.
@owners, how do you manage ?
DCEite is offline   (5) Thanks
Old 10th June 2023, 01:04   #4495
rajeevsulu's Avatar
Thanked: 3,039 Times
I am 6'4.I just push the seat as far as it will go behind. Bring it forward one notch and that is my perfect position to drive. I am very comfortable and have no issues at all
rajeevsulu is offline   (6) Thanks
Old 10th June 2023, 12:51   #4496
Thanked: 830 Times
Finally decided to go ahead with BFG KO2 , 265/60/R18 after 45K kms with Ceat Czars!
Steering has become surprisingly lighter, handling has improved many folds and a little bit of extra road noise as compared the stock ones.
Over all very happy with the new tyres, total damage is 21.5K per tyre with balancing and alignment paid extra.
The over all stance has completely changed and looks great for me.
Thanks for all the suggestion guys!
Mahindra Thar : Official Review-img_1357.jpeg
Mahindra Thar : Official Review-img_1358.jpeg
highwaypatrol is offline   (19) Thanks
Old 10th June 2023, 13:40   #4497
DCEite's Avatar
I took some photos to show the issue. There are two issues basically:
1. Left part of knee touching the lower part of dashboard.
2. V shaped footwear that gets cramped and I have to rest my left leg at an angle to the floor:
Mahindra Thar : Official Review-20230610_121307.jpg
Mahindra Thar : Official Review-20230610_121235.jpg
DCEite is offline   (2) Thanks
Old 10th June 2023, 20:06   #4498
Thanked: 27 Times
Took delivery of Thar LX AT 4WD HT in Everest white colour yesterday. Planning for following modifications
1. Wrangler style seven slot ABS Grill.
2. KING Kong 7 inch LED Headlight
3. LED fog light
4. Dead pedal
5. Grab handle
Please suggest if I should avoid something or add anything..
navino87 is offline   (1) Thanks
Old 11th June 2023, 03:27   #4499
rajeevsulu's Avatar
3. LED fog light
4. Dead pedal
5. Grab handle
Congratulations. Please drive a few hundred kilometers and then decide on the dead pedal. That is if you really need one.
rajeevsulu is offline   (2) Thanks
Old 11th June 2023, 13:09   #4500
Thanked: 47 Times
You can check and validate the rates here:
https://www.withyouhamesha.com/shield.aspx
Could someone share latest prices for 4th and 5th year extended warranty please. Unable to check as I'm not registered.
Could you share if you bought insurance from Mahindra or outside and how much it costed you? Can email at thar - AT - sandeeprawat d0t com
Dealer is quoting me 110806 for insurance (1 yr comp. + 3 yr third party). Wondering how can I get a better deal.
Any discounts etc. I can get on P-AT/CT/4WD in NCR?
This is the quotation I received from dealer
Mahindra Thar : Official Review-20230611_124913.jpg
sandeeprawat is offline
