Old 9th June 2014, 17:12   #481
tsk1979's Avatar
Thanked: 23,484 Times
Re: Leh, Ladakh and Zanskar - The Ultimate Guide
Originally Posted by Raps View Post
Finally decided the route, Looking forward for this trip
Please recommend if there are any changes required.
Thanks,
Its a good plan.
Chuck manali halt.
This will give you one day buffer if you are unable to get chushul permit
tsk1979 is offline
Old 9th June 2014, 17:56   #482
ramkya1's Avatar
Thanked: 434 Times
Pensi La is open. Wari La should be open. But you will get info from Leh taxi drivers.
Panzi La being open is good news, early days would be hell with snow-melt, slush and water.
Today morning's news form a Kargil hotel was that it was not open! Did RK Bharat pass through?
Ramky
ramkya1 is offline
Old 9th June 2014, 21:22   #483
tsk1979's Avatar
Ramky
Must have closed again. Its always unstable this time of the year. However this means, it should be open in the next 3-4 days.
tsk1979 is offline
Old 10th June 2014, 00:15   #484
rahulya007's Avatar
Thanked: 345 Times
Hi Tanveer,
Need your expert comment on the below plan from July 12th till 29/30th. We would be 4/5 friends in Xylo mHawk E9 with 3 drivers.
Day 1 - Thane to Jaipur - 1170 Kms
Day 2 - Jaipur to Jammu - 790 Kms
Day 3 - Jammu to Kargil - 495 Kms
Day 4 - Kargil to Rangdum-Pensi La-130 Kms
Day 5 - Rangdum to Leh - 341 Kms
Day 6 - Leh - Rest day - Permits
Day 7 - Leh - Local Site Seeing
Day 8 - Leh-Khardung La-Panamik-Deskit - 225 Kms (Panamik can be skipped)
Day 9 - Deskit-Wari La-Pangong - 225 Kms
Day 10 - Pangong - Rest Day
Day 11 - Pangong-Hanle (via Chuchul if permitted / Kakasang La) - 204/253 Kms
Day 12 - Hanle to Tso Moriri - 150 Kms
Day 13 - Tso Moriri to Sarchu via Tso Kar - 219 Kms
Day 14 - Sarchu - Manali - 223 Kms
Day 15 - Manali - Rest Day
Day 16 -Manali to Ambala - 348 Kms
Day 17 - Ambala to Udaipur - 870 Kms
Day 18 - Udaipur to Thane - 713 Kms
pls. suggest, potential road blocks or places where the vehicle will have issues. Also suggest if any changes required from Jammu. Not attempting any place which cannot be done in a RWD vehicle. Pls. suggest if any place which we can still do with some caution. How it the Hanle - Thot Zarbo La - Kyun Tso route to attempt in a RWD vehicle ?
Rahul Korde
rahulya007 is offline
Old 10th June 2014, 09:46   #485
Raps's Avatar
Thanked: 35 Times
Its a good plan.
Chuck manali halt.
Thanks Tanveer,
Exactly need to think about it if we are not able to get the Chushul permit.
Raps is offline
Old 10th June 2014, 11:12   #486
tsk1979's Avatar
Originally Posted by rahulya007 View Post
Hi Tanveer,
Change plans. Do not go to Jaipur, instead take Kishangarh highway
Day 1 ; Somewhere in RJ
Day 2: Jammu
Day 3: Kargil
Perfect, you see Durang Durung and then come back to Rangdum
One day is enough in Leh. Take one day later if you get chushul permits and are able to save a day
Good, 2 nights in Pangong will be interesting, you can stay at a home stay in Merak on night 2
Leave very early.
Do This : Manali - South PB (stay night there) and then take Kishangharh highway.
Rahul Korde
GC is the issue on Kyun Tso route. you can attempt it and turn back if you find it tough. Hanle to Tso moriri is almost 100% smooth tar on normal route, so even if you waste 2-3 hours, you are good.
tsk1979 is offline   (1) Thanks
Old 10th June 2014, 12:01   #487
rahulya007's Avatar
Thanked: 345 Times
Thanks Tanveer for your valuable inputs.
few questions to clear doubts.
1. where does the Kishangarh Highway start and end ? Tried finding some info on Google but did not get complete information.
2. Doing a home stay in Merak is a good idea. Will save some distance the next day and a different experience as well. what is the probability of getting a home stay in Merak ?
3. How is the road via Kakasang La ? you have advised to leave early. Is that because the detour will take time ? Will we still need permits for chushul ?
4. On the second day at Pangong, would you suggest attempting Marsimik La without any issues to the vehile ? as far as the vehicle can go..types.
5. Wanted to do Shyok but it will be difficult for a 2WD I suppose.
6. Since you have not commented on Deskit-Wari La-Pangong, I am assuming we can do it in Xylo.
7. Will try attempting Kyun Tso and as you said, will turn back if it is too difficult.
Awaiting your suggestions.
Rahul
Old 10th June 2014, 12:29   #488
tsk1979's Avatar
Use this thread: http://www.team-bhp.com/forum/route-...highway-5.html
Even if you do not get Merak, Spangmik is easy
For hanle take Tsaga La route. Kakasang La can be difficult if there are diversions
you can attempt, but it can be troublesome if you get too adventrous
yes,
Doable, its a tar road
Yes, best strategy. If you reach Kyun Tso, Thit Zarbo La downhill should not be an issue. Just don't take your vehicle off the track to sand etc.,
Old 10th June 2014, 13:51   #489
rahulya007's Avatar
Thanked: 345 Times
Diversions mean road work or something going on ? I wanted to see Mirpal Tso and Yaye Tso after reading your post and hence asking. Also the road seems ok from the images you have posted so dared to think of this route. I guess, Tsaga La could be an issue if permits are not issued, right ?
We are also thinking of personally visiting the DC office for the permits rather than relying on the travel agents, what say ? Guess, there could be more chances of getting the permits after being present personally.
I won't do any adventure, but just go till your vehicle can easily go or return back types.
I would definately not leave the road or the tyre marks to become adveturous. I know help can be days away if we get stuck so no masti.
Thanks,
Rahul
Old 10th June 2014, 13:59   #490
tsk1979's Avatar
Yes, they are kind to families. As for the Kakasang La route, if due to road work they create shortcuts, you could have a tough time since the pass is very steep. that said, even if you do not reach Kakasang La, you will lose 2 hours going to Mirpal Tso and back. But then you could get lucky!
tsk1979 is offline
Old 10th June 2014, 14:59   #491
Ace F355's Avatar
Thanked: 3,067 Times
TSK, what beautiful guide you have written! Wow...
This is going to serve a lot of people with 'Drive to Leh' dream. Thanks for sharing.
Ace F355 is offline   (1) Thanks
Old 10th June 2014, 17:12   #492
rahulya007's Avatar
Thanked: 345 Times
Was going through Google Maps and thought of asking about a detour to reach Srinagar via Jammu-Udhampur-Patnitop-Doda-Kishtwar-Sinthan top-Anantnag-Srinagar ?
what would you suggest ? Is this route doable by MUV. I have read, Sinthan top route is much more traffic free and scenic than the regular Jammu-Srinagar route via Ramban.
Rahul
Old 10th June 2014, 17:19   #493
tsk1979's Avatar
Rahul
Yes, its doable, but its longer, road surface till Sinthan from Jammu side is bad too. If you have time, you can do it. Its lovely
tsk1979 is offline
Old 10th June 2014, 17:30   #494
rahulya007's Avatar
Thanked: 345 Times
I had recently seen a youtube video on Rockcut wonders of Pangi Kishtwar where a single lane road goes via the rockcut mountain with valley on one side of the road. I am not sure if that road was of Pangi or Doda-Kishtwar route. The road was scenic but seemed equally risky. Does the Kishtwar road look like the one in the video ?
We can change the plan to halt at Srinagar/ Sonamarg on Day 3 and then proceed further adjusting 1 day there.
I would like to see Sinthan top as I have heard a lot about it. Only worry could be Doda-Kishtwar Section as mentioned above.
pls. confirm.
Rahul
Old 10th June 2014, 17:34   #495
tsk1979's Avatar
I had recently seen a Youtube video on Rockcut wonders of Pangi Kishtwar where a single lane road goes via the rockcut mountain with valley on one side of the road. I am not sure if that road was of Pangi or Doda-Kishtwar route. The road was scenic but seemed equally risky. Does the Kishtwar road look like the one in the video ?
pls. confirm.
Rahul
I think that is Sach Pass. Sinthan top road is not that dramatic, though scenery is very good.
you can take that if you have time
tsk1979 is offline
