Old 3rd October 2023, 17:12   #2341
ottocycle's Avatar
Thanked: 756 Times
Re: Bangalore - Mysore - Ooty : Route Queries
This weekend, I finally created the video of the 36 hairpin bends from my last Ooty trip. It covers driving through all the 36 hairpin bends of the Kalhatty Ghat.
The weather was clear when we started the climb, but around bend 15 onwards we started facing the mist and very slight drizzle. By bend 23, it was dense fog and visibility went really low. It was a refreshing drive though. We had opened the windows to take the fresh air in and had AC switched off. Hopefully it helped the engine too.
ottocycle is offline   (14) Thanks
Old 28th October 2023, 17:08   #2342
Thanked: 751 Times
Just completed from our Bangalore-Ooty road trip earlier this week. While going to Ooty, we took the Masinagudi-Kalhatty ghat route. @ottocycle's video in the above post of the hairpin bends shows the excellent condition of the ghat road uphill and it is smooth sailing all the way to Ooty.
When returning back yesterday, took the alternate Ooty-Gudalur route. There are way too many locations on this route where there is ongoing road work, hillside reinforcement, culvert building etc. Because of this construction, had to slow down ever so often and road quality is not so great at these specific locations as well. And since this route is longer to begin with, we ended up taking much more time than expected.
I had heard that only TN-local area vehicles or pass holders can go downhill from Ooty to Masinagudi via the Kalhatty ghat bypassing Gudalur, but if allowed this currently is a much better option on the return from Ooty.
vijaykr is offline   (1) Thanks
Old 28th October 2023, 18:23   #2343
Thanked: 225 Times
This is indeed the case, coming down via Kalhatty road is not allowed for non TN vehicles. In fact if I remember correctly, even TN private vehicles are not allowed from 2017 onwards.
SamDiablo is offline
Old 30th October 2023, 15:24   #2344
Thanked: 93 Times
Only those,who have a driving license from the RTO, Nilgiris are allowed down the Kallaty ghat these days.
nishkamm is offline
Old 15th November 2023, 09:35   #2345
Thanked: 185 Times
Adding to the above, there are plenty of tourist attractions on this route which lead to slow traffic and vehicles merging and exiting the road at will without any indication.
Also plenty of pot holes all the way till you enter the forest after Gudalur.
I was stumped to see perfect roads within the forest from there on (except for a couple of patches where bridge work is on).
If you are in sedan slow down and be patient till you hit the forest for motorable roads.
rakirank is offline
Old 7th January 2024, 11:12   #2346
Thanked: 2,865 Times
Need help for route from Mysore to Ooty. I am very new to the place and doing a road trip with family from Mumbai. As far as I have read through the thread, Mysore to Ooty route is via Masinagudi. Should I just simply follow Gmaps?
Bangalore - Mysore - Ooty : Route Queries-screenshot_20240107111141_maps.jpg
VWAllstar is offline
Old 7th January 2024, 12:39   #2347
Rajeevraj's Avatar
Thanked: 19,200 Times
Yes. Follow the route as indicated. The masinagudi route is the steep 36 hair pin bend route. Instead of turning left from Theppakadu towards masinagudi, you continue straight, it is the gudalur route to Ooty. When returning you will need to come via this route as they dont allow to come down via the Masinagudi route.
Rajeevraj is offline   (1) Thanks
Old 7th January 2024, 12:44   #2348
Thanks for your reply. Little confused. Why should I continue towards Gudalur? I would be interested to drive on the 36 hair pin bends. While returning I have to go towards Virajpet. What would be the best route as you mentioned the officials do not let you go down the Masinagudi route.
Bangalore - Mysore - Ooty : Route Queries-screenshot_20240107124400_maps.jpg
Old 7th January 2024, 13:25   #2349
Rajeevraj's Avatar
Sorry, I think I was not clear. There are 2 routes to Ooty. The shorter, steeper Masinagudi route is one. This is what Google shows and this is the route you need to take on the way up. The 2nd route is the one via Gudalur. This is longer, with a more gradual climb. Both of these meet at a point before Ooty. When you come back, due to the steep route, the authorities no longer allow downward traffic on the masinagudi route. So on the return you will come down via Gudalur and then continue on to Gundlepet. You will join back the onward route at the place called Theppakadu inside the forest.
The routes to Virajpet, not sure of the road conditions on the default route shown. I think it is a less travelled more deserted road. Maybe others can guide. The Mysore route is the better option is my view.
Rajeevraj is offline   (2) Thanks
Old 7th January 2024, 14:17   #2350
Thanked: 751 Times
Please take the shorter route via the hairpin bends. This was early doable in a sedan (City) and not as steep as I'd thought 😔. In fact it is a significant time saver compared to the Gudalur route given the less traffic we encountered.
Hopefully some of construction on the return direction is now completed which might make it easier. But I'd recommend planning additional time as it was not a great drive when I did the trip couple of months ago.
vijaykr is offline   (2) Thanks
Old 26th March 2024, 11:30   #2351
goandude's Avatar
Thanked: 1,298 Times
Anyone have the latest condition of the Gudalur route? Planning trip end April
goandude is offline
Old 26th March 2024, 13:05   #2352
Thanked: 1,812 Times
Most of the road is good except for the stretch through the pine forest which is a real test for the suspension.
keroo1099 is offline
Old 26th March 2024, 21:15   #2353
goandude's Avatar
Thanks Keroo. How many kms is the bad patch? And could you pinpoint the start and end? How long did you take from Ooty to the Bandipur forest gate?
goandude is offline
Old 26th March 2024, 23:07   #2354
It's not very long, maybe a couple of km and it's all within the Augustine Pine forest ( it's on Google maps) closer to Gudalur.
The journey easily adds an hour (probably more) to the journey compared to coming down Sigur.
Old 27th March 2024, 08:46   #2355
itwasntme's Avatar
Thanked: 14,292 Times
There are 2 routes to Ooty. When you come back, due to the steep route, the authorities no longer allow downward traffic on the masinagudi route.
Is downward traffic, i.e. from Ooty to Masinagudi being allowed now? I thought only TN43 (Ooty RTO) vehicles were allowed.
itwasntme is offline
