Originally Posted by ObsessedByFIAT I am planning to install a rooftop solar panel system and have run in to a lot confusion and questions. Looking for some advice from all the experienced folks here! These might be real noob questions, but my research is not yielding the information I am trying to figure out.
Some details of where I plan to install:
- The installation will be done on roof top, measuring appropriately 500/600 sq.ft. in PCMC region of Pune.
- The house is east facing and gets bright sunlight right from morning to sunset.
Questions that I have :
1. What should be an approximate cost I am looking at if I would like to run 2 AC, 2/3 Coolers, 2 Geysers and rest of the standard home equipment? Consider around 350 to 450 units a month.
2. What are the pros and cons of having a on-grid vs off-grid ? |
If you are in city and there is not much power cut along with existing power backup, go for on grid with net metering (if Maharastra allows). On grid inverters don't work in case of power cut (to prevent shock on anyone repairing the power line, since the excess power generated is exported to the grid). Nowadays there are new inverters coming with ZED devices which can work even with power cut but these might not be allowed by power discoms (better confirm with the vendor) Off-grid is costlier and might not be beneficial for city use. If you are having existing backup inverter and very less power cut, on grid is sufficient.
For on grid solar inverters, most popular ones are string inverter and microinverter. In string inverter all the panels are connected in serial to a single central inverter. Its cheaper but if any single panel has shade/performance issue, all other panel's performance drop's down. If your installation area is without any shade and you can easily clean the dust regularly, string inverters will work fine.
Microinverters are costlier since each panel has its own inverter and hence the performace is not dependant on each other. But these are slightly costlier.
3. What are the major recurring costs I am looking at? Battery replacement costs?
For on grid inverter there is no major recurring cost apart from regular dusting/cleaning. Most of the panels have 20/25 years performance warranty while the inverter will be having 5 years warranty(some brands give extended warranty). Since these have mostly non-moving parts the chances of failure are similar to any other electronics equipment.
4. If I would like to go on-grid, what types of permissions would I require from local authorities?
In my case vendor took care of all the formalities apart from one visit to main power station. It took nearly 45 days from the day of installation for approval, which was higher than normal according to my vendor since the executive engineer was signing something like this first time in my area, he was hessitant/(wanted something extra?) but in the end I didn't had to pay anything extra from my side apart from 500 given to guy who came to install solar net meter.
[quote]
5. How does the billing work? Is it like the bill itself is reduced or I first have to pay upfront and can expect a credit in my bank account?[/[quote]
For net metering, the bill itself is reduced (its "net units imported" - net units exported). In day-time, the power generated is first used by house and only extra power is exported. If the power generated is not sufficient, the difference is imported from grid.)
6. Is it a better economical decision to just charge an inverter through solar have have only limited coverage like a few bulbs and fans running off of the inverter?(I know, this question can be a bit tricky to answer as it would depend on my requirements. I would love to know your thoughts)
It depends on your usage and duration of power cut, if its not much, a new inverter costs around 5000 and a single lead-acid battery around 15000. Its much cheaper and efficient than having off-grid solar since if power cuts are not much, you will be wasting money on additional batteries which will be mostly not utilised. (My vendor had quoted for 2 batteries costing 30000 along with higher priced hybrid inverter. Overall for 3kw system it was 60000 more. Also, vendor informed hybird inverters don't perform as good and on-grid words, not sure how much of this is true)
7. Is there a drastic difference in electricity production during rainy / winter season as compared to summers? [
There is difference when sun is not there (rain, clouds etc) here is a graph of my panel on a normal day vs cloudy day
Attachment 2303044 Attachment 2303045
Regarding performance in summer vs winter- performance depends on two things, amount and duration of direct sunlight and the ambient temperature. Till now I have got highest performance in October and January on sunny day. In winter at my place, there is lot of fog, hence the performace was low due to lack of sunlight. Since April, due to heat, even though there is sunlight full day and the duration of sun is higher, overall generation is not so high. Here are my charts for monthly and daily performace for 3kw system. (Note, with daily/weekly cleaning you can increase the performance by ~20-25%, the vendor had installed my panels at height and its not easy for my parents to clean regularly. I clean it on ladder whenever I'm at home. Also just hosing with water doesn't works well since the dust is sticky, you need to mop it with microfiber cloth. It would be better if you install at lower height where its easier to clean with cloth )
8. Sometime down the line, I may plan on constructing a store room / additional room on roof. Are there some basic things that I should keep in mind while the installation of solar panel?
Make sure it doesn't shades the panel. Also you can use the panels as shade your if vendor is willing to put at height, but make sure to have some way to clean the panel
I plan to close the installation work before end of May this year if everything works as expected!
Thank you in advance for your words of wisdom!!
