Team-BHP > Street Experiences
View Poll Results: Whats your top speed
50-99 kmph 62 4.35%
100-149 kmph 492 34.55%
150-199 kmph 632 44.38%
200-249 kmph 167 11.73%
250-299 kmph 41 2.88%
300+ kmph 30 2.11%
Voters: 1424. You may not vote on this poll
Closed Thread
Old 2nd July 2007, 12:47   #1276
tathagata's Avatar
Originally Posted by Sudipto-S-Team View Post
Tatha
You are not only dangerous for yourself and your in-laws but also for others sharing the road with you. The Omni tyres are not meant for that kind of speed and can't handle the heat generated by that kind of speed. I hope you didn't do it for any extended period of time. When an Omni overtakes me on the expressways, I slow down completely and let him pass.
Sudipto
Are NA Sudipto Da. Actually me and my brother-in-law was driving each other's cars alternatively. After driving the Wagon-R at such a speed I thought of pushing the Omni to its' limit. But its started to vibrate so much at 100+ that I didn't dare to drive it for long at that speed. May be a couple of minutes. But do you think even driving a Wagon-R at 140 Km/hr. at the Durgapur Highway stretch is not safe either. The car nicely coupes up to the speed though. Though I don't see doing it again in future as it consumes much fuel and reduces the overall average on long drive.
tathagata is offline
Old 2nd July 2007, 16:05   #1277
Sudipto-S-Team's Avatar
Thanked: 292 Times
I am not too sure about the Wagon R tyres. Please check the tyres for their speed rating. Here is a link that explains the various things written on the sidewall of a tyre
Tyre Sidewall Explained
Sudipto
Sudipto-S-Team is offline
Old 2nd July 2007, 16:29   #1278
gopz's Avatar
I ve done 135+ on my 5speed M800
gopz is offline
Old 2nd July 2007, 18:11   #1279
naveen.kk's Avatar
Thanked: 30 Times
i have recently done 180+ in my palio 1.6 S10, Handling was great, but i was running it with stock tyres, and stock mags, which are not perfect, they dont have proper wheel balance, so it started rattling, so i had to stop....
but there wasnt any car racing with me......
naveen.kk is offline
Old 2nd July 2007, 18:20   #1280
rjstyles69's Avatar
Thanked: 845 Times
Originally Posted by IronWolf View Post
120 - Baleno (Limited by the Koromangala Ring Road)
In a coupla months time after adding the KnN and the Headers will be going to chennai.. Goal?! - 180!
And what tyres are we running this on?
rjstyles69 is offline
Old 2nd July 2007, 21:20   #1281
IronWolf's Avatar
Thanked: 45 Times
Now dont curse me.. its the stock VXi (motorcycle) size tyres. I did not even bother to look at the tire wall for the size.
I think those are 175/65 R13s right?
Looking at getting 14 inch alloys (I wish R15s but not advisable I hear) and 195/60 tires however that might take about 5-6 months. I dont want them too wide and lose out on performance and FE. with these stock tires itself I have not found wanting for grip.
Remember I used to drive a 95 esteem with almost bald tires.
Are you saying hitting 180 on these stock tires are not advisable?
IronWolf is offline
Old 2nd July 2007, 21:31   #1282
rjstyles69's Avatar
Thanked: 845 Times
Please keep that 180 mark away for safety reasons till you get a tyre upgrade mate.
15 inchers you can and I have 2 frends who run the car on 15 inchers with no problem's.
Touchwood wish it remains the same, I wasnt this lucky and had a complete spin out on the GQ while driving to chennai.
Dont get there with those stock puny tyre's.Get an upgrade 1st, coz I neednt say what the situation is on the GQ.
Old 2nd July 2007, 21:41   #1283
Thanked: 292 Times
Check the tyre speed rating
The letter `S', if it is written on your tyre means they are rated for a maximum speed of 180 kmph. It may not be a good idea to test the maximum limit. At high speeds tyres generate a lot of heat. The rubber has a maximum capacity to hold steady in that heat. Beyond that, it will burst. However, speed ratings are given assuming the vehicle is fully loaded upto the tyre's capacity. So if you are driving lighter than that, then your tyre might hold good even beyond that rating.
I am not questioning your ability to drive at that speed - on a good empty road with a good car I am sure you can do it - but the tyre's ability to handle that heat might be suspect.
Sudipto
Old 2nd July 2007, 21:55   #1284
rks
rks's Avatar
Thanked: 19 Times
As noted by Sudipto, if your tyres are S-rated, it is not advisable to go as high as 180 kmph; you should get at least H-rated tyres, which will also give you good grip.
If your stock tyres are tubetype, a puncture or tube failure at those speeds could make your car uncontrollable due to sudden loss of pressure; tubeless tyres are preferable. In any case make sure your tyre presssures are at or above the recommended level before hitting such speeds; tyre bursts often occur due to keeping low tyre pressures.
rks is offline
Old 2nd July 2007, 23:33   #1285
IronWolf's Avatar
Thanked: 45 Times
You guys have just sold the idea for me to upgrade.. Arrggh I hate to admit that you guys are right in a way. Even though these bridgestones have got good thread and they are meant for baleno's manufacture est top speed of 175. (am to lazy to go and see the speed rating now )
With the filter and with some wind behind me I was hoping to squeeze an additional 5kmph and touch 180 on the same road Binz was referring to.. however maybe little safer with tubeless. yes these are tubed tires.
IronWolf is offline
Old 3rd July 2007, 00:24   #1286
iraghava's Avatar
Thanked: 281 Times
Iron - The Baleno stock size is 165/80 R13.
iraghava is offline
Old 3rd July 2007, 09:58   #1287
moralfibre's Avatar
Thanked: 14,471 Times
85 kmph on a 20yr old Tempo Trax.. which comfortably seated 12 people.
Steering does not center needed constant correction.
Was the Trax in production 20 years ago?
moralfibre is offline
Old 3rd July 2007, 11:08   #1288
Thanked: 322,204 Times
That 5-speed 800 rocks! Only Indian car I have seen where the speedo needle extends beyond the speedo's top speed marking.
GTO is offline
Old 4th July 2007, 02:44   #1289
IronWolf's Avatar
Thanked: 45 Times
No idea moral.. Could be even 10-15 but the thing is really old. The engine is supposed to be a merc sourced or designed engine or something. Its a UK national's Trax which we borrow at times so not sure of year of manufature .
IronWolf is offline
Old 4th July 2007, 07:06   #1290
190km/h in my chevrolet Impala 3.8
180km/h in my chrysler Intrepid 2.7
Jatt is offline
Closed Thread
