Old 21st June 2010, 13:22   #1471
m_upreti's Avatar
Thanked: 324 Times
Hi Wolfheart, gear slippage can be serious. Get it checked out and insist that it be done under warrenty. With my VLX it started like this only and I was unable to convince the A.S.S. till the gears started slipping to neutral from 3rd & 5th while driving.
Ultimately M&M replaced the gear box, seems some locking ring in the gear box was defective / broken.
You can reviw my posts on this issue in this thread.
Originally Posted by Wolfheart View Post
The funny thing is that my car goes very smoothly from 3rd to 4th, never had a problem with that. I had only asked him to check since it has slipped into neutral on a few ocaccasions while moving from parking.
m_upreti is offline
Old 29th June 2010, 14:02   #1472
prithvi_seln's Avatar
Thanked: 9 Times
suggestion on first service
There are standard checkpoints the *** will look into when doing the service as listed in the service book and incase we have some issues they will look in to it. thats is enough for your first service, hope there wont be any issues if you have taken care of the run in for the first 1000kms or so properly.
Hi Folks,
The 1st service for my vehicle (Scorpio SLE) is due in a couple of days. The maintenance schedule chart in the service booklet recommends the following:
1. Engine oil & oil filter change.
2. Rear differential oil change.
3. HVAC particle filter cleaning.
4. Inspection and rectification (if needed) of all other fluid levels, electricals, under chassis etc.
I am also planning to go in for wheel alignment and tyre rotation, but not at the ASC.
Apart from these, should I ask the ASC to do anything else as part of preventive maintenance?
Cheers,
Vikram
prithvi_seln is offline
Old 4th July 2010, 11:07   #1473
SS-Traveller's Avatar
Thanked: 28,767 Times
I wonder what might be the purpose / function for this bolt sticking out of the floorboard behind the clutch pedal in all VLX Refresh models (at least those that I've inspected, including mine). Just ruined a good pair of shoes on it. There is no provision for a dead pedal here (which the bolt might have held in place). Cannot figure out what purpose it serves. It doesn't seem to be holding anything on the underside of the car either, but the head of the bolt is behind another partition and cannot be removed.
Mahindra Scorpio : Issues & Solutions-abcd0001k100.jpg
Mahindra Scorpio : Issues & Solutions-abcd0020k100.jpg
Is this a redundant bolt? What do I do? Cut off the bolt flush with the floorboard? Or is there a purpose for this bolt to be there?
Spike, your advice please!
SS-Traveller is offline
Old 4th July 2010, 19:52   #1474
vigsom's Avatar
Thanked: 30,336 Times
It would be best to just cover the bolt with a rubber pad,say 4"x4"x2"
That would keep both the bolt and your shoes happy
vigsom is offline
Old 5th July 2010, 18:44   #1475
CasperRider's Avatar
The driver side power window of my Scorp has been occasionally not working in the past. M & M A.S.S has so far replaced the switch assembly and some connectors(yes, that is the way they repair something; keep replacing whatever comes in hand, until the problem is resolved). From today, it completely stopped working! I need to take it up to them tomorrow
CasperRider is offline
Old 5th July 2010, 18:48   #1476
akshay4587's Avatar
Thanked: 4,724 Times
Its confirmed that i am facing a wierd issue of air leakage in my Hawk.
Off late i have been driving it on highways with 100%AC,whenever a fast moving vehicle overtakes the hawk,or if i overtake a slower truck from left.
I feel a blast of warm air on my arm,from where,i dont know
akshay4587 is offline
Old 5th July 2010, 22:14   #1477
getsurya's Avatar
Thanked: 2,046 Times
Akshay,
I guess the door rubber lining might be the culprit. Check for gaps for the door as wells the door panel and the quarter panel gaps.
getsurya is offline
Old 6th July 2010, 10:10   #1478
raj_5004's Avatar
Thanked: 3,169 Times
simple. close the windows & drive!
kidding! as surya mentioned, its most probably the rubber lining, or beading as many say, that may have come loose.
raj_5004 is offline
Old 6th July 2010, 12:19   #1479
m_upreti's Avatar
Thanked: 324 Times
Could be M&M's way of testing the bolt for the dead pedal before the US launch.
Ask the A.S.S. to replace the window drive motor.
m_upreti is offline
Old 7th July 2010, 14:08   #1480
Thanked: 315 Times
I had the similar issue and was resolved with the similar solution. one good thing is i was able to find better service center. The new MPL service center in OMR is awesome... since it is new, your vehicle gets more attention.
klassics45 is offline
Old 8th July 2010, 11:01   #1481
m_upreti's Avatar
Thanked: 324 Times
I have / still have issues with the power windows specially the drivers side window. The glass rattles in the door when it is rolled down, while rolling up the motor dosent stop in time and tries to push up the glass further.
The passenger side switches work as per their own mind.
Have complained to the M&M Mumbai office yeaterday.
m_upreti is offline
Old 8th July 2010, 14:07   #1482
Thanked: 315 Times
Did they change the window drive motor in the door? my issue got resolved only after replacing it.
Old 8th July 2010, 17:24   #1483
m_upreti's Avatar
Thanked: 324 Times
Not yet, I need to push them for the replacement when I go the the A.S.S. this time.
m_upreti is offline
Old 9th July 2010, 15:28   #1484
I'm not sure what to do now. I finally decided to go to the A.S.S and booked an appointment, but when I started the car and tried to operate the window, it goes vrooom! This happened yesterday morning and I tried at least 50 times from then till now, and it always works! They have already checked all possible loose connections etc and also replaced the switch assembly last time.
Old 10th July 2010, 11:06   #1485
m_upreti's Avatar
Thanked: 324 Times
There seems to be no other option except to have the motor replaced.
m_upreti is offline
