Old 11th March 2010, 22:07   #1831
tsk13's Avatar
Thanked: 362 Times
Originally Posted by mkh View Post
SCRATCH X ROCKS!!!
Wonder what meguiars is thinking- going by the way our roads are, this product will sell in tons to those who care about their cars...they must bring this soon.
Sorry could not post pics-wanted to, but in my anxiety, forgot.
MKH, try 3M's Liquid Wax and Bruise marks (that of other object's paint) are successfully removed (90% of the time). In event that the desired result is not obtained, try 3M's Finesse It Rubbing Compound and post-rubbing wax it. I'm referring this as this is way cheaper and does the same job.
Originally Posted by csateesh View Post
Where did you pick up the Scratch X ? And have you tried the ultimate compound ? I was told that the Ultimate compound is even better
Sateesh
Try the 3M stuff referred above.
Originally Posted by Raccoon View Post
As long as the panels look like the normal painted stuff, wax should work find on it. I use Turtle Wax on both my bikes ...and on the plastic side panels, fairing, etc. On the plastic parts (non painted surface), fairing visor, speedo, etc. I use F1 Dashboard cleaner.
In any case, I don't think there is a dedicated product for use on plastic/ABS parts which have normal paint like surface.
Where've you been? The Detailing threads have lost their charm as people like you, Parm and Bigman have not been active lately.
tsk13 is offline
Old 12th March 2010, 21:49   #1832
sohail99's Avatar
Thanked: 235 Times
3M Finesse-It is one hell of a clear cutter!!
just rub in one spot for lil' longer and you get a depression in the area!!
btw I bought 'Eagle1 Nanowax spray' for use as booster wax
results are really impressive!
Got a 'just waxed' look in a little over 15 minutes!
Now I just need to compare Megs UltimateQuikWax with nanowax spray!
then we'll decide the winner!
sohail99 is offline
Old 12th March 2010, 21:55   #1833
tsk13's Avatar
Thanked: 362 Times
You're the first person whose negative about 3M's Finesse It rubbing compound. The key to right result lies in the correct usage. If one rubs hard obviously any good part will give away and the paint will be gone. In the end, it's an abrasive.
Moreover, the Nanowax being referred has been non-advised by the oldies in Detailing.
tsk13 is offline
Old 12th March 2010, 22:15   #1834
sohail99's Avatar
Thanked: 235 Times
No no no!! 3M Finesse It is totally awesome!!
Actually my mom's U-VA had some blemishes and paint spots!
3M Finesse It really worked like a charm on those spots etc!
after finesse-it, I used UC to remove the scratches left behind by the compound and the overall finish was perfect!
Applied 2 coats of wax to seal!
sohail99 is offline
Old 12th March 2010, 22:27   #1835
NOTORIOUS's Avatar
Thanked: 124 Times
^^ if you are usung UC then dont need to use 3M Finesse It .
NOTORIOUS is offline
Old 12th March 2010, 22:31   #1836
The paint is being below the clear coat and the paint actually being scratched, what is the alternative? Have used it with good results and as others said, it all depends on proper usage. It is of course a rubbing compound but with very fine particles as far as I know.
janitha is offline
Old 12th March 2010, 22:37   #1837
NOTORIOUS's Avatar
Thanked: 124 Times
i always use 3M Finesse It with bare hands.
Old 12th March 2010, 22:53   #1838
sohail99's Avatar
Thanked: 235 Times
Actually UC cuts initially and then starts to breakdown!(requires multiple passes)
3M maintains its cutting power as its abrasives don't degrade and are suitable for stubborn blemishes and spots!
sohail99 is offline
Old 12th March 2010, 22:54   #1839
NOTORIOUS's Avatar
Thanked: 124 Times
^^ from where did you get UC from ???
Old 12th March 2010, 23:14   #1840
sohail99's Avatar
Thanked: 235 Times
from US via 20north.com A lil' too expensive, but kinda reliable!
sohail99 is offline
Old 12th March 2010, 23:59   #1841
tsk13's Avatar
Thanked: 362 Times
Janitha, for paint bruises first try something like 3M Liquid Wax which does the job 90% of the time. A green Auto bruised against my friend's White i20 and 3M Liquid Wax was able to remove 90% of the marks. The sole abrasive nature of 3M's Finesse It makes me use it as a last resort.
Man, simple play of words can totally convey a different meaning.
Same here. For complete polishing I suggest Professionals to do the job.
tsk13 is offline
Old 13th March 2010, 01:16   #1842
Raccoon's Avatar
Thanked: 116 Times
Finding it difficult to keep up with different forums I'm on, due to time constraints. :( Also, since most of my work involves sitting in front of a screen, doing more of it is straining my blinkers. At this rate maybe you will also find a dull looking Raccoon scurrying on Opthalmic forums, Headache forums, etc...
Thanks for missing me tho...
Raccoon is offline
Old 13th March 2010, 13:43   #1843
mkh
Thanked: 135 Times
I have the 3M liquid wax- wonder how would a wax remove bruise marks. Used it today(3M Perfect It Liquid wax)- did not see the bruise marks go. Wax at times covers up the marks, but once wax layer gone, the marks will come back. I have seen this with the Paste Waxes. Only if there is another objects paint that comes on top of your paint will wax work, but if there is a SCRATCH, it will not.
Rubbing compound will remove a layer of paint hence will clear it away completely
BTW the 3M products you are referring to- are these the ones sold in india? I have seen 3M wax, but not the rubbing compound.
The 3M rub comp is used at detailing centers and also sold in the US. Scratch X is cheaper than 3M rub Comp.
3M i feel is a leader and tad better quality than Meguiars in all products but costs more( from the US). Have not tried the indian prods, but surely they will be lesser in terms of quality than their US brothers.
mkh is offline
Old 13th March 2010, 18:09   #1844
mkh
Thanked: 135 Times
Session
Went in for a detailing session today to try out my latest shipments from the US
I used the microfiber- blue set i had got, its fantastic. It cannot be used for detailing as its toooo thick. But for buffing, man it feels better than our bath towel!!! Almost felt like i could take a bath with it!
I got another set - Smart Wax Supra Towels, they are almost comparable with the blue ones, posting some pics of those too. The thickness is almost same, plushness little lesser.
Both these are my set for wax removal and buffing
I used the 3M liquid wax- Show car Liquid Wax. Applying was easy, however removal had small challenge as the parts where it dried most and little more was applied, removing needed some extra effort. This is not what i have experienced with Meguiars Paste wax also, where removal was easier.
The effect is decent- frankly i think for our use all of them are the same, only that different packaging and different brand. (except for Turtle wax, which MY EXPERIENCE says is inferior to these)
Also pics of my arsenal of car care products( minus ScratchX which also i have but does not figure in the pic). I also got Waxpol Rubbing Compound, but i found it no good.
mkh is offline
Old 13th March 2010, 18:34   #1845
aks_karthik's Avatar
Thanked: 342 Times
Hi mkh,
Have you used Meg. Ultimate Compound ?
whether it's worthy to buy to remove small clear coat scratches?
what is the price?
aks_karthik is offline
