Team-BHP > Motorbikes
Old 19th December 2017, 12:37   #406
Thanked: 26 Times
re: Ridden: Bajaj Dominar 400
Originally Posted by mohansrides View Post
Congratulations New2CarZ. That white bike looks excellent. I was almost going to get the white. Enjoy the ride and be safe.
To answer your question, there is a switch on the right hand side of the handlebar that functions as a master switch for the headlights. If that is not turned on, then the headlights are stuck on high beam even if you switch them to low beam through the switch on the left of the handle bar. Check it out.
Thanks Sir. That switch is to toggle between DRL and main head lights (with the left side switch to toggle between high beam and low beam on the main head light).
I was asking if we can some way make the DRL low beam only. But now I understand the naivety of that question, as the DRL bulbs itself might be high beam by design on this bike.
I feel bad for the oncoming traffic if I forget to switch from DRL mode to low
beam head light mode for some time.
New2Carz is offline
Old 19th December 2017, 17:22   #407
goandude's Avatar
Thanked: 1,298 Times
Originally Posted by Neeraj1903 View Post
Check with SVC if your ECU has update number 116. That's the latest update which came in May and this problem was sorted.
But a June bike should automatically have received that update, no?
Went on 14th to Khivraj Bajaj for the ecu update. They had to send the chassis number to Bajaj Pune and get an otp. However, the Pune guys were busy and the OTP came Yesterday.
Went today and got the 116 ECU update done, Felt it pulls better, but this may just be mental BHP
For info of all:- My blue indicator light just above the headlight switch is not working, so I checked with them. Apparently the whole throttle housing has to be changed. There is no separate led light that can be changed
goandude is offline
Old 21st December 2017, 20:18   #408
Hells_Fury's Avatar
Thanked: 202 Times
Congratulations. Not sure what vibes you are talking about. But, keep your fingers crossed and wait for first service. Clock 500 KMs ASAP. Post some pics in the mean time.
I felt the vibes predominantly in the handlebars and the tank area. I've done about a 100 KM on the bike now and the vibes do seem to be getting lesser. Hopefully things should settle down post the first service.
Hells_Fury is offline
Old 21st December 2017, 22:53   #409
Thanked: 26 Times
I have noticed that the bike stalls sometimes when the neutral light is On as well when we release the clutch. This I observed when the neutral indicator glows even when we try to shift from first to neutral but the gear has not slotted in to neutral.
New2Carz is offline
Old 23rd December 2017, 13:12   #410
Ricci's Avatar
Thanked: 1,179 Times
If a touring based bike like the Dominar has such a bad horn, I can only imagine what the horn is like in the other smaller siblings in the Bajaj line-up.
The Pulsars have a louder horn actually, my 2007 P220 had a car like horn, although OEM suppliers may change over time and I don't know if subsequent/recent ones have toned the horns down.
Yes, it's happened with me a few times too. The neutral indicator lights up sometimes even when the bike is in gear, so releasing the clutch makes the engine stall. Rare enough and only occurs while motionless, so I'm not much concerned about it.
Ricci is offline
Old 27th December 2017, 17:13   #411
uday.ere's Avatar
Thanked: 2,692 Times
Dominar 400 With A Brand New Red Color
As per an article on Thrustzone, Dominar 400 is to be launched soon in the eye-catching red colour.
The concept CS400 was displayed in Red at the auto-shows and not having the red paint scheme at launch seemed odd. However, looks like Bajaj will be adding this Red as part of the 2018 model lineup.
Source : https://www.thrustzone.com/2018-domi...colors-launch/
Uday
Ridden: Bajaj Dominar 400-dominar400spiedredcolorfactorybajaj432x430.jpg
uday.ere is offline   (1) Thanks
Old 1st January 2018, 10:47   #412
Thanked: 860 Times
There will be a new blue colour along with red in 2018. It seems golden rims are standard in 2018 edition . Also, there will be a green shade according to a different source.
https://auto.ndtv.com/news/exclusive...-spied-1794053
Neeraj1903 is offline
Old 2nd January 2018, 11:22   #413
Thanked: 860 Times
Red coloured Dominar spotted at Dehradun.
Ridden: Bajaj Dominar 400-img20180102wa0016.jpg
Ridden: Bajaj Dominar 400-img20180102wa0017.jpg
Neeraj1903 is offline   (8) Thanks
Old 2nd January 2018, 12:06   #414
R-Six's Avatar
Thanked: 1,778 Times
Red colored Dominar spotted at Dehradun.
Wow!! The color combination locks a million bucks! IMHO, I think this is the best shade I have seen so far. It is more appealing than the rest of the shades. I think the golden color of the alloys are making it look even more upmarket.
R-Six is offline
Old 2nd January 2018, 13:11   #415
Maverick5490's Avatar
Thanked: 2,011 Times
The color combination looks stunning for sure, reminds me of my RD.
Ridden: Bajaj Dominar 400-img20171118wa0028.jpg
Maverick5490 is offline   (1) Thanks
Old 5th January 2018, 22:06   #416
Thanked: 2,201 Times
Red Dominar with Golden Alloys in showroom: Video posted on youtube. Also seen is Matt Black with Golden alloys
payeng is offline
Old 7th January 2018, 19:57   #417
goandude's Avatar
Does the Dominar have a relay fixed to the OE horn? When fixing an additional horn to my bike, my mechanic told me that it has one and just attached the additional horn with wires connected to the OE horn. It sounds much better now, but I was wondering why should a single horn require a relay?
goandude is offline
Old 7th January 2018, 20:06   #418
VW2010's Avatar
Thanked: 4,567 Times
A relay is always a safer bet. It has lot of benefits. Just google about relays. A fuse box and Relay helps from short circuit, allows shortest path for power supply and lastly also helps you to cut off power with a single switch.
But if they have a relay even for a single horn it means they thought about safety.
VW2010 is offline
Old 7th January 2018, 21:11   #419
Geo_Ipe's Avatar
Thanked: 3,711 Times
Here's a spyshot of the new blue shade!
Source: https://auto.ndtv.com/news/exclusive...-spied-1794053
Ridden: Bajaj Dominar 400-2018bajajdominarbluecolourspied_827x510_51514705383.jpg
Geo_Ipe is offline   (1) Thanks
Old 8th January 2018, 21:23   #420
Thanked: 150 Times
I am thinking of buying a dominar and the New red shade has captured my attention rather violently. Regarding the blue shade, how different is this from the existing Midnight blue ? Looks awfully similar to me. I am referring the bike in this YouTube video review
Last edited by v6kgang : 8th January 2018 at 21:29. Reason: Checked right website for information
v6kgang is offline
