Old 3rd January 2011, 16:48   #91
4x4addict's Avatar
Thanked: 4,648 Times
re: Unreasonable dilemma! Thar Vs Gypsy! Mostly resolved Page 9.
Originally Posted by gsferrari View Post
What for? You just need a compressor right? Isn't the blower factory fitted? Even if it isn't - shouldn't cost more than 15k for the LOT!
Another ploy to make sure the customer is at the mercy of the dealership. Maruti follows a similar policy with the Gypsy. I paid 45000 for my Gypsy AC installation but it included everything and then some. Thermal insulation, piping, 6V10 compressor, Superking blower, custom ducting etc. At least I am happy with my install.
What is the breakup for the 48k?
@gs: The thar has only the blower. In addition to this you will need to buy the following:
1) Compressor, mounting & fanbelt
2) Evaporator coil & fan
3) Condensor
4) Gas Tank/reservoir
5) Additional Piping
6) Labout.
Even then 48K is expensive. However, it will cost atleast 25K at the dealer for these things.
4x4addict is offline
Old 3rd January 2011, 16:50   #92
Tejas@perioimpl's Avatar
Thanked: 9,764 Times
3) Condensor
6) Labout.
Thar already comes with:
- Compressor mounts & fanbelt
- Fan
- Insulated Piping.
Tejas@perioimpl is offline
Old 3rd January 2011, 16:53   #93
Jaggu's Avatar
Thanked: 17,299 Times
No Tejas those pipes are for heater fluid circuit. AC will need separate aluminum pipe, also compressor mount since what it comes with is a dummy pulley fitment, which when removed will give access to the engine for mounting bolts.
Belt am not sure but if the dia of compressor pulley is small then yes, otherwise you will require plus size belt. But should be readily available.
Spike can you clarify if ^^^ is correct.
Jaggu is offline
Old 3rd January 2011, 16:59   #94
MileCruncher's Avatar
Thanked: 1,345 Times
- Fan
- Insulated Piping.
The Fan is for the Radiator. You'll require another 1 or 2 fans for the evaporator. Else its a recipe for Engine Over heating
Jaggu Bhai, The pulley and belt is not a problem as they are a direct transplant from the Bolero/Xylo. The major issue is placement of the evaporator coil.
MileCruncher is offline
Old 3rd January 2011, 17:05   #95
khan_sultan's Avatar
Thanked: 6,469 Times
Originally Posted by MileCruncher View Post
...The major issue is placement of the evaporator coil.
MM is in the process of creating a SoP for the same. The same procedure will be followed by all dealers for A/C fitment. That's what the news is from MM
khan_sultan is offline
Old 3rd January 2011, 17:09   #96
Jaggu's Avatar
Yup thats what i meant also, the one that comes in the Thar from factory cannot be reused for AC.
What is SoP? ^^^
Jaggu is offline
Old 3rd January 2011, 17:14   #97
What is SoP? ^^^
Standard Operating Procedure AFAIK
Old 3rd January 2011, 17:17   #98
Jaggu's Avatar
LOL am indeed , i thought it was another new part. That would be nice though, so that the dealers wont goof it up while fitting an AC.
How is bolero set up? One of 2 fans? The pics posted elsewhere did not show any additional fans. So if the stock one can be replaced with an upgraded electric fan, it should work? right?
Jaggu is offline
Old 3rd January 2011, 17:17   #99
SPIKE ARRESTOR's Avatar
Thanked: 1,545 Times
- Fan
- Insulated Piping.
Insulated piping?
Why 2 fans?
Jaggu, you are correct, AC inlet and outlet pipes are different. Did you notice two holes plugged with rubber grommets near the firewall?
Throw away the idler pulley replace with a compressor, no change in belt, belt tension etc.
Spike
PS-Can help you out with parts if required.
PPS- SoP also means Start of Production :-P
SPIKE ARRESTOR is offline
Old 3rd January 2011, 17:23   #100
Originally Posted by SPIKE ARRESTOR View Post
Why 2 fans?
The Bolero Setup is 1 electric fan for the evaporator and one fan for the radiator. The Radiator Fan unlike smaller petrol / diesel engine is always rotating. I understand due to absence of regulated airflow to the radiator as well the smaller evaporator coil requiring higher per sqcm heat dissipation 2 electric fans might be needed.
Let Spike clarify!
Old 3rd January 2011, 19:01   #101
The fan for the Radiator in a Bolero is of Viscous clutch type.
Spike
Old 3rd January 2011, 19:29   #102
Jaggu's Avatar
Yup i saw those plugs. No need for cutting hole on fire wall etc.
This i didnt quite understand, do you mean the AC pulley is similar in size? Idler pulley seemed small?
And hence it runs through out, and if am not mistaken saw the same set up on the Thar Crde?
Jaggu is offline
Old 3rd January 2011, 20:21   #103
a) This i didnt quite understand, do you mean the AC pulley is similar in size? Idler pulley seemed small?
b) And hence it runs through out, and if am not mistaken saw the same set up on the Thar Crde?
a) Yes, same to same. Remove dummy pulley, fit Compressor, bolt on!
b) The viscous fan is engaged only under 5-15% of normal operating conditions, otherwise the radiator is cooled through Ram air cooling, this is done to reduce the parasitic losses resulting due to parts coupled to the power plant. The viscous fan engages and disengages in accordance with the bimetallic coil placed inside the assembly. This happens when a pre-set temperature is reached.
Spike
Old 3rd January 2011, 20:42   #104
Spike
So what you mean to say that there will be instances when the fan shouldn't be moving right. But I have never seen that happen i.e. the fan actually not rotating while the engine is on.
Could you please explain further.
Old 3rd January 2011, 21:08   #105
@MC, have you seen it when the Ram air is actually in full swing ? No, you must have seen it while in Kerb idle, in most conditions the fan is just freewheeling and not actually engaged. During freewheel the fan rotates but only at ~ 800 RPM, it is only when the engine is loaded the fan engages. This is felt when:-
1. The engine sound increases to a slight roar
2. Fan spins faster ~ 1800 RPM and above.
Spike
