Old 2nd November 2008, 11:38   #8896
akshay4587's Avatar
Thanked: 4,722 Times
How are MTX speakers?
when compared to brands like JBL,Pioneer and Likes?
akshay4587 is offline
Old 2nd November 2008, 22:02   #8897
jkdas's Avatar
Thanked: 1,497 Times
Anyone who has checkout JBL P6563C ?
Any idea about its price?
jkdas is offline
Old 3rd November 2008, 23:53   #8898
Thanked: 163 Times
Max USB capacity that HU can handle
What is the maximum capacity USB drive that the HU can handle?
Specifically Pioneer 3090UB and Sony 470?
Manuals of both the above HUs do not mention anything about maximum USB size (in terms of memory) handling capacity.
Bouncer is offline
Old 4th November 2008, 07:27   #8899
Thanked: 4,910 Times
I dont think there is a limitation to the actual size. some folks have even got portable HDD's working. . there are limitations to the number of files/subfolders you can place in a folder , and the current supply capablities of the USB port are limited , but not specified.so some brands of portable HDD's work fine , others do not - only way is to try each one .
greenhorn is offline
Old 4th November 2008, 17:25   #8900
ariendj's Avatar
Thanked: 159 Times
how are the GTO 607C components??
how much do they cost?
ariendj is offline
Old 4th November 2008, 19:13   #8901
satansvalet's Avatar
Is it advisable to buy ICE components from the US?
I am interested in buying the BLAUPUNKT HAMBURG MP57.
In one of the posts the price list of the entire range was mention in which the above was priced at Rs.15,950/-
And in the same post a website (Midwest Electronics - Blaupunkt Sales and Service) mentioned in which the price of the same is roughly in INR is Rs.9,500/-
My friend is coming this december from the US.So do reply ASAP!!!
satansvalet is offline
Old 4th November 2008, 23:36   #8902
vamsi.kona's Avatar
Thanked: 573 Times
Hi, can anyone suggest a good ICE set up for palio mjd. I would like to use the stock positions as much as possible. Cost is not a restraint and if the budget is high then I would go with the ICE set up in stages.
I generally listen to Indi-pop and soft music, while my friends(with whom I travel the most) are into heavy metal and Hard rock. So i am looking for a set up which would be able to do justice for both.
vamsi.kona is offline
Old 5th November 2008, 10:18   #8903
navin's Avatar
Thanked: 9,959 Times
Originally Posted by vamsi.kona View Post
Hi, can anyone suggest a good ICE set up for palio mjd. So i am looking for a set up which would be able to do justice for both.
I would start with a HU, amp, 4 speakers. a good 4 ch amp helps a lot and does not take up too much space. If you are willing to sacrifice boot space you can add a sub. A custom FG sub enclosure will cost more but will occupy less space.
navin is offline
Old 5th November 2008, 10:41   #8904
kunaldhami's Avatar
Thanked: 82 Times
Originally Posted by kunaldhami View Post
Hi
My good friend just booked i10 Asta with Sunroof and we need advice for ICEing..car is to be delivered in mid November so we have some time to finalize the setup.
3)where in Surat can I listen to other brads like Ground Zero?
one more question
Is stock HU good enough to drive everything?
Please help..
kunaldhami is offline
Old 5th November 2008, 10:54   #8905
SRShrikanth's Avatar
It is certainly a good idea to shop for Blau units from Midwest, delivered in the US. You obviously dont have warranty on those goods when you bring them here, but can avail the excellent Blau A*S*S in Mumbai - for a cost though.
Hamburg is a good unit but has a higher spec now available that has Bluetooth streaming & phonebook option as part of the standard unit. You could consider picking that up at Midwest prices as well.
Happy Hunting.
SRShrikanth is offline
Old 5th November 2008, 14:02   #8906
thanks a lot bhai.
Also,is the hamburg equipped to drive a sub and component speakers?
Old 5th November 2008, 15:58   #8907
Am assuming you are doing to drive the sub & comps off an amp, and not off the HU.
Yes, the Hamburg is equipped for the same.
Old 5th November 2008, 16:52   #8908
Hi All,
I have a swift with following setup ,need a advise on the head unit
I have a
MMC690 6 x 9 inch three way loudspeaker with external crossover.
Sound stream Tarantulla component in the front
JBL GT5-A604 -4 Channel Full-Range Amplifier
Can anybody suggest me good head unit ?
scavenger is offline
Old 5th November 2008, 16:59   #8909
ethanhunt123's Avatar
Thanked: 1,035 Times
Whats your budget for the HU ? Kenwood / Pioneer make some good HU's which are VFM.
ethanhunt123 is offline
Old 5th November 2008, 19:19   #8910
vamsi.kona's Avatar
Thanked: 573 Times
Hi Navin,
Can you suggest me a few options in HU, Speakers and Amps
