Old 23rd December 2013, 15:09   #106
ampere's Avatar
Thanked: 13,628 Times
Originally Posted by TheTeacher View Post
I have an MMI standalone GPS device. Any pointers on how I can accomplish planning on a PC / xfr to the MMI? Thank you very much.
It's difficult to get the trip planning to work. May be you can use Google Earth for this purpose. Still I am not fully sure. Need to dig more to find out.
ampere is offline
Old 24th December 2013, 16:06   #107
Thanked: 371 Times
re: Sygic India GPS Navigation
followed one of their feedback to user comments & renamed the sygic_mmi folder (instead of deleting it). It is now downloading the essential resources and required maps. I am not going to download the maps all over again
null is offline
Old 28th December 2013, 22:07   #108
TaureanBull's Avatar
Thanked: 329 Times
I have downloaded Sygic India with MMI maps on my Samsung Tab 2. Google Maps are the most updated maps without any doubt even to the extent that I have found the updated highway numbers which have been updated on any other software. Both sygic and google have good coverage in the remote areas in North East.
My Use
I select my route on the google map on Tab 2 and from the options I copy the map for offline use. Thereafter I select the "Navigate to" option in Google Map which asks for option of software for navigation and I select as "Sygic". A wonderful way of using google map data for navigation by Sygic.
TaureanBull is offline
Old 28th December 2013, 23:22   #109
mvp
Thanked: 18 Times
Originally Posted by TaureanBull View Post
I have downloaded Sygic India with MMI maps on my Samsung Tab 2. Google Maps are the most updated maps without any doubt even to the extent that I have found the updated highway numbers which have been updated on any other software. Both sygic and google have good coverage in the remote areas in North East. My Use I select my route on the google map on Tab 2 and from the options I copy the map for offline use. Thereafter I select the "Navigate to" option in Google Map which asks for option of software for navigation and I select as "Sygic". A wonderful way of using google map data for navigation by Sygic.
I use an iPhone and am quite happy using google maps along with the 3G network for navigation. I am however stuck in remote locations or at locations mobile connectivity is not good enough.
I have been looking for a navigation app to be used in my iPhone which can work off line. Tried downloading sygic but could not successfully install. Does this work well with iOS or is it that I have not figured it out correctly? I find that India is not listed under "Asia"
I also read in this thread that sygic is now free. Does this really work well or a paid app is better?
"Sygic and mapmyindia" is now available for INR 1900/- at the apple store but the reviews are not encouraging at all. I prefer continuing to use my phone rather than buying a navigation unit for my car.
mvp is offline
Old 3rd January 2014, 18:21   #110
Thanked: 741 Times
I have been looking for a navigation app to be used in my iPhone which can work off line...
mvp, you can do the following on your iphone, especially if you are using ios7.
1. Go to google maps and navigate to a particular city or area on the map, where you expect to pass through duing your trips.
2. type 'ok maps' in the search bar located above and click on the search symbol.
3. The phone will cache the area of the map displayed on the phone.
4. Sometimes you might get an error if the map area is too big. For that you will have to zoom in to reduce the area of the map.
5. The map will now be available offline even when there is no mobile connectivity.
Happy navigating offline!
saleem_k is offline
Old 3rd January 2014, 18:39   #111
Fillmore's Avatar
Thanked: 597 Times
The google map will be cached locally, however when you start the trip it still tries to connect to the internet and if it is not able to you cannot proceed. So this caching too leaves you stumped.
Try this, cache a map, switch off your data and wifi connection.
Are you still able to get google maps to show you online navigation ? The problem is to set the destination you have to go to the Search box, and that does not proceed without a connection.
Fillmore is offline
Old 3rd January 2014, 18:45   #112
Thanked: 741 Times
Hi Fillmore,
The offline caching can be used only to see where you are located on the map. It will not help you search or do anything without an internet connection. I have tried using offline google maps in iphone and it will show me where I am on the map. I won't have voice guided navigation though.
I think it's good enough as long as you don't need active navigation help. If you just want to keep track of where you are heading to and whether you are not on the wrong track, the offline caching in google maps works perfectly fine.
saleem_k is offline
Old 3rd January 2014, 20:15   #113
Fillmore's Avatar
Thanked: 597 Times
Hi Fillmore,
Ok got you. Yes we can use it for this.
Fillmore is offline
Old 7th February 2014, 22:26   #114
Thanked: 25 Times
I use Sygic MapmyIndia app on my iPhone every time I drive out of Bangalore and have found the app to be very stable and accurate.
I have one question though - I always find the speed readout on the app to be always about 6 to 7 kmph lower than what the speedometer shows. And I have tried this on many vehicles, so it is not that one particular vehicle speedometer is wrongly calibrated.
Has any one noticed this too? If yes, what possible explanation could there be for this anomaly?
Thanks in advance!
rogercharlie is offline
Old 8th February 2014, 10:00   #115
Thanked: 7,692 Times
Originally Posted by rogercharlie View Post
....I always find the speed readout on the app to be always about 6 to 7 kmph lower than what the speedometer shows. And I have tried this on many vehicles, so it is not that one particular vehicle speedometer is wrongly calibrated....
It is not an anomaly. What you see on Sygic is your 'true' speed .
ALL speedometers have a margin of about 5% - it will always show a higher speed than what you are actually doing. This margin is increased further should you upsize beyond acceptable limits. Here is an old thread discussing this - http://goo.gl/P8Yu59
Dry Ice is offline
Old 12th February 2014, 19:52   #116
sdp1975's Avatar
Thanked: 1,278 Times
What's the download size of the maps ? Is it for all of India or statewise ?
I see 44M as the size listed here https://play.google.com/store/apps/d...sygic.aura_mmi
sdp1975 is offline
Old 12th February 2014, 20:10   #117
Simhi's Avatar
Thanked: 1,306 Times
Ideally, you should be going in for Sygic India Free download which is around 39MB to 45MB which is only the application. Once the application starts for the first time, you are given the option to download for one or more individual states. For Maharashtra, the size is around 112MB. Along with it you might have to download additional resources around 35MB.
Simhi is offline
Old 12th February 2014, 21:08   #118
condor's Avatar
Thanked: 16,902 Times
The total full app should come to about 700MB.
condor is offline
Old 24th February 2014, 12:06   #119
procrj's Avatar
Thanked: 5,740 Times
Downloaded Sygic India free version and maps for south india. Planned a route yesterday and Sygic estimates the journey time to be 8+ hours. Mapped out the same route on google and estimated journey time is around 4 Hours. Has anyone faced similar issues with Sygic time estimates?
Route map
procrj is offline
Old 24th February 2014, 13:17   #120
ampere's Avatar
Route map
I think no point looking at travel time estimates. Better to go with details furnished by fellow members. I have never used these estimates myself.
ampere is offline
