Old 22nd October 2024, 17:24   #10471
Thanked: 1,935 Times
Re: The Home Appliance thread
Originally Posted by Nithesh_M View Post
Yes. The lock is a bit too tight to move with any object and it only seems to move if I insert a 3 piece plug. Which is weird because the switches were all installed about 2 years ago.
Originally Posted by Kiyon View Post
This is all not worth the hassle if you are happy with the cable length and it reaches all corners of the house from a common switch. All that you need is change the existing point which is stuck with a new one , something like below (quick and easy )
This one is from Havells and you can easily push the earthing hole with plastic.
I agree and would also advise not to use any extension. It'd be much easier and cheaper to replace faulty socket with a good one where the earthing pin can be pushed easily to allow 2 pin plug.
Aviator_guy is offline
Old 22nd October 2024, 18:29   #10472
sagarpadaki's Avatar
Thanked: 6,801 Times
Need help.
Electrician suggested we snip the plug and install normal 3pin plug on the vacuum cleaner but I'm not sure of it since I assume it will void warranty.
Does anyone have a solution? Is there a modular 16A socket I can buy and replace my existing 20A socket in kitchen?
Replacing the 2 pin 16A plug with a 3 Pin plug will not void warranty. You can go ahead and get a good quality 16A plug from Cona/Lisha/HiFi/Anchor and do a transplant. The earth pin will be dummy but will work for pushing the locking pin in the socket.
When I purchased Karcher pressure washer years ago, it came with EU plug. The dealer chopped off the EU plug and installed Indian 16A plug. No impact on warranty.
sagarpadaki is offline   (2) Thanks
Old 23rd October 2024, 15:05   #10473
ron178's Avatar
Thanked: 8,067 Times
Do not use a coiled extension cable for high loads. It gets hot, and is a fire risk. Not just theoretical: I have seen one start to smoke.
I've heard extension boards get hot with vacuum cleaner so unsure which way to go.
I don't know about the board, but I had a huge scare when my tiny 600W Bissell 1611 stick (British plug) started billowing out smoke last month plugged into a surge protector. Even with the small converter block I used at home, it always became very hot within a couple of minutes.
ron178 is online now   (1) Thanks
Old 23rd October 2024, 15:57   #10474
Thad E Ginathom's Avatar
Thanked: 29,988 Times
It's not good to use a coiled electric cable, but, to be honest, the one I saw catching fire was one of those plastic-drum-with-socket things, so the cable was tightly coiled, and the load on it was an electric room heater, could have been 2kW.
Thad E Ginathom is offline
Old 24th October 2024, 20:04   #10475
mxx
Thanked: 313 Times
I am trying to decide between these 2 refrigerator models.
Electrolux 360L Double Door Refrigerator Bottom Freezer
https://amzn.in/d/iThwyoT
Panasonic 400L Double Door Bottom Mount Refrigerator
https://amzn.in/d/fh55Hsc
Any suggestions?
I dont have any experience with either brand.
There is a Rs.3000 difference of pricing between these 2 models.
mxx is offline
Old 26th October 2024, 13:17   #10476
Thanked: 158 Times
Originally Posted by MyLife_MyCar View Post
Anyone using any of these brands? Or a smart lock in general? How’s the experience? Do you suggest to get one or stick to traditional locks?
I’ve been using hale digital lock on all my rooms and main door for past 3 years without any complaints. Reduces a lot of hassle related to keys.
Dr Alpha is offline   (1) Thanks
Old 26th October 2024, 15:02   #10477
Thanked: 412 Times
I bought a Bluestar Inverter 5 star ac in 2021 and we have been never happy with the cooling. In the initial year, the guys from Bluestar would say this is the maximum that this ac can cool and when I would show my other same-sized bedroom with Voltas they would just say cooling differs from brand to brand. The problems started even more after the first year warranty. I have had to pay innumerable times for gas recharge and also last year had to change the entire coil itself. When the guys mentioned about changing the coil, I had made up my mind to buy a new ac there and then, but they somewhat convinced me that out of a million sometimes once in a way one experience goes awry and asked me to change the coil and stick around with Bluestar as they are a good brand. Now its come to a pass that every 2-3 months there is gas leakage and every visit they want 1500 to top up. Now that its Diwali time, problems with AC have begun and I am on a lookout for ac with five year COMPREHENSIVE WARRANTY. The thing is it seem sonly Bluestar is offering one which covers gas leakage at the moment LG says it does but only if it is caused due to compressor issues. No one else does even if you pay upwards of 50K for Mitsubishi or Ogeneral. I hear some Carrier acs offers comprehensive warranty at Vijay sales according to their website, so will be checking those this weekend. Anyone have any other suggestion, please do advise, thanks.
jomyboy is offline
Old 26th October 2024, 18:15   #10478
Thanked: 886 Times
Infractions: 0/2 (15)
Voltas also offers a 5-year Comprehensive Warranty on some models of its ACs bought through Croma, I bought one online through Croma's website in August with a 5-year comprehensive warranty, free installation and free AC wall mounts as well, it was quite a good deal. Do check out their terms and conditions though and double-check that the AC is eligible for 5 year Comprehensive Warranty from the Croma store near you.
Godrej, Hitachi and Carrier also have a 5-year extended warranty on some of their ACs sold through select channels, but I don't have much information on the same.
However, of all these brands, I have felt that Voltas has been offering an overall better experience (two ACs in my home and a handful in our family) with value-for-money products, although we do have all Blue Star ACs in our supermarket and they have functioned well thus far too.
yedukrishnan199 is offline   (2) Thanks
Old 26th October 2024, 19:28   #10479
MyLife_MyCar's Avatar
Thanked: 1,756 Times
Is it hale or yale?
This is the first time I’m hearing someone use it for the rooms also. It’s true that it saves the hassle of keeping so many keys.
MyLife_MyCar is offline
Old 26th October 2024, 21:46   #10480
mpksuhas's Avatar
Thanked: 8,407 Times
Any suggestions?
Amongst the two, nothing much to reject / select I would say. However, you are getting a bigger model in Panasonic for slightly lesser price.
That aside, both these are bit expensive, did you check out LG, since their customer care and product is good in longer run. Though nowadays, I see more expensive brands being pushed by the sales team in shops, could be due to margins.
mpksuhas is offline   (1) Thanks
Old 26th October 2024, 22:59   #10481
Thanked: 1,098 Times
Any suggestions?
Electrolux is new to India after a second entry in around 2022. As of now they have no manufacturing base in India. Service network would be very limited as well. So if you are the unlucky one to need service or a spare, you would face challenges.
Godrej, Bosch, Whirlpool, LG, Samsung, Panasonic, IFB, Voltas-Beko are some of those who have refrigerator manufacturing base in India. Some of their models could still be imported or OEM sourced.
Theyota is offline   (2) Thanks
Old 27th October 2024, 06:16   #10482
Thanked: 886 Times
Any suggestions?
Among these two I would recommend Panasonic owing to its better service network and manufacturing base in India. Moreover, it has a 2-year comprehensive warranty and 4 modes of operation and seems to be overall better value than the other model.
yedukrishnan199 is offline   (1) Thanks
Old 27th October 2024, 12:19   #10483
Thanked: 412 Times
Hitachi and Carrier have five years comprehensive warranty sans gas charging. Only Godrej offers wholesome warranty and they are also the cheapest by far, at 1.5 ton for 35,000 but there are so many negative reviews about Godrej out there on the net, just one too many for my liking, especially the aftersales service. After doing all my research, I might finally go for Voltas again, you can buy extended Voltas brand warranty that includes gas charging as well for 1+4 years.
jomyboy is offline
Old 27th October 2024, 15:00   #10484
Thanked: 632 Times
If you already have a Voltas and are relatively happy with it why change a company that works for you?
I have 3 voltas 1.5 tons non inverter ACs purchased over a period of 3 years with roughly a year's interval between each. Before that I had a Samsung inverter which gave so many problems that I swore off inverters. My main reason for buying the first Voltas unit was the 5 year extended warranty. The subsequent ones were cause of their excellent service.
Also please note, their extended warranty is more expensive if you purchase the unit online.
SedateGuy is online now   (2) Thanks
Old 27th October 2024, 21:52   #10485
Thanked: 158 Times
Is it hale or yale?
Typo !!
It’s Yale.
As for the rooms - Privacy and security. Just close the door and it’s done.
Dr Alpha is offline
