![]() | #2536 | |
Senior - BHPian ![]() | ![]() Quote:
Considering the scenario in Chennai, you would be using the AC regularly during night for atleast 5 - 6 hours which means you would need a energy efficient one. Please check the Panasonic Cube ACs . You wouldn't need drilling & other mason works. 5 star efficiency and ideal for rented apartments. | |
![]() | #2537 | |
Team-BHP Support ![]() ![]() | ![]() Quote:
I checked out Cube website in the morning, after reading some good reviews about it in the previous pages - but all of them seems to be 2 star? Am i missing something? Our office purchase department seems to suggest Voltas, among the cheaper brands available. Seems they had best experiences in providing General and Carrier, and among cheaper brands - Voltas. Voltas comes recommended in team-bhp? Didnt see anyone buying Voltas - although I went through quite a few pages in this thread. | |
![]() | #2538 | |
![]() | #2539 | ||
Look for a.s.s. when getting AC. If the room isnt big, 1 tonne should do and 3 star would do unless you are not gonna run it for couple of hours a day. A stabilizer (Vguard) for 1~1.5ton AC would cost 2.4k MRP. | ||
![]() | #2540 | |
This specific mode is not present in the model that i bought. Which means i need to switch it off when i feel too cold and get woken up because of that, alternatively set the timer to make this run for about an hour and then it switches itself off. Another newbie question, does this thing necessarily needs a voltage stabilizer? Last edited by mayankjha1806 : 25th April 2012 at 14:18. | |
![]() | #2541 | |
![]() Stabilizer is needed IMHO. It will help power surge and give contant power to the AC ( like what a cap does to a sub ![]() | |
![]() | #2542 |
Senior - BHPian ![]() Join Date: Dec 2007 Location: Gurugram
Thanked: 4,621 Times
| ![]() This is the biggest con there is. If your voltage stays between, 190 (to be safe, else I will say 170) and 250V then forget. Many modern Inverter models advertise that you do not need a stabiliser. |
![]() | #2543 |
Senior - BHPian ![]() | ![]() This tells me i am bad at explaining, BTW you are right. Here it is, this is exactly what i meant. Auto Sleep Mode: This feature reduces the cooling effect during the night automatically once you have set it. This is useful since you do not need the same cooling in the night as you do in the day. With the automatic setting you stay comfortable without chilling in the night and the low power bills will help you keep your cool in the day too. Source : Split Air Conditioners - Hitachi I Clean Split Air Conditioners, Hitachi ACE Cut Out, ACE Follow Me and Kaze Split Air Conditioners Retailer & Service Provider |
![]() | #2544 | |
How would hitachi compare with voltas? | |
![]() | #2545 | |
Any particular disadvantages with Hitachi? | |
![]() | #2546 |
Senior - BHPian ![]() | ![]() @C_D. Hitachi is good, we used a Hitachi window AC bought 11 years ago from Chennai. All these years it served without any trouble. Recently sold it and replaced with Panasonic split. A.S.S of Hitachi in Bangalore is not very good and Panasonic my more recent crush i went with it. Question : Does this AC has Auto Sleep mode as i have explained above? Last edited by mayankjha1806 : 26th April 2012 at 07:56. |
![]() | #2547 | ||
They do mention this though - 'Ever woken up feeling chilly in the middle of the night? ‘Kaimin’ adjusts the temperature automatically through the night to suit your body needs. It is an intelligent feature that ensures you get sound sleep every night and wake up feeling fresh every morning. By raising 1˚ C per hour for upto 4 hours, its operation ensures saving of power.' http://www.hitachi-hli.com/iclean.html#features Last edited by CrAzY dRiVeR : 26th April 2012 at 09:04. | ||
![]() | #2548 |
BHPian ![]() | ![]() MINI REVIEW OF PANASONIC CUBE AIRCON: bought the panasonic cube a/c 1.25T for a bedroom size of 12x14 and it cools very well. in 15 minutes, the room gets chilled from 32deg to 26deg and the cube a/c has the simplest functions plus remote. timer function is there, upto 12 hours - which maintains a steady temperature at nights. auto on/off feature is also present in case of sudden cut-off. the biggest/simplest advantage is that the airfilter is pull-down (square screen mesh) type, which can be cleaned by anyone at home, just wash, air dry and push/slide it in upwards. no need to call/have an AMC for this simple chore. during installation, the mechanic opened and showed me the innards of both the indoor and outdoor units. the indoor unit has a "exhaust-like" fan with 3 speeds, air filter in-front of the fan and the condenser coil foremost - just 3 items with the remote circuit board at the side. the throw of the cube a/c at max. fan speed 3 is felt 10 feet across the room, literally. the fan speed 1 makes it the silent cooler, very very silent infact. the outdoor unit is slightly larger than regular other a/c brands, but has very simple mechanicals/electricals inside. 80% of the outdoor unit is occupied by the cooling coil and the same "exhaust-like" fan, while the compressor and the electrical CB are in a corner. you need to drill just one 3 inch hole for the gas in/out tubes and elec wire, and another 1.5 inch hole for the water outlet. another 2 drill holes for mounting the bracket for the indoor unit. the disadvantages are : you have no air-flow adjustments or vents to direct air to your desired position. the air throw is just straight ahead of the indoor unit so you can fit the indoor as low as you want, just as old-time window aircons. no heating mode or fancy adjustments. even the remote is tiny and simplest with just On/Off, timer on/off, fan speed On/Off and temperature increase & decrease buttions. just 5 buttons with a lcd display, pls note no display in the outdoor unit except an indicator light. advantages : the cube a/c is rated 2 star by 2012 standards, which means 3 star as per 2011 standards. the power consumption is 1600W as per the label. energy efficiency is 2.75 EER. the biggest saving is the cost - 18,000/- all inclusive with free installation, free stabilizer and free door delivery (with a panasonic rice cooker as free gift - can get another 500-700/- reduced if you forego this free gift). the next branded 2 star split a/c's cost approx. 23,000/- which makes this cube a/c - the best buy. |
![]() | #2549 | |
BHPian ![]() Join Date: Nov 2011 Location: Hyderabad
Thanked: 53 Times
| ![]() Ordered a Hitachi 1.5T Kaze, will be installed today/tomorrow. ~35k including Keeline stabilizer (with replacement warranty) and installation. The room is on the first floor (duplex house) and the terrace gets good amount of sun during the day. Room dimensions are 12*16*10ft and AC will be used only during the night for 4 months/yr. Hope the 1.5tonner will suffice. Quote:
Kaze 1.5t installation completed today, both the IU and OU are manufactured in Jan/2012 and the OU has a sticker price of 32990 (instead of 34590 as per HLI website currently). I amd wondering if this is a 2011 model (relative to star ratings) or otherwise a 2012 3* model manufactured before the prices were increased. Any thoughts? Thanks. Last edited by GTO : 27th April 2012 at 12:28. Reason: Merging both your posts. | |
![]() | #2550 |
BHPian ![]() Join Date: Jun 2010 Location: Bangalore
Thanked: 148 Times
| ![]() Finally could not take the heat anymore and bought a couple of Panasonic 1T 2Star CS-UC12NKY. Did not want to bother about the star rating since being in Bangalore, won't use it for more than a month per year. Not installed yet, more after installation. Got it for 19K each (retailing for 23k) from a known dealer. |
