![]() | #841 |
Distinguished - BHPian ![]() ![]() Join Date: Jun 2007 Location: Chennai
Thanked: 15,778 Times
| ![]() That's a very nice explanation, and, for when I next buy, you have sold me the idea ![]() |
![]() | #842 |
Senior - BHPian Join Date: Sep 2007 Location: New Delhi
Thanked: 274 Times
| ![]() Khoj, thanks, that's nicely explained, but....now consider a situation where there are no traffic signals! Looking around in Delhi, a city that suffers truly hostile summers, I find that in most 'commercial' places the ACs are continuously on, struggling to get to the set temperature! This is the scenario in a lot of shops/stores and many offices. These people will see absolutely no difference in their power bills. In a home environment, or in well designed office premises where AC plant sizing has been generous and insulation has been applied there will, no doubt, be savings. In short, savings will only be realized where the compressors are cycling (on-off) and the more they cycle the greater would be the savings. An under-sized AC where the compressor is always on most of the time that the AC is in use will offer very disappointing savings, if any at all! I wish manufacturers would explain this point clearly to customers before they shell out the money for these very expensive ACs! ![]() |
![]() | #843 |
Senior - BHPian ![]() Join Date: May 2009 Location: Chennai
Thanked: 1,740 Times
| ![]() @anupmathur I think the concept will come in to play only at night during our summers. During the day time the compressor will be running for most of the time anyway! |
![]() | #844 |
Senior - BHPian ![]() | ![]() Guys, Before you start jumping to conclusions go through the link below. Inverters have been in use for many years now and proven their credibility in areas such as Australia which sees ambient temperatures as high as North India if not higher and in the Gulf where for months together the ambient is beyond the mid 40s. Explore the link VRV system | Product | Daikin Industries, Ltd. Commercial establishments here face the same challenges as those in the Gulf. However there are many other components and factors in a large building which will effect the overall cooling/heating efficiency and those would be fodder for another thread all together. |
![]() | #845 |
Team-BHP Support ![]() ![]() | ![]() with pretty limited options would you suggest Videocon Split 1.5T? the only good brand available is Blue-Star and it has been advised to not buy Carrier, Hitachi and General isn't available, wouldn't want to go for Samsung/LG though Godrej, Voltas are present advise please |
![]() | #846 |
BHPian ![]() Join Date: Jul 2008 Location: Noida, NCR
Thanked: 282 Times
| ![]() Recently there was a discussion on the convinience of shifting a split unit vs window unit. Well, I just finished shifting a split unit and can give the cost perspective. Uninstallation cost Rs1200 last year. Re-installation cost Rs.5000 (including Rs.2500 for gas refill) and it took more than 4 hours. All the concrete and brick dust are pretty messy as well. Sorry if this have been discussed before: does the gas have to be re-filled at every re-installation? |
![]() | #847 | |
Thanked: 274 Times
| ![]() Quote:
There are valves on the outdoor unit pipelines. These should be shut in the correct sequence (liquid line first) with the AC running. Most of the gas will now be trapped in the condenser. After re-installation at new location the unit will at best need only a small top-up charge of refrigerant, if any is required at all. | |
![]() | #848 |
Newbie Join Date: Dec 2009 Location: Bangalore
![]() | #849 |
| ![]() If an AC compressor is running all the time and struggling to reach even the set temperature, then it is indeed under-spec, and something of an expensive mistake. False economy at the time of purchase. I was once told by an engineer that over-spec is not a good idea either. Something about cooling the room too fast, again causing cutting in and out too often. |
![]() | #850 | |
Thanked: 282 Times
| ![]() Quote:
![]() | #851 |
Thanked: 274 Times
![]() | #852 | |
Thanked: 274 Times
| ![]() Quote:
It might leave you a tad disappointed by not quite cooling to the required degree! But you'll be all smiles seeing the electricity bill at the end of the day! Last edited by anupmathur : 28th March 2010 at 21:53. | |
![]() | #853 | |
| ![]() Quote:
To match the opex of inverter RACs with normal rotary RACs is not possible. It is an application based and capex decision whether one has to go for Inverters. The cost of Inv. type AC is about 50% more than a equivalent capacity premium normal rotary split. | |
![]() | #854 |
| ![]() I suspect that the greatest running-cost economy is that of a correctly-sized unit. (And I am used to being a Thad disappointed ![]() |
![]() | #855 | ||
Thanked: 274 Times
| ![]() Quote:
Is there a duty cycle specified anywhere? ![]() | ||
