Old 21st September 2018, 11:38   #1261
Styler's Avatar
Thanked: 736 Times
re: The First Grand Vitara on Team-BHP [14 years & 150000kms]
I changed this entire assembly to reduce the play in the Gear Lever.
This is the image of the part replaced.
It is 28101-64J01 LEVER, GEAR SHIFT CONTROL Cost Rs 2032.80 + GST
You can order the same if you do not get the bush.
I would recommend that you order the other part (10. 28117-82C02 Seat Lower Rs 125 + GST) too as it is just Rs 125 . That reduces the play.
Styler is offline   (3) Thanks
Old 28th September 2018, 18:21   #1262
wanderernomad's Avatar
Thanked: 1,276 Times
Guys, I was having difficulty sourcing the AC cabin filter for the GV, but i found that the cabin filter for the Creta is an exact fit.
wanderernomad is offline   (4) Thanks
Old 12th October 2018, 14:55   #1263
Thanked: 30 Times
Hello everyone. I was wondering if I could gather some thoughts about changing the wheels set-up from stock alloys (17 inch) to off-road friendly steel negative offset ones. What would be the impact of downgrading to a 16 inch rim? Can I compensate with a higher profile tyre? Will this impact the way the vehicle behaves on road?
On a separate note, we have another 2.4 manual joining the family now. My very close friend is closing the deal today on a 2011 GV - 2.4lt manual. It has been an interesting experience so far. I'm eager to share our experiences.
sawan_dubey is offline
Old 12th October 2018, 15:06   #1264
Thanked: 30 Times
I had ordered one via Mandovi motors on Hennur road (Bengaluru) and I got a call that a few parts have arrived.
I had asked for:
Air filter
AC cabin filter
spark plugs - the dealers told me Suzuki uses Denso sourced sparks. Are there any better alternatives?
I'm getting these 3 things fixed tomorrow. So far, no major issues since my previous service at 95K kms, except for a minor fuel leak from the fuel transfer pipe that connects to the engine (located right up-front near the coolant reservoir). We were on our way to Mysore and my wife swiftly red-flagged petrol smell inside the cabin. I parked the vehicle to the side, switched off the engine and immediately narrowed down the source of leak (nose assist). The fuel pipe had a weak spot at the end that plugs into the nozzle and I used my multi-purpose knife to chop off about half an inch and reconnected the pipes. Voila, no looking back since then.
Still all smiles with the GV Our 8 month old son enjoys traveling with us and he loves watching the scenery go by all day from his child seat! I love the planted feeling (thanks full time 4wd) and exhilaration
I have completed 5K kms in the last 3 months with a trip to the western -ghats, one to Puducherry, and multiple trips to my hometown, Mysuru.
Old 12th October 2018, 15:31   #1265
vigsom's Avatar
Thanked: 25,496 Times
If you are fine with standard nickel plugs, the DENSO K20PR-U11 is very good.
However, the NGK Iridium IFR5J11 is a better and longer lasting plug; goes all the way till 1 lac kms without fuss.
vigsom is offline
Old 12th October 2018, 16:08   #1266
Thanked: 30 Times
Thanks for the information. What are the benefits of iridium plugs? any negatives? Also, is NGK Iridium IFR5J11 the full spec to buy this? I'm looking at online options, but is there any other way to buy this locally!
Old 12th October 2018, 17:16   #1267
I had asked for:
Air filter
AC cabin filter
How much did they cost? I bought some after market stuff and the Cabin Filter was for 300 INR while a Sakura Brand Air Filter was for 900 INR. I can see that Aliexpress has the Air Filters for around 500/600 INR. Anyone has an experience of using them?
Old 13th October 2018, 11:29   #1268
Thanked: 1,674 Times
I fitted the IFR5J11 iridium spark plugs 3 years ago. I have driven about 14000 kms since then.
The iridium plugs are worth the premium. The engine low end traction becomes better and a lot of flat spots are eliminated. Do get the throttle body cleaned at the same time.
A few months ago I got the engine decarbonised using the hydrogen injection system. There was a noticeable improvement in torque and smoothness. Last month I added a can of Nulon E25 to the engine oil. The engine has now become smooth as butter.
I have just replaced the engine air filter with a K&N unit. I have only driven about 5 kms after that. But it looks to be very promising.
I replaced the cabin air filter with one meant for the Creta. This unit does not fit in the normal slot of the OE unit. I applied double side tape on both the width sides and placed it on the bottom of the housing. And I used some foam pieces to pack the whole thing into place.
I plan to order another unit from Aliexpress later.
sridhar-v is offline
Old 13th October 2018, 14:35   #1269
Thanked: 30 Times
Suzuki genuine spares - INR 1451
I replaced the cabin air filter with one meant for the Creta. This unit does not fit in the normal slot of the OE unit........
Thanks. These look like good next steps for me. Just got back from the service centre. The AC cabin air filter was a fit, but they got the spark plugs and the air filter wrong. I would be grateful if you could tell me how you sourced the NGK spark plugs. Also, are you from Bengaluru? Where are Bengaluru GV owners servicing their vehicles from?
Last edited by khan_sultan : 15th October 2018 at 11:40. Reason: Edited quoted post for better readability
sawan_dubey is offline   (1) Thanks
Old 14th October 2018, 09:56   #1270
The iridium spark plugs are readily available on the Maruti spares system. Part no. is 09482-00549. You can order through your MASS or through the Over The Counter Sales outlet. If it is not in stock in Bengaluru the system will order it and you get it within 15 days.
I am from Pune. But i will be more than happy to help you with any issues.
Old 14th October 2018, 10:59   #1271
Thanked: 30 Times
Fantastic! Thanks for the information. I'll place an order right away. Anyway to find out the air filter part number?
I must have noticed from your display info that you're from Pune
Much obliged with the offer to help out. This is an example of the fabled Tbhp community spirit.
Another question to end this post. Is the SX4's oil filter a direct fit? The service centre guys seem to think so, but I'm wary of their overconfidence.
Old 15th October 2018, 10:23   #1272
........Another question to end this post. Is the SX4's oil filter a direct fit? The service centre guys seem to think so, but I'm wary of their overconfidence.
Air filter : 13780-65J00 I paid 757+tax in 2015
Yes SX4 oil filter fits 16510.61A31 484+tax
Lots of parts are common with SX4 -eg door switches.
Old 15th October 2018, 11:22   #1273
vigsom's Avatar
The sx4 oil filter is 16510M55K00; costs approx 135 rupees.
I have used this filter in all oil replacements so far; perfect fit.
vigsom is offline
Old 15th October 2018, 12:37   #1274
spgv's Avatar
Thanked: 99 Times
I have just replaced the engine air filter with a K&N unit. .
Sir, please share the details
spgv is offline
Old 15th October 2018, 14:45   #1275
Jaggu's Avatar
Thanked: 15,907 Times
Even in my car SX4 filter was used, the dealer checked on their system and confirmed the part was the same.
Jaggu is offline   (1) Thanks
