Old 28th March 2025, 20:55   #136
Thanked: 21,233 Times
Re: Which Projector Foglamps to choose? So many options in the market
Alibaba is a wholesale website meant only for B2b business. Aliexpress used to be their b2c website and I used to order a lot from there till 2018. After that Aliexpress was blocked and it is now very difficult to buy anything from Chinese websites and have it shipped to India anymore.t.
I beg to differ. Have been ordering stuff off Alibaba from quite sometime now. For four of my cars and a few friend's cars I have ordered the same projector sold here for hardly 6k a pair including customs. They are open to both B2B and B2C orders especially for something like a pair of projectors. Has been hassle free and worth the money. In fact, except the fact that you cant order directly on Aliexpress, the entire supply chain is active and works better than before including customs clearance. Apart from these projectors, have ordered a lot of other stuff and have never faced any issues.
audioholic is offline
Old 29th March 2025, 01:38   #137
TurboTales's Avatar
Thanked: 84 Times
I own a Skoda Slavia Ambition variant and prefer not to replace the headlamp housing unit. Therefore, I want to install projector fog lamps instead.
Could you recommend a projector fog lamp that is easy to install (plug-and-play)?
Product compatible with Slavia ?
Wattage ?
Price ?
TurboTales is offline
Old 29th March 2025, 09:17   #138
C?
There wouldnt be plug and play options for Slavia unless you want to live with an error on the dashboard about fused fog lights every time you start the car. And the fog lights of the Slavia are directly powered by the BCM without any relay in the middle. Hence, there will be need of a relay in the middle to keep the BCM safe. That needs to be programmed in VCDS to not show up errors.
If your car has cornering lamp function that also needs to be disabled else it will cause flickering of the fog lamps when the cornering lights turn on and off. Hence, its not so straight forward to switch to LED fog lamps on the Slavia.
Old 29th March 2025, 14:57   #139
TurboTales's Avatar
Thanked: 84 Times
Thank you for the details.
Can I install Osram 50W plug and play LED headlights without the relay, dashboard error and all the hassle you mentioned for fog lamps ?
Old 1st April 2025, 12:27   #140
predatorwheelz's Avatar
Thanked: 2,168 Times
Thank you, useful information. I too have a (2024 April) Slavia Ambition and was thinking of replacing the stock fogs with 3" projector lamps.
Alternative question then. If I leave the fogs alone and install Aozoom TH02 auxiliary lights within the grille, this should not cause any problems right? Company wiring doesn't get cut. Additional lights get wired to the fuse box and maybe a separate cabin switch?
And no, the Ambition doesn't come with cornering lights.
predatorwheelz is offline
Old 6th April 2025, 11:34   #141
Thanked: 11 Times
Originally Posted by Torq View Post
Any suggestions for sonet gtx fog lamp upgrade? Not looking for anything too white or too yellow
Buddy did you upgrade the fog lamp? If so let me know, i too have a Sonet GTX
punchthebully is offline
Old 9th April 2025, 08:50   #142
Hello Everyone, I'm based in Gurgaon and looking to upgrade my stock Toyota Yaris 3" fog lamps.
Visited Sam Garage in Dwarka yesterday to check TRICOLOUR variants available. They showed me American Muscle G2 (₹5700) which (I felt) was at par with lights of much popular but costlier AES FX3 (₹9500).
Considering my car is 6+ yrs old now, and I might keep or sell it, I am pulled towards saving costs. The G2 also doesn't get any warranty while the FX3 has 1 yr cover.
Would really like to have fellow BHPians opinion and recommendations, if any other better options I should consider.
Many thanks.
mehargags is offline
Old 17th April 2025, 14:08   #143
Torq's Avatar
Thanked: 640 Times
I am still searching for something good, which someone has already done on their sonet.
Torq is offline
