Old 6th November 2006, 17:12   #31
Thanked: 30 Times
Any Info on the good brands to look for when looking at relay + wiring + ceramic holders?... read some where that there is a kit available (includes wiring + relays + holders)... any info on that would be more than welcome!...
anToNIcHeN is offline   (1) Thanks
Old 6th November 2006, 17:19   #32
abhibh's Avatar
Thanked: 39 Times
INQUIRY: Strobe lights / Colour changing Paring Lights
I have 2 questions:
1. Are there colour changing parking lights available anywhere ?
2. Whats the usual cost of parking strobe lights ? And do they keep on blinking or you can just halt them anytime ?
Thanks.
abhibh is offline
Old 6th November 2006, 17:33   #33
Thanked: 19 Times
You can easily get a Headlight Wiring kit for approx 300 Bucks and can buy Roots Ceramic holders for 140 for a pair.
Mugen.
Mugen_Power is offline
Old 6th November 2006, 19:18   #34
vidvai
Posts: n/a
i wanna ask why are streetglow xenon headlights so cheap $30...are they somethin else...is bad illumination a concern...??
link:
http://www.streetglow.com/cgi-local/...=/page=hid.htm
thanks
Old 6th November 2006, 20:07   #35
Lukeskywalker's Avatar
Thanked: 1,244 Times
Mugen.
Any idea where in Bangalore I can try to source these out?
Lukeskywalker is offline
Old 6th November 2006, 23:52   #36
Thanked: 19 Times
I dont have any idea but few links might helps.
http://www.team-bhp.com/forum/modifi...us-cities.html
http://www.team-bhp.com/forum/car-en...bangalore.html
http://www.team-bhp.com/forum/tyre-a...bangalore.html
Cheers,
Mugen_Power.
Old 7th November 2006, 11:22   #37
tsk1979's Avatar
Thanked: 23,494 Times
Originally Posted by vidvai
...nd do black neons actually give out a black 'light'...i mean isnt this against the basic laws of physics...?
they are used inside the car, and will make any white or fluorocent object inside your car glow.
tsk1979 is offline
Old 7th November 2006, 16:11   #38
vidvai
Posts: n/a
so say, a combination of black neon and white-led pedals will look awesome...and i am assuming it wont have any blinding effects...?
Old 10th November 2006, 18:47   #39
mail4ajo's Avatar
Thanked: 337 Times
A small query...Please do not laugh or ridicule if this is a stupid one.
Would it be possible to have 2 holders in a headlight unit, one with stock headlamp and another with a powerful headlamp? Would it be possible to switch betweem them as and when you require? Say, stock in the city and powerful one for the highway driving..
mail4ajo is offline
Old 12th November 2006, 22:34   #40
Guys I have located a lighting specialist
dear friends,
It was so much fun, I met this guy, He started talking about car lighting, This guy is a serious pro in Automotive lighting, He has changed the way the lighting on my car is behaving. Anyone looking for any kinds of information and products on lighting, do contact him. His name is Ashwin Bhartia, 9840022620, ashwinbhartia_4@yahoo.co.in. This guy is apparently one of the biggest importer of lighting equipment from Germany. (HELLA, OSRAM, PHILLIPS, XENONS, HID, you name it), anyone looking for any lighting stuff. Contact him
chips_mittal is offline
Old 13th November 2006, 11:41   #41
I have maruti 800 car(May 97 model). I would like to upgrade headlamp. DO suggest me the available options. My budget is approx 1000/-.
geekay is offline
Old 13th November 2006, 12:26   #42
tsk1979's Avatar
geekay, its simple.
Get 100/90W roots headlamps, get new wiring and relay.
Wiring+Relay = 500rs
Two halogen bulbs = 450rs.
Since you are having a real old 97 800, make sure you put a Voltmeter to your battery and check wether your alternator is in top notch condition, otherwise these lamps will put unnecassary load on your system.
tsk1979 is offline
Old 13th November 2006, 13:46   #43
Jaggu's Avatar
Thanked: 17,320 Times
so my hunt for better lighting started and i can say have fairly succeded also over the weekend.
iKON 2000 model and the lighting could have been termed 'bad' which i finally managed to realize with a bent rim on the way back from mysore to bangalore couple of months back, so the idea was running in my head and 2 weeks back went searching for a set of additional lights.
first searched the gujli market in bangalore and the best deal i could get was whole SXI transformation with clear lens head lamps, fogs bumper and grill for 8 k, but would have taken couple of days of head braking instal and painting to get it proper, then went on to search couple of accesory shops and saw some add on helas for 1800, problem again mounting them safe in the stock old fashioned bumper.
so finally this weekend decided to get 90/100 lighting atleast, started from koramangala where i saw Philips crystal vision, seeing the blue shaded bulb itself was a turn off for me and the way the guy said i can plug and play with the stock wiring made me run, checked out another guy who had Philips rally but he also was also giving gyan though finally agreed i would require new relay and wiring, thanks to parking issue went to JC road from double road and parked in the multi level car park.
across the road were some accesory shop and went and checked, and they had Philips 90/100, as well as ready made wiring kit from PMP, i was impressed. Fitting took some 10 mts, remove the old bulb, plug wiring harness from to the existing wiring, other 2 to new high wattage bulbs, plug the relay and the power wires onto the battery and you are ready to go
bulbs 300
relay and wiring 500
and went on to splurge some more on Stebel Nautilus
overall visbility has improved by 60%, low beam i cant increase reach as in incerase hieght, or in high beams and with more weight in rear the beam will hit the trees, but had adjusted it previously to max and now atleast in high beam i dont have blind spots near to the car thanks to better lighting compensating for throw and yes am more careful with high beam in city, low beam have perfect vision of road even with blinding lights from oppsite side.
so overall am happy for now
Jaggu is offline   (1) Thanks
Old 13th November 2006, 13:49   #44
willy's Avatar
That is a very good thought. I too feel there should be some modification to the headlight unit or replace the whole unit to have a powerful headlight and the medium one so that we can escape from the cops.
willy is offline
Old 27th November 2006, 19:12   #45
Hi, what is the standard fitment for opel corsa ( high & low beam)
dhir_d is offline
